Now in 993 land ...
Replace "Cup" Clutch - need part numbers
My 993 has the LWF / Cup clutch according to the receipts that came with the car. I need to replace the clutch and would like to buy all the necessary replacement components that ususally come in a clutch service kit. Can you help me with the part numbers? I don't see a Cup clutch kit without the flywheel, which I guess I will need!?
FWIW the TRG invoice from the PO only says "Carrera Cup Clutch Kit, Fywheel, Pressure Plate, Bearing, Pilot Bearing, Bolts" without Porsche part numbers. Thanks!!! |
I Don't Have Much Information About This so Please Help me.......
RS LWF 964 102 239 31 RS PP 964 116 028 53 RS disc 996 116 015 32 or 964.116.011.61 RS starter ring gear 964 114 143 31 RS guide tube 950 116 813 30 Rear main seal 999 113 426 41 Flywheel bolts 928 102 151 01 PP bolts n 014 715 3 Release bearing 944 116 080 01 Pilot bearing 931 102 111 00 note that some or maybe all have been superseded w/ 996 or 997 #s, same part just newer versions
Now in 993 land ...
Now I need to know what needs to be replaced (routinely). Please help me out. I went over it with the best of my knowledge: RS PP 964 116 028 53 <--- check RS disc 996 116 015 32 or 964.116.011.61 <--- check RS guide tube 950 116 813 30 Replace? Inspect first? Rear main seal 999 113 426 41 not leaking, do people replace this as preventative maintenance? This has been replaced about 80k miles ago about 8 years back. I usually let sleeping dogs lie - haven't heard this seal is prone to leakage on the 3.6. Flywheel bolts 928 102 151 01 would not remove unless you tell me I need to do the RMS as prev. maint. or does this need to come out for pilot bearing install? PP bolts n 014 715 3 ??? Release bearing 944 116 080 <--- check Pilot bearing 931 102 111 00 <---- check TIA, G |
RMS is one of those things that is cheap to do while the engine is out, if it's not replaced it could last for ever or go next week. i had one replaced and needed to replace it a year later. I guess it just depends on how lucky you feel. use new pp bolts I'd also think seriously about replacing the /20 shift spindle 950.303.134.02 w/ either the /3x part 95.303.134.05 or if GT still has them a GT replacement part and a hd 3/4 shift fork, again the /32 part is 950.303.113.04 and GT used to have an hd 1/2 version as well that was used in the 996GT3R(i'd need to look up the part # if you are interested)
Now in 993 land ...
![]() Quote:
One more question: What needs replacing on the clutch fork mechanism? Bearings, shaft, fork? Thanks a ton! G |
on the fork, why not let Dave R&R as necessary, there are several wear items, like the bushes at the ends of the fork and operating spindle
Now in 993 land ...
G |
Cup Clutch
Bill, If I want to convert my clutch to a "Cup" clutch, do I just need to change the flywheel?
My clutch was recently changed by Possum Motorsport and they installed a sachs clutch kit. From what I understand, the major difference is the flywheel, is this correct? Cheers, James
You will never know the feeling of a driver when winning a race. The helmet hides feelings that cannot be understood. Ayrton Senna 1993 964 RS |
dual mass flywheel and it's components or single mass and it's components as outlined above
Now in 993 land ...
James,
The way I understand your question is that you just had a regular sachs clutch kit put in and now want to go with a LWF / cup set up. I do not believe that the LWF works properly with the standard clutch kit. You will have to buy the entire LWF kit which consists of all parts Bill listed for us. I am in the opposite situation of you. I have the LWF but the clutch components are worn out. I can't just go buy a standard $800 Sachs clutch kit. G George |
Now in 993 land ...
Finally got a hold of an 8 mm metric "triple square" tool to take the pressure plate off. I am impressed how good the clutch disk and the flywheel look after over 80k miles on them. The clutch was getting pretty heavy - probably the pressure plate?
Do I need to have the flywheel resurfaced? It is very flat as you can see in the pictures, hopefully. There is light discoloration but no grooves or noticeable rounding. Thanks, G ![]() ![]() ![]() |
Now in 993 land ...
I consulted TRE during my last phone call on the flywheel - their recommendation on an LWF is not to resurface rather than hit it with some sand paper to get a nice cross hatch pattern helping to seat the new disk!
G |
If I read your post correctly You already have the longer guide tube needed for the cup clutch. It isn,t necessary to replace it again unless worn. I need one for an upcoming LWF install so if you already ordered a replacment and have a good used one I would be interested in it The clutch will get heavy as the disc wears thinner.also the grease on the guide tube goes away and friction increases there too. I think there is a special grease that is supposed to address the stiff clutch
1980 911 SC 3.6 coupe sold 1995 993 coupe 1966 Mustang Shelby clone 1964 Corvair Spyder Turbo gone 2012 Boss 302 Last edited by johnsjmc; 03-27-2011 at 06:36 AM.. |
When replacing the FW with an RS set up can someone tell me the orientation of the ring gear? The RS version has a step on one side and is flat on the other. Does the flat side go to the flywheel with the stepped portion facing the PP? Any help would be appreciated.
That was a great write up - thanks! I could not see the ring gear orientation though. Does the pressure plate fit into the stepped down side of the ring gear?
Now in 993 land ...
Test fit it and you will see that the stepped side will not lie flat on the flywheel but when you turn it around it will engage nicely to the pressure plate and lie flat on the flywheel. Hope this helps! George Last edited by aigel; 05-04-2011 at 09:00 PM.. |
Thanks George! That helped - I was able to get the clutch in today!
Thread Tools | |
Rate This Thread | |
