Front Strut removal
My shocks were junk, so I bought some replacements from hour host.
I found this on rennlist: Easier way for front strut removal on 85 - Rennlist Discussion Forums Wouldn't removing the lower control arm mean I'd have to get an alignment? Besides it was done on an S4, not sure if it will work on my 84. Right now I have it apart and I was trying to see if I could slide the strut out but no luck. The WSM suggests to remove the upper control arm. I've had it bathing in PBBlaster for the last 24 hours and It's not looking promising. Anyone have any alternate methods for removing a front strut? I was hoping to bang it out this weekend. Thanks -Dan
1979 Porsche 911 Black on Black widebody 3.2 - SOLD 2015 Jeep Wrangler Sport Unlimited - White 1984 Porsche 928s Black on Black - SOLD |
I have had my front shocks out recently, 1982 model,
I found it quite easy to undo the two nuts either side in the engine bay that hold the UPPER arm, 3 nuts on top of the tower, bolt through the eye of the strut to the lower arm, pull the upper arm out into the wheel well , leave it connected to the hub, with a little juggling strut drops down and out.easy.
'82 928,2002 4.3 lexus quad cam VVTI V8,5 spd Auto.(at the front)BorgWarner 3.08/1 LSD-at the back-Weisach retained,Transaxle gone.Borla exhaust,XSchops Cayenne big brakes front ,968 front brakes rear.Mk4Supra m/s & servo. Alloy rad,1380kgs(3036 lbs(53%F/47%R))
Dan,
I've replaced shocks on quite a few 928s and have always removed the lower control arm. (I just replaced all four shocks on a friend's '85 last Thursday) Unless you change the ride height, the suspension will bolt right back in the same position, so no re-alignment is necessary. On '86 and older models, it is necessary to unbolt the suspension and raise the A arm to just above horizontal and "screw" the coils of the spring through the A arm from the bottom. At least, that's the way I do it.
John Curry (Drift King) 928OC member Grand Prix White 1994 GTS AT (The GTS) Black 1989 GT (The GT) and Cobalt Blue 1989 S4 AT (The Blue Car) 1986 Euro AT Indishrot 1984 Euro S AT (The Stepson) and Black Metallic 1984 Euro S 5 speed (The Schwartz) |
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior 1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
