Cylindeer Head Temp Sensor
Hi All
I am currently using a Bosch CHT sensor. It's fitted in the head of cylinder number 3. Warms up very quickly. I would like to retain this, but I don't want to have to take apart the shroud in order to test the temperature calibration. Anyone have any data on this sensor? Thanks John
1988 Porsche 930 Targa - 3.4L Twin Plug Motor, DC 13 Cams, Supertec Head Studs, ARP Rod Bolts, Port and Polished Heads, Garretson Andial Intercooler, GSX 61 BB Stage 5Turbo, Tial F46 WG .8 Bar Spring, PowerHaus Headers, Rarly8 Dual Tip Muffler, MS3 Pro EFI conversion, 85lbs. Injectors, Center Force Stage 2 Clutch , Rebuilt 4 Speed with LSD. |
87 930 GHL/Rarlyl8/Garretson/GT3582R/1 Bar/Wevo shift, mounts/Meth inj/LM-2/Custom Fuchs/Carrera intake manifold/Xtreme Carrera heads P&P/3.4/DR 993SS cams/ Mahl/Pauter/JE/Niresist/ARP/twin COP/8.25:1/KEP stage 2/twin tials/close 2,3,4th. MS3Pro Evo 500+ HP, BTSOMP Dyno
Now that I think about it, I should be able to check temperature and ohms as the car warms up using my current setup.
If you don't want to have to build your own sensor and prefer a bolt-on solution for engine temperature:
![]() This is a simple kit to install. The heads warm up more quickly than the 10+ liters of oil, and more accurately reflects the engine's temperature for a warm-up cycle.
Chris Carroll TurboKraft, Inc. Tel. 480.969.0911 email: info@turbokraft.com http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft |
Hey Dos531(Derek)
Sent you a PM regarding tracking number. Thanks John
I like that TK set up, how does it attach to the head? Drill and tap a hole in a fin?
Looks like something new is on the way.
Any info on this? Web link?
Compared to using oil temp -- the engine warms up sooner, so gets out of cold start mode sooner, drives better sooner.
Why do ECU manufacturers insist on mounting connectors atop the ECU? No more mounting it under the seat like factory -- if someone lowers the seat and adjusts it fore-aft, it hits the ECU connector.
Not really. DIY Auto Tune posted it as the banner image on their Facebook page. The Performance Racing Industry trade show is this week in Indianapolis so maybe they will announce something there.
Chain fence eating turbo
Haltech Elite has it right!!! |
I have my ms3 pro under the seat and there is plenty of room between it and the bottom of the seat.
The one thing I really don't like about the connectors being on top of the ecu is the danger of something falling inside the connector socket and wreaking some sort of havoc. |
Easy
I would rather be driving
I can't stand top mounted connectors either. Ok for a race car where you need access. Not great for a street car where you mount discrete. No options for 90 deg connector either. Same problem from many vendors.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
John, do you have a tuner locally that can help you with this once your done? Philip
Hey Philip
Yes, There is a dyno shop in Burlington that tunes Megasquirts, 20 minutes from my place. I should be able to get off boost map dialed in. Boost really needs a dyno. Especially on ignition side. Hoping to get some help from Pelican brain trust.
1988 Porsche 930 Targa - 3.4L Twin Plug Motor, DC 13 Cams, Supertec Head Studs, ARP Rod Bolts, Port and Polished Heads, Garretson Andial Intercooler, GSX 61 BB Stage 5Turbo, Tial F46 WG .8 Bar Spring, PowerHaus Headers, Rarly8 Dual Tip Muffler, MS3 Pro EFI conversion, 85lbs. Injectors, Center Force Stage 2 Clutch , Rebuilt 4 Speed with LSD. Last edited by jpilcher; 12-10-2016 at 12:49 PM.. |
Your lucky to have someone so close, it's a 4 hour drive at least for me, to the closest Porsche tuner/dyno. ;(
