Interesting 930 basket case
Thought this was a interesting 930.
https://m.ebay.com/itm/1978-Porsche-930/152802323714?hash=item2393ba6d02:gqoAAOSwnCFaGXQ i
There is a 79 930 basket case on pelican parts as well.
http://9309700485earlyturbo.wordpress.com
Old 11-27-2017, 04:29 AM
Registered Minimalist
75 911s's Avatar
Doesn't look like a basket case at all. Just partially disassembled for paint. I wonder what the reserve is? Should go in the 70s at the least. Paint for 25k and you have a 170k 930.
Duane / IG: @duanewik / Youtube Channel: Wik's Garage
Check out my 75 and 77 911S build threads
Old 11-27-2017, 05:24 AM
gearhead
Definitely not a basket case. That car is $20k from being an excellent driver.
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 11-27-2017, 05:54 AM
I’m thinking closer to $50,000..
This 930 is needing at least 150 hours of work. 150 x $200 a hour is $30,000 in labor alone.
At least $5000 in misc parts here..
GUARANTEED
Old 11-27-2017, 06:02 AM
gearhead
GUARANTEED
Your numbers are always biased by the idea that we are taking a car up to a 1 or 2. An excellent DRIVER is a condition 3 car.
1974 914 Bumble Bee
2009 Outback XT
Old 11-27-2017, 06:09 AM
speednme1's Avatar
GUARANTEED
I must admit I agree with you. Unless you're doing the work yourself it will easily past $50k....motor alone will be $15-25k, suspension will be another $5-7k, tires,whees(refurbishment) and brakes (refurbished calipers) $3-4K, transmission rebuilt..if needed..$4k, interior cleanup-refurbishment $3-4K, paint $10-15k, misc-$5k of course your demographics will play a role in all this. I hate to say it but many shops ideology is that the value of the car plays a role in the cost of the repairs, which I think is wrong but I don't own a shop.
Rey....77 930 "the Mistress"
Old 11-27-2017, 06:59 AM
gearhead
Why are you rebuilding the engine, gearbox and suspension/brakes?
Plus, I don't know where you guys are paying $200/hr in labor, but you are getting ape raped.
1974 914 Bumble Bee
2009 Outback XT
Old 11-27-2017, 07:41 AM
Preferred pronoun:Maestro
Norm K's Avatar
Operative statement above is "Unless you're doing the work yourself". For a solid DIYer the number should be far less than "easily past $50K".
This is why many of us DIY...
$15-$25K to refresh an engine with only fifty-some-thousand miles? Unless the long time owner absolutely abused and neglected this car the bottom end is probably pristine and in need of pretty much nothing, and if the seller is to be believed, the jugs and pistons have less than 30K miles on them so they're probably in fine shape as well. Pull the engine, re-seal as necessary and it'll very likely be good to go. Unless you run into something unexpected, you'll be in the refresh many, many thousands less than your estimate above.
The same is true for your suspension estimate and probably for your interior number as well. Wheels could certainly get up there, depending on your taste. Your gearbox number is in the ballpark, though you were wise to insert your "if needed" qualifier, as I'd wager it's fine - again, given the reported mileage.
Interestingly, your body and paint estimate actually seems to be a bit on the low side. Now, I'm not suggesting you can't get a quality job for $10-$15K (irrespective of what you might have read in the JE thread) but given that you aimed so high on the other items I'd have expected you to throw out a number in the $30-$40K range.
I think a DIY buyer who just wants a beautiful 930 he can drive and enjoy could come pretty close to Matt's $20K estimate - the most likely wild card being the cost of body and paint.
When in doubt, use overwhelming force.
Old 11-27-2017, 07:50 AM
gearhead
^exactly.
1974 914 Bumble Bee
2009 Outback XT
Old 11-27-2017, 08:10 AM
Cool project car for an experienced Porsche owner and hobbyist. Good paint and reassembly and you're driving.
