Another 3.4L 930 with EFI
1979 911 SC with a 930 engine transplant, Boxster brakes
Engine rebuilt to 3.4L, ported heads, Carrera manifold, modified Kokeln intercooler, sport cams, B&B headers, Garrett GT35R turbo, and old-school Borla 4-tip muffler Long block brought in for finishing, build a harness and completely wire the supplied EFI, and tune. ![]() ![]() ![]() ![]() 500hp/490tq at the wheels, 1.15bar boost, 91-octane. TurboKraft 3.4L EFI Porsche 930 makes 500hp at wheels, shoots fire out tailpipes - YouTube TurboKraft 3.4L EFI Porsche 930 -- glowing exhaust and shooting fire balls -- 500whp - YouTube
Chris Carroll TurboKraft, Inc. Tel. 480.969.0911 email: info@turbokraft.com http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft Last edited by TurboKraft; 04-19-2013 at 12:59 AM.. Reason: addition |
Wow, beautiful power..very cool Chris..that car looks very unassuming.
Yasin
Ole Skool - wouldn't have it any other way |
Brando
What trans?
Turbo powa! 1977 911s. it's cool |
Very nice. I like the way you are plumbing the air filter in front of the manifold. Are you returning the scavenge pump oil to the breather cover and does it/would it interfere with the air filter? Also, I unwittingly chose to have the bulk of my wiring harness pass through that area so it would likely interfere with the air filter placement. Do you have pictures of how your engine wiring harness with main connectors is laid out?
Also curious about tranny choice, ?LSD, and compression ratio. edit: Ah, I see the throttle body is flipped.
Steve Sapere aude 1983 3.4L 911SC turbo. Sold Last edited by sjf911; 04-19-2013 at 07:33 AM.. |
Looks nice.
You can rotate that Sanden AC compressor clockwise 90 degrees and the mounting ears line up the same to pump mount. Then the AC hoses and charge fittings are on the right side and more out of the way. The AC hoses can then be rerouted behind all the breather hoses going to the oil tank above the right side longitudinal to move them farther out of the way when changing spark plugs or adjusting valves if they are long enough. |
Here's a pic showing the same model AC Sanden compressor mounted 90 degrees clockwise from the one in the above post with the hoses more out of the way on the right side.
Brando
JFairman
Perdy engine. Super clean. Nice
thanx
![]() Here's another pic. You can see that rotating the Sanden AC compressor 90 degrees clockwise would also make more room for a full bay intercooler... if I had one. There is a recirculating piston type blow off valve in the C2 type rubber elbow off the CIS airflow meter housing hosed to the origonal Kokeln blow off valve hose fitting on the back. The extra blue hose you see goes to a second blow off valve under the intercooler that is vented to atmosphere. It has a little stainless steel mesh air filter on it because when decelerating at lower speeds the high intake manifold vacuum opens the blow off valve and being vented to atmosphere it inhales unmetered unfiltered air so an air filter on it keeps dirt from being sucked in.
why 2 bov's?
Because I'm a gadget freak and I wanted to.
I was using the deceleration valve as a second small blow off valve vented to atmosphere. Then I sold it and took that cash and bought a nice looking black anodized chinese made turboXS copy 32mm blow off valve off ebay and mounted it under the intercooler. It works great with 2 of the included shims under the piston spring. It's not needed but it reduces any chance of compressor surge in the turbo when lifting off the throttle quickly while under boost and I like the little woosh sound it makes venting some of the closed throttle turbo boost to atmosphere between boosted upshifts. sorry to hijack the thread with this stuff here... |
Richard 1982 930, K27-7200, Ruf wheels, Leask WUR, Tial WG, RarlyL8 headers & single out muffler, SC cams, TK I/C 2018 GTi, 2020 AMG E53 wagon ski car 2004 BMW R1100S |
Sneaky sneaky. Love it...
Thanks for posting Chris.
Yet another great dyno result:-)
Trond R. 1979 930: Garret GT35r turbo, EFI, carerra intake, Link EMS, custom GT2 cams, 98mm JE P/C, 964 crank (stroker), custom valves & ported (XtremeCylinderHeads) etc..etc.. 1972 914-6 GT replica project 1986 944 Turbo |
Chris, You PM box is fill. Please clear it out. Thanks
1965 911 Vin 1249 Slate Grey 1969 911 Golden Green 2.0 Twin Plug 1971 911 S Gold Metallic. Peter Gregg 1974 911 RS Euro Metallic Blue Gold lettering 1991 Brumos 3.6 Turbo Pikes Peak Zwart Motor |
Nice job and love the flames!
1998 993 C2S Guards Red/Black 1990 964 C2 RWB project car 2016 GT3RS White Daily driver 2018 Lamborghini Performante Gegio Telesto |
| Tags |
| 3.4l , 930 , dyno , efi , turbokraft |
