LinkBack Thread Tools Rating: Thread Rating: 3 votes, 5.00 average.
Merry Christmas guys and gals
Old 12-25-2016, 10:37 AM
Bit Meister
Pehlen's Avatar
Great pic, great looking car.
Old 12-25-2016, 05:30 PM
al lkosmal's Avatar
looking good clay..merry xmas.
RGruppe #669
http://www.x-faktory.com/
Old 12-25-2016, 05:48 PM
Super impressive project Clay! Those manifolds are a thing of beauty and your execution is just incredible!
Ive been debating building manifolds for the Triumph ITBs as well. Yours look great and would save a great deal of time.
Does anyone feel there any issue with the lengths of the two outside runners compared to the center one?
2007 911 Turbo 6-speed, 1984 911 Carrera, 1974 911S, 75 914-6 conversion/project, 2007 Mercedes SL63 AMG, Coyote Powered FFR Cobra
Old 12-25-2016, 09:23 PM
911SC Tinkerer
merlinfe's Avatar
If anyone does have a problem, they also have a problem with Weber Manifolds, and Zeniths, and PMOs. Pretty much all the same proven design.
-Steve
-'83 911SC Coupe
SSIs, Dansk GT3, EFI ITB, Instagram: @ Zinnmetallic_sc
Old 12-26-2016, 04:43 AM
Always Be Fixing Cars
Very nice work. Can I ask why you are using weatheproof type connectors - is the new fuse panel inside or outside the cabin?
'91 964 C4 - New Daily
'73 Alfa GTV - 90% done 50% to go
'65 912 - Welding in process
Old 12-27-2016, 03:38 PM
The fuse panel is in the cabin and the bussman panel comes with weatherproof connectors so I got more for the other plugs as they used the same terminals and tools. I ordered a bunch for other projects. They are not required.
Old 12-30-2016, 01:47 PM
You get this rig on the dyno yet? What are the other specs for this little powertrain? Love the work!
No physical quantity completely explains its own existence
Old 01-06-2017, 05:16 AM
Brando
quattrorunner's Avatar
I love your car....I really love it so much I feel like I need to go smack something...what does that mean? Am I ok?
Turbo powa!
1977 911s. it's cool
Old 01-06-2017, 08:46 AM
Life moves pretty fast.
quint22cp's Avatar
-Steve
Hi Merlin,
This is exactly what I have been obsessing about when I set out to do my Triumph ITB conversion. From the pic you can see that I chose to have the straightest possible ports and also reasonably short so that the injectors still hit the back of the valve.
The heavy looking aluminium plate serves two purposes, it keeps everything rigid and it is internally drilled for brake vacuum and fuel regulator vacuum take offs. I intend to machine some of it away to lighten it later on.
I am currently working on the linkage between the ITBs.
Great work Clay you have been an inspiration to me to get mine finished. Look forward to another instalment.
Pete
Twin plugging, you know it makes sense
Old 01-19-2017, 09:33 AM
al lkosmal's Avatar
ITBs
Pete,
Interesting approach regarding the adaptor plate. I also designed an adaptor plate to mate the Triumph ITBs to Weber manifolds..........similar to your approach, but not a straight shot. Also, I just used the vacuum ports built into the Triumph throttle bodies.
Also, you might want to research the effects of runner length........basically short runner length is good for top end power....long runner length for low end power........I have some reference material that i used when I designed my EFI kit......if i can locate it I'll post it....but googling will likely find good info.
regards,
al
RGruppe #669
Old 01-19-2017, 10:50 AM
quint22cp's Avatar
Hi Al,
Interesting, there must be more Triumph ITBs on Porsche's than there are on Triumph motorcycles, everyone has got one or should that be 6.
I know what you're saying regarding runner length, I am aiming to use long trumpets atop the ITBs for a ram effect. The vac' ports in the Triumph bodies will be used for the idle valve connection as they were on the original motorcycle. What injectors are you using ?
I am going to measure the Triumph ones to see what they will flow. I think I need somewhere around 28 - 30 lb.
