Zombie
jack points on 911
i looked through previous posts just got more confused when i was a kid i used to work at a porsche dealer (lot boy) anyways they always just had small blocks of wood and lifted or jacked the car from the four corners of the pan i even think i once saw them jack the back of one using a block of wood on the sump plate i would think that using the jack point under the sills would just cause more rust problems in a already rust prone area?
Green Skull 006
Check your manual, exact lift points are given. I think it's one of the pages at the back.
S Reg 823 R Gruppe 246 1955 pre-A Carrera Speedster...x 1974 leichtbau..."Sascha" "It makes me sad. Our cars were meant to be driven, not polished" - Ferry Porsche while surveying a PCA Parade concours field. |
This applies to all cars. Where the manuals tell you to jack the car up by, is also where you are supposed to put the jackstands. Can't do both. For the 911, I use the factory jakc point, then place jackstands in the proper places.
The "collection" 1983 911 SC Targa (1 of 1430 imported) 1994 MB E320 Coupe (1 of 825 imported) 1992 MB 190E 2.6 2004 Volvo V70 2.5 Turbo (1 of a bazillion imported)
I hate to say this but ... the
button is your friend. There have been numerous posts on this topic. The best is by Bill Verburg who has a picture of the bottom of the car with both the jacking and support points marked. Tell us what you find.
Harry 1970 VW Sunroof Bus - "The Magic Bus" 1971 Jaguar XKE 2+2 V12 Coupe - {insert name here} 1973.5 911T Targa - "Smokey" 2020 MB E350 4Matic Last edited by HarryD; 04-22-2006 at 05:03 PM.. |
Zombie
well thanks for your hospitality harryd
The problem is that unique or even emergency posts get pushed down by new posts. When those new posts are on things that have been answered literally hundreds of time before, people are less likely to re-re-...answer.
The search button at the bottom RH side of the screen is the best one to use.
"A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off |
Sorry you feel that way. Please do note that not only did I tell to to use the search button but also gave you a bit of information on what you needed to find. Did you find Bill's post? Did it not answer your question?
Make Bruins Great Again
Tony: the truth is that the search button is your friend. You will find a TON of info that will help you (now and in the future). I spent a month "going to school" using the search button.
-------------------------------------- Joe See Porsche run. Run, Porsche, Run: `87 911 Carrera |
Zombie
yes totally understand but theres alot of opinions on my main concern being can i lift my engine using the sump plate i saw as many for as against i would not care but i think its the only way to get both rear wheels off the ground.
Zombie
lift my car using the sump plate not engine
Non Compos Mentis
To get both rear wheels off the ground, I usually lift one side at a time using the factory jack point, and then using a jackstand under the torsion bar cover.
But others have been using the sump plate for years without any negative effects. As long as you don't lift on the sheet metal pan, you're probably okay. |
Somatic Negative Optimist
tonypeoni: It helps to state what year/type your car is because the sump plate was modified over the years.
That said, I think it is not very smart to use the sump plate for jacking. Go just slightly ahead (towards the clutch) on the engine seam with a wooden block, or a hockey puck. Regarding search: A lot of people take the short-cut of letting other people do the search. Use the "Search" button, all the info is there.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD! 1995 seafoam-green 993 C2, LSD, Sport seats. ![]() Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Semper drive!
Re: jack points on 911
Not trying to slam you but your original post was a little difficult to understand. Had to read through it a few times to finally understand what you were saying/asking. There are loads of people on this BBS who love to help fellow Porsche owners, but if they can't understand the question, chances are they'll move on to another. Just my own $.02. Oh, as far as the jacking points, definitely do the search thing for the Bill Verberg post. He provided a photo of the under-side of the car with all of the jacking and support locations clearly identified. Good luck! Randy
84 944 - Alpine White 86 Carrera Targa - Guards Red - My Pelican Gallery - (Gone, but never forgotten )One Marine's View Igitur qui desiderat pacem, praeparet bellum |
Zombie
Alright id say this has got out of hand. Any other a** holes want to chime in on punctuation, sentence structure, grammar or posting threads that have already been answered?
No comment on your last post.
Get yourself a jack pad from our host. I use it all the time. I lift one side then put a jack stand under the torsion bar covers; then do the other side. The nice thing about the jack pad is it's ease of use. I'll lift the car just to have a look at stuff in order to familiarize myself with the car; you might say "just for the fun of it". And, as the others have mentioned; the search button. I've learnt a ton about my car by spending hours reading old posts. Of course this is where I might run out and lift the car to get an eyeball on what I may have just read about. My P-car insurance ran out two weeks ago but the fun doesnt' end when you can't drive it. I'm doing a valve adjustment this week end and will continue to putter with the car until I dicide to put it back on the road. This is the other half of the fun in ownership of these cars. Enjoy tonypeoni!
Henri Owned for 21 years: '87 Carrera coupe Venetian blue |
Many will tell you that they have sucessfully lifted the rear of their car via the seam on the engine (near the sump plate). Personally, it makes no sense to me to lift you car via it's single most expensive component when there are safer alternatives. To lift the rear end I use the factory lift points and put jackstands on the Torsion Bar covers or T-Bar Tubes. But then again, your car, your money, your choice. What are you needing to do? Best of luck.
If it flows, it goes. If its smooth, it moves. Any questions? 96 993 C2 (Current) 87 911 Factory Turbo-Look Cab (Sold) 85 911 Factory Turbo-Look Targa (Gone) |
chilllackofpuncuationgrammarsentencestructuremakes forhardreadingforthoseofuswhowishtohelp. Help us help you.
Semper drive!
![]() Randy
Zombie
With all this popularity I'm starting to feel important. Ive never got elected to anything before. I wonder if i should run for moderator?