The head studs are done. The interior would clean up just fine. Black is the easiest to rejuvenate and look good. The suspension could be freshened up with new rubber and shocks at a later date. Transmission. Well probably needs freshening, but you can drive it for quite a while with worn syncros. Trust me. You just need to learn to shift better.
I wonder what the reserve is? I would not pay over $50k. Like Matt said, $20k and I'd have a clean driver with new paint. Too bad it's Gold.
Derrick
Old 11-27-2017, 09:53 AM
shlobeck's Avatar
Everyone is making speculations and determinations on different levels of restoration and reconditioning. This as we know is very slippery slope. Assuming the car runs, very little needs to be done for it to become a “driver,” what ever the hell that means. Who ever buys the car better know what they’re getting themselves into, even low mileage, unmolested cars have issues and need maintenance and money. In its current conditions I would either “restore” it completely or just reassemble and drive it. Piece milling projects can be the biggest waste of a money. Labor hours vary greatly depending on the shop and the quality of work. If you’re looking for a ‘deal’ then don’t bother restoring/reconditioning the car.
Old 11-27-2017, 10:04 AM
specialtyoneinc's Avatar
Hard to put a value over $50k on that car. It has obviously been sitting and it will take $$$ to get it sorted mechanically plus all the cosmetic work needed to turn it to a nice driver.
Old 11-27-2017, 11:28 AM
What's wrong with gold?
Old 11-27-2017, 12:41 PM
Mighty Meatlocker Turbo
Rawknees'Turbo's Avatar
Ha ha!
Old 11-27-2017, 02:05 PM
speednme1's Avatar
The car has been sitting since 1995. That's 22 years. That engine will need to be removed and at a minimum a top end would be warranted. I've been down that road and would advise anyone to have a sizeable flexible budget. Things that one would never give a second thought about will need replacement or refurbishment.
I remember contacting a member here who has a restoration paint shop. I asked what a windows out bare metal repaint would cost. He quoted me $35K plus gaskets for the glass. His work looks top notch. I don't (like most of the guys here) have a Godfather in the business, so my cost is all retail. Shops charge about $130 hr plus any additional cost (i.e coffee breaks, bathroom breaks, chit chatting, Arse scratching..etc..etc)...so yea it would be best getting into a car like the OP listed with an open mind...and wallet.
Old 11-27-2017, 02:30 PM
gearhead
I'm not spending that on a driver. I'd spend $10k on paint and the other $10k is the rest. I'd just be putting the car back together cleanly to drive it. I would do about half the labor myself and pay someone else to do the heavy lifting.
Restoration guys call it a basketcase. Driver guys call it a project. $75k restores this car. $20k gets it on it's feet. It's just a matter of having a different end goal. I see a run of the mill late 70's 930. It's not a collectible to me, even if a restored or preserved one is a six figure car.
1974 914 Bumble Bee
2009 Outback XT
Old 11-27-2017, 02:37 PM
sugarwood's Avatar
Damn, that was a tough ad to read.
Hope it goes to a good home.
1986 Bosch Icon Wipers coupe.
Old 11-27-2017, 02:59 PM
You'll need $10k to make the engine perform Mountain Man.
Headers $ 2,500.00
WG $600.00
Turbo and Misc $3,000.00
Intercooler $ 2,000.00
Injectors, Fittings, Ect. $1,300.00
Laask WUR $500.00
But you should be 380-400HP to the wheels
Nothing. It's just not for me.
But then again I have a Guards Red Porsche, So my input is worthless
Derrick
Old 11-27-2017, 03:08 PM
Lol They made 471 of the these.. 78 930 US spec.
471
How many remain today?
Old 11-27-2017, 03:11 PM
Norm K's Avatar
471
And therein lies the beauty of a (nice) twenty-thousand-dollar driver-level refresh and repaint on a car like this one. A guy could buy, freshen and actually drive (you know, enjoy?) this car for a few years then sell it with 60-70K miles on it to the guy who'll pay someone else to perform a full on restoration and then probably never drive it ... and likely make money in the process.
Of course, if there's a stupidly high reserve on it then all bets are off.
_
Old 11-27-2017, 03:19 PM