I must admit I got a bit obsessed about the straight runners. My thoughts were that on the original motorcycle they were a straight shot and the injectors were close to the valves as in the Porsche manifold. It sort of evolved from what you have at your disposal. When I started this project (some years ago) I didn't have 3D printing facilities as, Clay did, but where I was working at the time they had full workshop facilities and some excellent aluminium welders. Hence the fabricated approach.
Reading through Clay's project has given me the kick up the ar*e to get this project finished and on the car before summer.
I am currently working on the linkage between the ITBs, I have managed to come up with a simple solution using the original Triumph parts and a few other odd bits off ebay. I should have this working tomorrow so I will post another pic.
Pete
Old 01-19-2017, 12:49 PM
Originally Posted by quint22cp View Post
Great work Clay you have been an inspiration to me to get mine finished. Look forward to another installment.
Thanks!
Pete
I've been thinking about trying out a center push/pull linkage setup off the Triumph linkage to gain a little more clearance on the air filters, it's tight now there's limited room for adjustment. I really just need to play with it more. Feel free to share what you've come up with.
Old 02-06-2017, 11:16 AM
al lkosmal's Avatar
Triumph injectors
Pete,
Here is a list of Triumph injector specs.
regards,
al
RGruppe #669
Old 02-06-2017, 11:54 AM
quint22cp's Avatar
ITBs linked together
Hi Clay,
Here's a pic with the ITBs linked together. I used a piece of brass tubing to bridge between the spindles of one ITB to the next and then filed out the original Triumph parts to fit over the tube. I then brazed it all together, needs cleaning and painting (maybe zinc plating) but it works well and I have now done all 6 ITBs. Not sure what to do about ram pipes and air filters yet. I saw how you did it with the Triumph rubber parts and that maybe the way I go. Also thinking about making something up in plastic (i.e. like 993) or how about sand casting some trumpets and machining these up. Lots of ideas still working on it.
I have decided to stick with the original Triumph methods and I'm going operate both banks of ITBs with cables to a common crank. I looked at all those ball joints and linkages and thought "looks good but that's a lot to adjust and cables are just so much cleaner".
Thanks for the injector table Al.
I have 6 of the 1240891, I flow checked them and they will do 300cc/min (30lbs) if I nudge the fuel pressure up to 45psi. They spray really well with good atomization much better than my current ones at 36psi. As the injector pitch is still standard I going to use the original Porsche fuel rails bolted to the Triumph fuel rail bracket.
Regards Pete
Old 02-14-2017, 07:11 AM
Eng-o-neer
Tremelune's Avatar
I'm surprised there isn't a bolt-on ITB/EFI kit for these cars yet. If it was even remotely reasonable in cost (which might not be too hard to accomplish, based on the price of stock parts), I think they'd wind up on a significant portion of these motors.
Old 02-14-2017, 07:23 AM
Ryan H's Avatar
Al's (X-Faktor) kit is bolt-on and he's always around if you need support.
I think there are a bunch of ITB cars being built as we speak. I am one of them.
2007 GT3
1982 911SC
1998 Integra Type R
Old 02-14-2017, 07:27 AM
Eng-o-neer
Tremelune's Avatar
EFI Kit S3-EFI-001
Nice, thanks!
What, no 3.6-3.8??
Old 02-14-2017, 07:33 AM
Ryan H's Avatar
EFI Kit S3-EFI-001
Nice, thanks!
What, no 3.6-3.8??
Those 3.6 and 3.8 guys are are too busy going to cars and coffee
2007 GT3
1982 911SC
1998 Integra Type R
Old 02-14-2017, 07:42 AM
al lkosmal's Avatar
The Triumph t-bodies are approx 42mm. For larger engines I typically use larger t-bodies from PMO...and i am currently working with RHD (Austrailian company) to bring their EFI products into the 911 EFI world. They currently have 40-45mm t-bodies and are working on larger sizes. These should be on my website soon. I'm in the middle of the design review for the 1st beta test units, as we speak........stay tuned.
regards,
al
RGruppe #669
Old 02-14-2017, 07:51 AM
