LinkBack Thread Tools Rating: Thread Rating: 2 votes, 5.00 average.
dos531's Avatar
Originally Posted by willtel View Post
I'm going to try one of these with an AEM Infinity.
Air Cooled Coolant / Warmup Sensor | The Dub Shop
Let us know how this goes. I would definitely try this out if I didnt already have a turbokraft cht kit ready to install.
'86 930 Guards Red - EFI MS3Pro, 80lb inj, 3.4, GT35R, Tial 46, Bosch 044, B&B Headers, 3.2 carrera manifold, Turbokraft Full bay IC
'12 Gallardo LP-570-4 Performante
Ducati 748R
Old 10-25-2017, 05:24 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #441 (permalink)
Will do. I have a good electronics store near me. Hope to pick up a thermistor tomorrow night.
I may also hit the local U Pull yard, and pickup a used GM Air Intake Sensor. I believe Tippy did this.
1988 Porsche 930 Targa - 3.4L Twin Plug Motor, DC 13 Cams, Supertec Head Studs, ARP Rod Bolts, Port and Polished Heads, Garretson Andial Intercooler, GSX 61 BB Stage 5Turbo, Tial F46 WG .8 Bar Spring, PowerHaus Headers, Rarly8 Dual Tip Muffler, MS3 Pro EFI conversion, 85lbs. Injectors, Center Force Stage 2 Clutch , Rebuilt 4 Speed with LSD.
Old 10-25-2017, 05:55 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #442 (permalink)
TurboKraft's Avatar
Their disclaimer is worrisome:
"This is not meant to act as or replace a proper cylinder head temp sensor"
Why sell it then?
Chris Carroll
TurboKraft, Inc.
Tel. 480.969.0911
email: info@turbokraft.com
http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft
Old 10-25-2017, 10:00 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #443 (permalink)
Originally Posted by philip j View Post
That's interesting... at what location would you place it? I'm looking for a alternative to the 1 wire Bosch sensor I've been struggling with... Philip
I'm not exactly sure where I'm going to put it yet. At the rate my project is progressing I'll let you know how it works out in about 3 years.
Why sell it then?
Think of it as a warm up enrichment sensor rather than a CHT sensor. It is accurate to about 260° which should be enough to get through the warmup cycle. A true CHT sensor like those used on piston aircraft would have an operating range closer to -40° F to 500° F.
1987 GP White 930
1977 Ford Bronco
Old 10-26-2017, 12:30 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #444 (permalink)
John,
I used a GE glass encapsulated NTC thermistor, P/N AL03006-1847-76-K. It rated at 3000 ohms @25C or 77*F. Digikey and Mouser sell an Ampherol version P/N AL03006-1847-76-G1.
-Dennis
1977 930 Slant, MS3 EFI, Carrera intake, Twin plug, Powerhaus headers, Magnaflow muffler, Garretson intercooler, GTX3071R
Old 10-27-2017, 07:52 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #445 (permalink)
Picked up a 10k Ntc thermistor yesterday. Thermistor cost $2.20.
Soldered a positive and a negative wire to the thermistor. Insulated each wire with shrink wrap up to glass resistor. Fed resistor through eyelet of connector. Squished connector down and then insulated entire assembly with some more heat shrink. I haven’t done the calibration yet. That is tomorrow’s job.
Old 10-28-2017, 11:53 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #446 (permalink)
I would rather be driving
jpnovak's Avatar
I often make "CLT" and "IAT" sensors this way. works well.
Easy to calibrate too.
Old 10-28-2017, 01:18 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #447 (permalink)
Where is best place to install the CLT? I know cylinder head would be ideal, but I don't really want to
remove intake and shroud. Was thinking intake manifold stud. They should transfer enough heat through the bolt for a quick warm up. Let me know your thoughts.
John
Old 10-29-2017, 02:28 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #448 (permalink)
3 restos WIP = psycho
kenikh's Avatar
I tapped the front of the cam tower
Sent from my Nexus 6P using Tapatalk
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 10-29-2017, 02:31 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #449 (permalink)
John,
I think there would be too air blowing around the intake manifold stud, so that the temperature would very too much as car and engine speed changes. You could try what I did and slip the wire terminal between the fan shroud and the cam tower for cylinder #3 forward most shroud bolt. Use a larger washer on top of the shroud to compress the wire terminal tightly against the cam tower. I see running temperatures between 140* to 179* in logs once warmed up depending on outside temperatures and engine loading. I have not run the car in cold weather around freezing, so the running temperature may go below 140*. I cut WUE to 100% by 120*.
-Dennis
Old 10-30-2017, 08:10 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #450 (permalink)
Thanks Dennis
Old 10-30-2017, 08:45 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #451 (permalink)
Originally Posted by jpilcher View Post
Holy wire gauge Batman! 22 or 24 AWG will suffice.
-Jayson
1976 911S Signature Edition - 3.2SSt (JE 98mm 9.5:1 pistons, 964 Cams, Carrillo Rods, ARP Head Studs, AASCO Valvetrain, 3.2 Carrera Manifold, ID725's, B&B Headers, TS HyperGate45 Gen V, TS RacePort, BW S360, AEM Infinity 506, E85)
IG: Signature_911
Old 10-30-2017, 11:22 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #452 (permalink)
Well I installed the CLT sensor on the intake stud. It took 5 minutes to get to 102 F. Obviously not the best place to install. The intake manifold wasn't even warm to the touch.
I plan on moving the sensor as per Dennis's recommendations. I'll let you know how I make out.
Old 11-01-2017, 05:00 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #453 (permalink)
jpnovak's Avatar
Try the intake valve cover stud next to the engine tin on Cylinder 3. Very little airflow in the corner.
Another option is to drill and tap the outer section of the cam oil line banjo bolt, install on the bolt. This comes to oil temp very quickly.
I do not like the shroud bolts. There is too much airflow that can leak out and falsely cool the sensor.
Old 11-01-2017, 05:51 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #454 (permalink)
Moved sensor to Intake Valve Cover on Cylinder #3. Warms up much quicker there.
When I started the car the Mat and Clt were within 1 degree F.
Old 11-02-2017, 04:02 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #455 (permalink)
John,
Let us know how it responds when driving (datalog) the car. I may move mine if the temperatures are more stable with increasing engine speeds and different outside temperatures.
-Dennis
Old 11-03-2017, 08:28 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #456 (permalink)
thermoster
how about something like this...
2x NTC 10K Thermistor Temperature Sensor Thread Probe Cable for TEMP Controller | eBay
87 930 GHL/Rarlyl8/Garretson/GT3582R/1 Bar/Wevo shift, mounts/Meth inj/LM-2/Custom Fuchs/Carrera intake manifold/Xtreme Carrera heads P&P/3.4/DR 993SS cams/ Mahl/Pauter/JE/Niresist/ARP/twin COP/8.25:1/KEP stage 2/twin tials/close 2,3,4th. MS3Pro Evo 500+ HP, BTSOMP Dyno
Old 11-03-2017, 12:44 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #457 (permalink)
If the max temp on that sensor is 118C, I don't think that would be high enough for a head temp sensor.
-Jayson
IG: Signature_911
Old 11-03-2017, 12:48 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #458 (permalink)
118C = 250 F my car never goes above 200 F...
Old 11-03-2017, 01:02 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #459 (permalink)
kenikh's Avatar
But you CERTAINLY want to know if it does.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 11-03-2017, 01:09 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #460 (permalink)
