Originally posted by pearldrum
I've been considering getting some brighter foglight bulbs. Let me know how they compare to the old ones when you get them installed.
I bought some clear 100watt foglights....they are a tiny bit brighter when the headlights are off, when the headlights are on, its not noticable. Was it worth the 15 bucks i wasted? HECK NO! Btw, the yellow headlights/bluish foglights looks ugly.
991.1 RS - Lava Orange
991.1 GT3 - Sapphire Blue - gone
997.2 GT3 - Guards Red - gone
996 GT3 4 Liter - Basalt Black - gone
Old 03-10-2004, 07:35 PM
Nabeel's Avatar
Send a message via AIM to Nabeel
Z-Man is using neon in his car? Z-Man!?
I'm speechless.....
'85.5 944
Kalahari Beige/Brown
5-speed
76K miles
color-matched fuchs
SOLD
Old 03-10-2004, 08:01 PM
fast924S's Avatar
Send a message via AIM to fast924S
GOT RICE??
1986 951, Stock for now.
]87 924S Gaurds red- SOLD after 11 years of ownership
Old 03-10-2004, 08:10 PM
Used & Abused
1.5 is correct however, you can use up to a 2.0. anything above will melt the bulb holders. The 1.5 and 2.0 normally are available at a good electronics shop or can be ordered through a dealer or maybe even thru pelican..
quote:
Originally posted by toolboy62
can anyone tell me if the 1.5W bulbs are correct or if they've been replaced? A fairly knowledgeable lighting guy says that the only standard bulbs in that format are 3W or 5W. Although it wouldn't surprise me to learn that they're Porsche specific.
nate
go to Clarks Garage, and look up instrument light replacement. 5 watts melts the surrounds, 4 watts almost melts things, 3 watts is a wonderful comprimise, 2 watts is dimm, 1 watt is useless. I'm working on an LED system for my early 44 and I'll post something when I get info.
83 - 944, daily driver
62 - VW Karmann Ghia, never moving restoration
"Oh Bother," said Pooh, as he chambered another round.
Old 03-11-2004, 02:53 AM
Originally posted by fast924S
everything... Its a oil leaking, air cooled lawnmower ..... I mean 911 , not a killer 924/944/968
Good thing it's a "T" and not an "S". You'd be humbled when passed and/or lapped by a lawnmower.
'87 924S , sold.
'99 Subaru O/B, 62K on first timing belt. Could have gone another 40K.
Old 03-11-2004, 04:49 AM
Eric 951's Avatar
replace injectors
replace slave/master
fill with ATE bleed system
replace catback
sand OPRV
change oil
drink beer
Eric
83 911SC/83 944
bunch of Honda 750s
Old 03-11-2004, 05:15 AM
Z-man's Avatar
I'm speechless.....
Yeah, I'm ashamed of myself. I feel dirty everytime I drive at night...
Gotta get the dash lights fixed before I got booted off this board!
-Z.
PS: Check the mileage on my odo: mean anything to you? ? ?
2010 Cayman S - 12-2020 -
2014 MINI Cooper S Coupe - 05-17 - 05-21
1989 944S2 - 06-01 - 01-14
Carpe Viam.
Old 03-11-2004, 05:52 AM
bertman's Avatar
Last year, I tried to finish my "to do" list but I still have a couple of things on the list:
Replace belts, rollers, front seals, etc.
Install spring centered clutch.
Install 968 mirrors, door handles.
Maintenance: flush & renew brake fluid/coolant/add freon.
This is what I did last year:
Detailed car top side, interior and undercarriage.
Repainted header/test pipe.
Redyed leather on front seats, steering wheel and shift boot.
Replaced front speakers.
Repaired power locks, passenger power window switch.
Painted tailights w/red translucent paint.
Replaced stone guards, some rubber trim pieces, painted rocker panels.
Painted/installed 951 rear valence.
Painted/installed 931 vented header panel.
Installed 951 side skirt pieces.
Polished 16" Fuchs, hubcaps, lugnuts.
Polished engine pan, strut bar, engine bits.
Installed Nology coil, new plug wires.
Replaced coolant tank.
Installed Potenza S-03's.
R&R power steering rack, tie rods.
Lowered rear ride height @ eccentric, aligned.
Installed new power steering lines, reservoir.
Replaced swaybar bushings.
Removed OPRV, smoothed and replaced.
Installed Koni rear adjustable shocks.
Installed 18mm rear sway bar.
Installed Zimmermann drilled rotors/new pads, painted hats & calipers.
Installed SS brake lines.
Installed short shift kit.
Installed MOMO shift knob/boot on shortened lever.
Removed MOMO knob and reinstalled OE shift knob.
