Imagine Auto RSR Coilover Setup
A few years ago I picked up Stephen's RSR setup for my 930. Just found out during a tech inspection that one of my front strut inserts needs to be replaced. Do any of you have the same setup and know the part number? My concern is that they were likely custom valved and am unsure how to track down the correct, matching, replacement insert.
Thanks!
Rob Montgomery
'88 Blk/Blk 930 ('Lucy') - Not Stock & Not Running
Old 04-22-2010, 09:33 AM
A930Rocket's Avatar
Have you tried to contact/PM Stephan? I know he's out of biz, but...
Old 04-22-2010, 10:25 AM
I did... sent an email yesterday without a response. Somewhat impatient only because I'm supposed to be at the track next Friday.
Rob Montgomery
Old 04-22-2010, 10:33 AM
89turbocabmike's Avatar
Rob, if they are custom-valved your best bet is going to be to send them to Bilstein in Poway (San Diego) or you might chat up Jae Lee at Mirage Intl. Maybe he can get it done quicker as he does a lot of work with Bilstein. Mine were custom valved by Jae/Bilstein but in customary fashion the custom valving specs stamped into the housing have been ground off.
Old 04-22-2010, 11:34 AM
Rob send me pictures of the strut, we used a couple different options . I was the lead tech there. dockarl at wilen.us
Doc Wilen
86 951
Old 04-22-2010, 11:36 AM
Thanks Doc... just spoke with the shop and it actually now looks as though it isn't the insert itself but the internal 'sleeve' (probably not the technical term). Insert and houseing apparently both look good.
Rob Montgomery
Old 04-22-2010, 11:46 AM
Infidel
JBL930's Avatar
All of Imagine Auto's suspension came from Rebel Racing and Tarrett, just get in touch with Clint at Rebel and he'll sort it out for you
Jonathan.
87 930, 993 turbo engine, RS Tuning 520PS/515lbf-ft, Arrow Rods, ARP hardware, Solid lifters, G50-50, RS Flywheel, 890nm Sachs clutch, RSR coil overs all round, 993 C4 calipers front, 930 fronts on the rear, Ruf Speedlines.....
Old 540 BMW, XB12S Modified, for being a total hooligan
Old 04-22-2010, 12:15 PM
Some at the end came from rebel, none came from tarrett. Most of the early stuff came from bilstein.
Doc Wilen
86 951
Old 04-22-2010, 12:16 PM
Infidel
JBL930's Avatar
Some of the parts had Tarrett stickers on, i guess Rebel must get some stuff from Tarrett then, and they came in that way. I bought my RSR stuff through IA too, so was just saying
Jonathan.
Old 04-22-2010, 12:19 PM
Lol, interesting i never saw those stickers. Wouldn't surprise me. There is always 4 middlemen in the porsche business.
Doc Wilen
86 951
Old 04-22-2010, 12:21 PM
Max Sluiter
Flieger's Avatar
Clint sells Ira's stuff like sway bars and monoballs. The struts and coil-over stuff he does himself to the best of my knowledge.
Old 04-22-2010, 06:35 PM
Blaine Sellie's Avatar
I bought the same setup from Stephen.......it came from Clint at Rebel. I would call him and let him know about the problem....certainly he is capable of resolving the issue.
Blaine
1988 Porsche 930 Factory Slantnose
2011 Porsche Panamera Twin Turbo
1974 Porsche 914 2.0 Phoenix Red
1965 Shelby Cobra Replica- 428FE
2007 Mercedes SL55 P30 Package
Old 04-22-2010, 07:42 PM
Jeff Alton's Avatar
Yep, I dont thing IA made too much of their own stuff..... Alot of Ira's stuff (tarett) is re branded or ripped off.
Cheers
www.turn3autosport.com
Old 04-22-2010, 07:45 PM
Max Sluiter
Flieger's Avatar
I'll ask Clint when I see him tomorrow if you send me an email with your name and a little more specific desdription of your problem.
Old 04-22-2010, 09:08 PM
I can't remember the name but there is a shock house at Infineon that could rebuild it for you. That is the best route since they replace seals + shafts but will retain the valving.
Old 04-23-2010, 01:46 AM
Max Sluiter
Flieger's Avatar
I talked to Clint today. I told him your issue and asked him to email you. He thinks what the mechanic is talking about are the "linear bushings" which are a split-sleeve like piece of metal with Teflon on the inside.
Clint has the bushings and offers both a rebuilding and revalving service. The price is better than through Bilstein- Bilstein buys their parts from a third-party supplier.
Let me know if you do not hear from him by Monday evening.
Can you post a photo of the strut to see if it is, in fact, sourced originally from RSR Products?
Old 04-23-2010, 08:58 PM
Thanks... I also just sent Clint's contact info to the shop as well. I'll post a pic once I get it (shop/car are in Chicago and I'm in Cali)
Rob Montgomery
Old 04-26-2010, 12:04 PM
Scottsdale Arizona USA
Porsche Crest
I would suggest James Patrick at Patrick MS. He is likely to have replacement inserts in stock. If not, he has an SSF account who carries several Bilstien valving options. He also stocks the true originals, MODE Monoball camber plates and spring hardware.
Old 04-26-2010, 12:53 PM
