Thought this write-up deserved a thread of its own, for anyone who's considering this path.
I picked up the car last night and I must say, it's a totally transformed BEAST now ![]() The pre-boost torque and drivability with the GSF headers & GT35R BB turbo is amazing. This turbo is a MONSTER guys When it spools, it whistles VERY loudly, almost to the point of scaring me from applying further throttle ![]() The last few days have been quite wet down here, so I haven't really had a chance to get a feel for what this new setup can do, but my initial impressions are that it will meet and probably exceed all my expectations. I'm not too sure about the SPEC Stage3+ clutch as yet. It's new, so I guess it needs proper breaking in, but I'm not very familiar, or use to, the on/off feel of this clutch. I'll give it a few months and see how it goes. The Magnaflow single out muffler sounds great. Not TOO loud and not too quiet. Again, I haven't applied full throttle yet to experience the whole system, but I like the sound of the Magnaflow and the build quality and welds are of a very high quality. I was quite surprised that the GT2 EVO CAMs don't sound as lumpy with a proper header setup & the GT35R. The older K27HF and factory heat exchangers made the engine idle quite lumpy, but now it's very smooth. Probably because of the more efficient exhaust flow and split/divided housing on the new turbo?!? I can't wait for some dry weather this coming weekend so I can experience this new configuration completely ![]() I'll get & post some pics when the weather dries up ![]() P.S: I'm not even running an optimum tune with the Proto Motronic Stage3 CHIP. Once I go MAP sensing, it'll compliment the setup even further. Oh, another cool thing is you can hear the compressor still spinning after the engine is turned off
Merv '89 911 Turbo Cab Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
Congrats!!!! It is certainly a great feeling when everything works out, or better than what you expect
![]() Are you running with a 3.4 set up? Are you EFI now? What BOV are you using - kinda interesting that you can hear the turbo when you shut off
87 930 K27HFS/B&B/Twin-Plug... Megasquirted
![]() My setup is an aftermarket turbocharged Carrera motor, with 930 P&C's, GT2-EVO CAMs, ARP fasteners, racing valve springs, titanium retainers, turbo spec inlet/exhaust valves, C2T head gaskets, full bay IC, twin plugged heads, OEM Motronics with Protomotive software & FPR. BOV is a TiAL 50mm, W/gate is a TiAL 46mm unit. Yeh, I can hear the compressor winding down after a shut-off, through the air cleaner. Probably spins down for a minute or so
We wait with anticipation. Glad you finally committed to a route and achieved your expectations
Very nice Merv, and yet my misguided path continues....ever since some deal fell through with a nice Australian gentleman in a bolt on setup.
Luke S. 72 RS spirit 2.7mfi, 73 3.2 Hotrod on steelies, 76 993 3.3efi TT, 86 trackrat, 91 C4s widebody,02 OLA winning 6GT2, 07 997TT, 72 914 v8,03 900 rwhp 996TT |
![]() My only gripe is with the SPEC clutch... that thing is a b!tch to engage smoothly, but I'm getting use to it, and I hope it improves as it gets bedded in ![]() Are you still going down the TT path? My Proto TT kit is still available mate
). I bascially connect a K&N directly off the turbo inlet and I still can't hear it wind down when I shut off the car; though I do always idle for a minute or so before I shut her off, so maybe the turbo had spun down by then? BTW - do keep us posted when you have a chance to truly test her capability
Remember guys, he is running a Garrett ball bearing turbo - it is the ball bearings you hear after shutdown. They do sound cool.
JP
JP 86 930/4 tribute beasty 81 sc beach beater ‘55 Belair ‘40 Ford pickup |
Yes, Merv still thinking TT. Already have too many parts at this point to go Protomotive and I ended up with a 3.0 base at this point and Megasquirt. Decision are snail size and whether to go to the trouble and cool factor of ITB's or just slap on a Carrera intake (both in the garage, don't tell wife
Greg |
UPDATE: I tried to test out this new setup on the weekend and had a couple issues.
