![]() ![]() ![]() They are now wanting me to bring it home little frustrated one don't wanna pay for another tow and two it ran when it got there. ![]() ![]() |
weighing in with limited knowledge
Some more knowledgable members will comment I hope, but the first thing I would ask them to do is check the fuses and replace the fuel injection relay. They can find the relay chart in the owner's manual, if you have it. You can get one from Pelican and have them install it.
If you can list what they fixed, maybe we can figure out the systems they touched and can narrow it down a little. Are you sure you have spark? Have them confirm that the fuel pump is running. If it isn't it might just be the fuel pump relay. The electrical systems in these cars are now over 30 years old and therefore a little fragile. Especially the 14 pin connector on the passenger side. Also, a car that has been sitting for a while is going to need other things, like a look at the fuel lines to make sure they're safe. Therefore, another option that I would suggest is to tow it to a place that knows about these cars and the common problems. Maybe a member here can weigh in on someone in Ohio. Good luck! I get the sentimental value thing. I have a Ronson lighter my dad had in the Navy. I spent stupid money to get it fixed and I don't even smoke. |
Recovering dismantler
Anyway -NO cps on an 81. How do you know its getting gas - Does the fuel pump run for a few seconds when you turn the ignition key on? Have you tried a small amount of starter fluid sprayed into the air intake - does it try to start? Is the green wire from the distributor, across the front rail to the Bosch box ok?
Neil 2009 Mini Cooper 2004 Mercedes CLK500 2024 Subaru Outback Touring XT 2020 Entegra Coach |
I also agree that the best place to check is the fuel injection relay. I use to have times when my car would not start, and after a lot of parts and searching, it was the relay.
thank u both for your responses the car turns over but gets no spark I believe they have check the fuses. I will check the green wire from distributor when I stop there tomorrow. Would the fuel injector relay cause it to not spark?
@928gene928 just a funny note this was my dads car and his middle name was Eugene and always went by Gene just a funny coincidence thanks again for some starting ideas |
also not sure about if its a cis or l-jet not sure what that is actually but if it matters I will find out and post
Engine management systems
CIS and L-Jet are the engine management systems. It controls the air and fuel mix for optimal running.
It looks like CIS ended in the 1979 MY for US cars. Which means unless your car is a Euro, you have L-Jet. Does your car have a fog light to the left of the rear bumper? If not, it is a US car. Which is good news, because my impression is getting CIS to work right is harder than the L-Jet, but that may be just me. |
Could be the green wire too
\Brad/ '82 928 Automatic w/Competition Package Black/Red |
I concur with the others that you may want to consider checking those relay connectors on the passenger side fuse panel. If you don't hear that little fuel pump whine with the ignition on, then it could either be the relay, or the connection on the relay needs to be cleaned, and then reseated... with the battery disconnected, of course.
us car for sure gonna spend a little time with it tomorow and repost with any results thanks
Another area to consider is the ignition switch itself, especially on older cars, the actual internal contacts can wear out and fail. This is one of the things I changed during my investigations.
alright much thanks to all the fuel injector relay has gotten me 80percent farther than we have been in a year. we have spark and with starting fluid got engine to fire now to figure out why why aren't getting enough fuel gonna start with fuel pump relay
Wonky alarm will cause no start also. Ask me how I know! ;-)
Kool
Relays, pumps, filters, accumulator, wur, check / clean / replace those items.
Ron 1978 5sp (#30) project-Wreckscue, 1979 5sp Euro Project 1982 5sp resto project, 1985 Auto S3 1984 Parts car (the fire car) 1987 s4 (parts, or maybe project) (Yes, I now have 4 project Sharks) |
well still not starting without starting fluid runs for a few seconds then dies can hear fuel pump spin up I am thinking fuel filter gumed up from sitting and not allowing a enough gas to get to engine
Bring a new fuel pump relay or two wires and a rocker switch and drive it back home. A picture is worth a thousand words. Post a pic of the engine bay. We'll tell you what injection system you have. Like Neil says, it's most likely L-Jet.
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior 1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD** ![]() |
curtisr
Ends go into the slots (centre on the top and bottom) that correspond to the 30 and 87 tangs on the relay. ![]() I've had no-start issues with my '82 thanks to a) bad relay and b) bad relay socket connections. |
I bought a new fuel pump relay and put in yesterday when we hit it with starting fluid it starts but dont think its gettin the gas it needs to stay running
Use the switch as Curtis shows, once you activate it and you don't hear your pump kick in, then there's your problem. I'm done on this thread unless you can provide us a pic of your engine. It's moot trying to help when there are two different injection systems for your year.
will try rocker swtich and get some pics of engine
Thread Tools | |
Rate This Thread | |
Tags |
81 928 wont start |