I enjoy tinkering with the car so I'll always have a to do list. After 20 years of ownership during which I bought & sold many other "nicer" cars, it remains my favorite.
bertman
84 944 Original Owner
65 Plymouth Satellite
08 Mercedes-Benz E 350 Sport
Old 03-11-2004, 06:16 AM
vott does ziss do?
ronin's Avatar
you see "The Passion of the Christ" yet?
lest the pharisees of the 944 temple pass their judgment
Old 03-11-2004, 10:19 AM
Nabeel's Avatar
Actually Z-Man, it woud be really cool if you got the neon to light up in unison with the bass thumps from your 5000-watt stereo.
Seriously though, have any of you looked at the IceShark LED kit for replacing the instrument panel lights? Thar is probably the route I will go if I decide to replace my dash bulbs this summer (right now they are fine, just slightly dim).
'85.5 944
5-speed
76K miles
color-matched fuchs
SOLD
Old 03-12-2004, 12:34 AM
Z-man's Avatar
No 5000-watt thumpin' bass in my car: too heavy, and it would likely move around too much while I'm busy passing 911's on the track!
Nabeel
Unfortunately, I don't think the IceShark LED kit would work for me, since that kit gets it's 12v from the circuit board, which is where I'm having the shorting issues!
But I will take out the dash (hopefully this weekend) and give it another shot!
-Z.
Carpe Viam.
Old 03-12-2004, 05:47 AM
pearldrum's Avatar
Send a message via AIM to pearldrum
I bought one of those neon lights at autozone a couple of months ago. The guy at the register saw my car out the window (I was the only one there) and said. "I hope this light is going no where near that car." I laughed and said no, it was for inside my bass drum. I wanted to see if I could get it to flash when i hit it.
'83 arctic silver 944 n/a
Power steering? who needs it!
Old 03-12-2004, 07:09 AM
vott does ziss do?
ronin's Avatar
that's funny. did you get it to work?
Old 03-12-2004, 09:46 AM
Send a message via AIM to SlowToady
WooHoo!! Here's my To-Do List for the newest member of family.
1) Fix passenger inside door handle.
2) Give him a bath, and a good wax and buff. Maybe paint him.
3) Rotate the tires..Shoulda been done ~60 miles ago
4) Clean it!
5) Put new mirror on passenger side
6) Order some oil filters, and change the oil. Bought some Pennzoil 10W30 Full Synthetic.
7) a. Replace air filter
b. Replace spark plugs
c. Replace cap/rotor
8) Replace Timing Belt. Dad and I are doing this one together. Water pump was just put in ~8K miles ago, or around 1.5-2 years. Should I do that, too?
9) Clean brake dust on my rims, and polish em up.
10) Fix/buy exterior trim pieces that are missing
11) Bleed brakes
12) Figure out why hatch doesn't like opening most of the time. Fix it.
13) Change diff/tranny fluid
14) New battery? Hmmm...
15) Take it to my brother to get a new radio/door speakers
16) Replace lights that are out in back
17) Paint calipers "Arrest Me Red"
I think that's it for now...
What I've done:
1) Got my headlights adjusted properly.
2) Got it starting consistenly.
Let's see how many of those I can knock off the list in the next month or so...
I love my 944.
Old 03-13-2004, 08:29 PM
pearldrum's Avatar
No, I haven't gotten it to work yet, it's too sensitive. It picks up the guitars and bass when we play. I need to take it apart and cover the microphone.
Old 03-14-2004, 11:05 AM
vott does ziss do?
ronin's Avatar
or perhaps have a rheostat control for sensitivity
Old 03-14-2004, 12:04 PM
COLDBASS's Avatar
1. Figure out where the water, that puddles in the passenger rear foot area is coming from.
2. Fix number 1.
923/912E (2.1l OEM EFI
'99 F150 4x4 Chipped (who cares)
LLVL in the LBC...
"Long Hoods Rule"
"RICE - The Breakfast of Champions"
Old 03-14-2004, 04:44 PM
KLR KLR is offline
KLR's Avatar
Lightbulb
In no particular order...
1. Get car back from bodyshop (having dent repaired and rockers resprayed)
2. Remount 'turbo' badge
3. Have a couple of chips airbrushed, touch up other chips
4. Replace foglights
5. Replace rear cargo light
6. Replace glovebox lightbulb
7. Replace synthetic oil with dyno (tried to switch 500 miles ago, ended up with a leak right onto the headers )
8. Replace fuel lines with Lindsey kit
9. Replace as many vacuum lines as possible without removing the intake manifold
10. Fix vacuum leak at boost gauge connection
11. Fix non-functioning A/F gauge (lost power while driving last week )
12. Refinish phone dials
13. Replace cracked turn signal
14. Replace missing interior trim plugs
15. Put in H4s
16. Put in resister to dim boost gauge backlight to match my other dim interior lights (as my old man used to say, "you can raise the bridge or lower the river")
17. Have beer
18. Repeat
1987 951 - Stone Gray / Burgundy
15psi Guru Chips, Reliaboost, 3-bar FPR, KW Variant 3 Suspension, OE Euro Driving Lights, Iceshark Wiring Kit
Old 03-14-2004, 05:35 PM