1. First time I tried to cane her, the vacuum line blew off the fuel pressure regulator ![]() 2. Once I tracked THAT down and fixed it, took her for another spin and found that when boost kicks in hard, I'm experiencing ignition break-down ![]() Time to fit that Crane HI-6 ignition system back in there
Brando
Turn the boost down a notch.
Turbo powa! 1977 911s. it's cool |
Yeh I could, but that'd mean I'd have to go inside the w/gate and remove one of the springs (it has a 0.8bar + 0.3bar spring in it).
Probably just as much effort to install the Crane unit and leave it at 1.1bar.
As I said before, I firmly believe that removing 0.3 bar spring is very prudent thing to do. You can raise the boost from 0.8 by other means. You might run into trouble on firm 1.1 bar if it's really warm outside and you hit a batch of bad gas.
Thank you for your time, |
Hi Beep! Interestingly, this morning was quite cool and I gave her a bit of throttle. Seems like the wastegate was supplied with a 1.0bar spring. My telltale boost guage shows it pinned right at @ 1.0bar and I got no hesitation up top. What I may have experienced on the weekend was possibly due to the warmer weather
![]() Either way, I'm typically seeing full boost by 3K on a pretty crude tune, so I'm happy with the end result. I can't wait to go standalone EMS and twin plugs now, to further improve on an already great setup. I highly recommend the GT35R to anyone considering an alternate path... Heck, I'd be willing to try the GT30R for high performance street. I think the GT30R would be a seriously fun street turbo, seeing that the GT35R provides this level of drivability and responsiveness.
Merv, full boost at 3k? How much boost and what size hotside? Is it a t3 or t4 hotside. Hmm, that sounds like some pretty quick spool! That has me considering selling my Billet Design Marco Manzie headers and going with the GSF ones as I'm no longer interested in going the high hp dyno queen route.
YUP! 1bar mate!
From 2.5k, boost rises aggressively and you get shoved back pretty hard Pulls all the way to redline, so the power band is very fat. Pulls like a freight train from very low and it's totally transformed the drivability of the car.I went with the 0.78 A/R, divided inlet T3 turbine housing, to suit the GSF headers. It has a 3" V-band discharge too. If the GT35R can spool this quick on such a crude tune (I'm just using a generic Protomotive Stage3 CHIP), I'd be interested in knowing how the GT30R compares If you aren't after BIG HP numbers, but ultimate streetability & response, I'd say go for the GT30R ![]() I like my car like this though. It's a blast to drive and with the top down, the turbo sounds amazing when it spools.
Merv ,how much power is the car making ?
10.76@139-1/4 mile 0-1 mile 193MPH I Love to Shine Cars
I would also like to know how much power it's making. Wow, I didn't think a gt35r would be spooling that quick!
Haven't had the opportunity to dyno it yet. I've left the boost at 1.0bar for now, whilst I break things in, but I'm hoping to get it onto a dyno shoon to verify the A/F's and RWHP figures @ 1.25bar.
Mind you, I'm not really building a big HP dyno queen, but my goal of building a quick street turbo has been reached I'm pretty happy with the end results.My next phase will be to go complete stand-alone engine management for even better response and drivability. I'll post dyno sheet as soon as I've had it done.
I was out tuning the EBC last night whilst it was a nice cool evening.
The B (or max) setting on the AVC-R has been set to nail the boost right @ 1.25bar. At this setting, it's insanely quick. The tach needle swings to redline THAT fast in all gears, it's very difficult to keep focused on the road and watch your RPM's at the same time. Once on boost, this turbo doesn't let up and it's quite a task to choose the right shift point before hitting the limiter. I have a whole new level of respect for you guys who drag race your cars with monstrous HP ![]() I've set my boost levels accordingly: LOW = 1.0bar MED = 1.1bar HIGH = 1.25bar (tyre shredding in 3rd gear )Hopefully next week I can book in some dyno time to verify all my A/F's are in check, at each setting. The GT2 EVO CAMs are also very aggressive and pins you back when they "kick in"... I'm in love again, with this car
