scumbag
2. You can make one or buy them. Very readily available on eBay. You need 6 inlets, one outlet at a minimum. It's just a chamber/reservoir that all your vac lines connect to. Don't overthink it. 3. Get creative. Any overflow can with a port on the bottom can be made to work. Similarly, any catch-can without a port in the bottom can easily be made to have one. Simple is best. I love the idea of draining the catch can back into the sump as long as the oil gets (and stays for a bit) hot enough to burn off any water. In daily-driven (especially non-garaged) cars, draining into the sump isn't a great idea. They condense a lot of water vapor into water which would end up in your sump. I reckon a garaged air-cooled 911 will be just fine. But don't take that as gospel. There are myriad threads on catch-cans here on Pelican and I think they all touch on draining to the sump vs being drained manually.
My first Porsche - http://forums.pelicanparts.com/porsche-911-technical-forum/989493-my-low-budget-dream-car-build.html AchtungKraft #009 - IG: @doktor_b |
https://www.diyautotune.com/shop/solenoids-and-outputs/idlecontrol/ regards, al
[B]Current projects: 69-911.5, Previous:73 911X (off to SanFrancisco/racing in Germany).77 911S (NY), 71E (France/Corsica), 66-912 ( France), 1970 914X (Wisconsin) 76 911S roller..off to Florida/Germany RGruppe #669 http://www.x-faktory.com/ |
New-ish 911SC Targa Owner
I purchased a VW vr6 idle control valve but never installed it. You would have to figure out how to plumb it in to your vacuum manifold (my best guess).
This is what it looks like: ![]() You could also install a hand throttle that would essentially crack the throttles open slightly. This was how Porsche handled idle control before CIS. Do throttle by wire setups usually have a separate idle control valve or do they use the throttle motor to allow extra airflow?
'83 Targa 300k w/ freshened 3.0 with 930/52 case# 6770540 ARP and Raceware hardware - AEM Infinity 506, Triumph T595 ITBs, B&B headers, Dynomax muff, Fidanza FW, Alum PP-203whp Last edited by pampadori; 01-17-2020 at 05:09 AM.. |
That's a good question. I do not think AEM has the functionality for the throttle-by-wire to do anything other than control the throttle inputs as performed by ones foot. Tunability for idle based on temps etc would be nice.
No physical quantity completely explains its own existence |
For those with CIS, is there any other way of adapting these manifolds to the intake port? I’d ideally like to not weld the injector notch. I’m currently in process of pulling my CIS for Clays kit. This is what my intake ports look like
![]() Sent from my iPhone using Tapatalk
Josh @joshgrowth |
JP,
Yes, typically phenolic spacers/insulators, that are shaped to block the CIS injector notch are used. I get these from PMO. regards, al
kinda slow
I’ve just been blipping the throttle but it’s not very elegant, and I often blip a little much and not a big fan of 3K RPM engine starts, lol |
However, if you do not have allready bought a MS box that can handle TPS and idle control - well, then you have to dust off those soldering skills. If you're a DIY guy, but not comfortable with eletronics, then I would recommend a 'backdate' hand throttle installation. Easy and works. Or buy an updated MS box or AEM
kinda slow
I’ve got Microsquirt and EFI Source sells a stepper idle control module that I’m looking at, and at this point I’m just trying to understand the mechanics of it all. I’m not opposed to doing a hand throttle, but I kinda just want to get it to a point that I can just get in, turn the key, and go.
mister Nux. How do I backdate a hand throttle installation. I have one now using a 924 water heater valve to bleed in air below throttle housing but after converting to ITBs that will no longer work. So what exactly will it take to get a mechanical hand throttle ? I assume it will apply throttle, as in physically give gas
80SC (ex California) |
Same here. As previously stated it sounds like some version of megasquirt can accomplish the TPS. I'd think the TPS built into the end of the Speed Triples could satisfy this for the ECU? Maybe not?
Josh @joshgrowth |
kinda slow
What EFI you planning to run? |
Options for cold idle control: 1. Drive by wire setup, ECU controls throttle bodies via actuator to be cracked up during cold start - Most of us don't have this option with our ITB setups 2. Backdate' hand throttle - manually holding the ITB's open with additional linkage (in addition to the foot throttle linkage) 3. Idle control valve controlled by AEM/Megasquirt. This is basically creating a controlled vacuum leak to raise the idle without changing the throttle position or opening the throttle bodies. 4. Hold throttle open with foot pedal for 20-30 seconds until engine warms up and holds idle. I'm in Houston and option 4 works well for me, cold starts aren't really an issue so i've never needed additional measures. |
Triumph ITB - AEM Infinity Project
Gotchya. That clears the air. I’m leaning towards option 3 as we have some chilly fall days in WI. Is a sensor needed for this? Or can Megasquirt, the plan here, simply control that? EDIT..read above posts about the VR6 idle control valve As for TPS, I’m gathering that this is the little black sensor with two torx screws on the ends of the ITB grouping? I noticed in some of your images Clay, that it looks like you have two installed? One in the rear on the ITBs covering cylinders 4-6, which looks like it’s the one that’s wired? And then an additional in the front, not wired, on the ITB grouping covering cylinders 1-3.
Josh @joshgrowth Last edited by jpgroth; 01-23-2020 at 07:57 PM.. |
The main idle base position table is based on temps and can also flare the initial start to help assist starting in colder temperatures.
-Jayson 1976 911S Signature Edition - 3.2SSt (JE 98mm 9.5:1 pistons, 964 Cams, Carrillo Rods, ARP Head Studs, AASCO Valvetrain, 3.2 Carrera Manifold, ID725's, B&B Headers, TS HyperGate45 Gen V, TS RacePort, BW S360, AEM Infinity 506, E85) IG: Signature_911 |
78 911SC Targa, GP White Last edited by theenico; 01-24-2020 at 08:01 AM.. |
Isn’t it possible to control idle by ignition timing? By creating a “V” in the table, where you by altering the ignition timing force the idle towards the bottom of the V?
Sent from my iPhone using Tapatalk |
kinda slow
It’s not perfect and bounces back and forth a couple minutes if I don’t drive it immediately, but it does work in lieu of a better solution. Those in warmer weather probably don’t need it, if they just give it some gas for a few seconds on start. |
Sent from my HD1907 using Tapatalk
Current Garage: VW Rallye Golf, 820whp VW r32, TDI Touareg |
Have any of you managed to keep AC somehow?
Instagram @everythingcrafted Day Job - Crafted Wealth www.craftedwealthmanagement.com |
