Member 911 Anonymous
DRACO A5OG's Avatar
Cool Part Trois: 3.4L Build, The Journey
Day 1:
All parts are in!
Crank Shaft:
  • Crank Shaft, Polished, Verified Straight, No Cracks, Oil Pathways Clean and Snout Fixed
  • Rods, Resized (STD), Straightened, Honed and New Wrist Pin Bushings
  • Bolt/Nut kit, ARP M9 Bolt/Nut Kit 40ft lbs
  • Clevite 77 (STD) Bearings, measured (Tab) 1.476MM, (Center) 1.495MM (Non-Tabbed side) 1.476MM, Consistent on all bearings, thicker in the middle as it should be
Notes: ARP M9 Nuts require a 12 point ( Triple Square ) 11MM Socket
Bought this toy to verify my torque settings, works very well considering it is from HF
'85 Carrera Targa
PCA/POC
Old 03-09-2017, 11:46 AM
DRACO A5OG's Avatar
Case Assembly:
Last measuring task:
Ground ( well, I chickened out and had a Pro do it at Vellios $45, Yes I cheated ) and Measured Ring END GAP
Top .017
2nd .022
Oil Retainers .015
Don't worry fellas, the file is for any burrs the shop missed, they didn't
DAY 2:
Oil Pump/IMS with New Bearings & Chains, installed
GT3 STD Bearings, installed
DAY 3-4:
Chamfered, D-side Case thru holes and two behind the Oil Cooler (side tracked, modification needed)
Case Sealed, used Master Henry Schmidt's method of Case Thru tighten without O-rings as not to panic on time but I still needed to tighten the perimeter nuts within the time limit. She is sleeping over night, O-ring with Dow55 Tomorrow.
Used Brand New M8 Oval Lock Nut and M8 Crush Washer for the perimeter.
Test Turned the Crank, All Rods moved freely and drop on their own weight, Wow, Smooth
ARP Head Studs, installed
http://forums.pelicanparts.com/uploads26/IMG_4599_1_1489562389.JPG
Tested Rotation, SUCCESS!
'85 Carrera Targa
PCA/POC
Old 03-09-2017, 11:47 AM
DRACO A5OG's Avatar
Thumbs up
Cylinder, Rings, Piston, Head and Cam Tower Assembly
Had to wait a week for my WISECO RCS09800 true 98MM Ring Compressor Sleeve/Installer, HIGHLY RECOMMENDED!
Day 5
Measured Deck Height, glad EBS spec'd for 3.2 heads so I still have the step, it allowed me to measure deck height easily.
Don't mind the gauge, I dropped it and then stepped on it, also take pic cock eyed the readings
Measured 6 times , OCD like that
Heads torqued down verified flat as the Salt Flats.
Next, Cam Tower, Camshaft, #1 & #4 Rocker prep for Timing
Another tool recommended either the Stomski Wrist Pin install tool or Porsche 964 Wrist Pin installer, you have to mod the side tabs but it works freakin great.
'85 Carrera Targa
PCA/POC
DRACO A5OG's Avatar
Day 6-7
Timing Set, A successful 1.25MM both sides:
She is smiling at me
Proper Tools really is a Must! Thanks again Master KTL!
Weekend Break:
Did some Bling, used Craft's Store Metal Oil Based Paint Pen to paint the Logos on the intake and upper Valve Covers, came out pretty nice
Hot bathed in DishWasher :-P
ASSEMBLY COMPLETE DAY 12-14 ( Actual time 4 months waiting for parts and machine service but working on her, about 2 weeks )
Glad to report, no extra bolts and or nuts. WOO HOO
Next, install and break in, Joy Joy Joy
'85 Carrera Targa
PCA/POC
Old 03-09-2017, 11:48 AM
DRACO A5OG's Avatar
The Break In:
Step 1: Filled with 30 weight SAE Rotella
Step 2: Hand Cranked to insure nothing is binding, Nothing is Binding
Step 3: Cranked with Starter, DME disconnected NO FUEL, Cranked Smoothly and Effortlessly
Step 4: Start, Run at 2000 RPMS for 20 Minutes, check for leaks, DUMP OIL, Change Filter.
Step 5: Refill with 30 Weight, Drive Her for 50 Miles, All RPM ranges and decels, check for leaks, Dump Oil, Change Filter.
Step 6: GO visit Mom in Fresno 600 mile round trip, check for leaks, dump oil, change filter, Put in DELO 400 15W40.
'85 Carrera Targa
PCA/POC
Old 03-09-2017, 11:49 AM
Send a message via Skype™ to kyngfish
Lol
For a second I thought, why does your CS have eyelashes?
1986 Carrera Coupe - 1987 W124 300E - 1999 Land Cruiser 100 - 2021 GLA250
Old 03-09-2017, 11:58 AM
DRACO A5OG's Avatar
'85 Carrera Targa
PCA/POC
Old 03-09-2017, 12:03 PM
KTL KTL is offline
Schleprock
KTL's Avatar
Sweet.............
Kevin L
'86 Carrera "Larry"
Old 03-09-2017, 12:37 PM
Chain fence eating turbo
I would really consider a bolt-stretch gauge for the rodbolts.
Mine were all over the place final torque wise.
Beg, borrow, or steal one.
Our rod bolts are the weak link being smaller IMO.
Old 03-09-2017, 12:58 PM
DRACO A5OG's Avatar
Yeap
Will redo with gauge Master KTL lent me
'85 Carrera Targa
PCA/POC
Old 03-09-2017, 01:01 PM
That's great to hear!
Old 03-09-2017, 01:03 PM
abit off center
cgarr's Avatar
I like the flooring. Just had ours done.
______________________
Craig
G2Performance
Old 03-09-2017, 05:09 PM
DRACO A5OG's Avatar
Verified:
0.0105"
Surprising, for a POS HF unit, but it wasn't typically cheaply priced
'85 Carrera Targa
PCA/POC
Old 03-09-2017, 06:12 PM
You're stretching 10-thou? Forgot it was that much!
Old 03-09-2017, 06:54 PM
DRACO A5OG's Avatar
Yes sir, ARP spec states .0100-.0105" or 40 ft lbs
'85 Carrera Targa
PCA/POC
Old 03-09-2017, 06:59 PM
Under the radar
Trackrash's Avatar
Originally Posted by DRACO A5OG View Post
Reserved for Cylinder, Head and Cam Tower Assembly
Have you figured a way to post a pic when editing?
Gordon
'71 911 Coupe 3,0L outlawed
Old 03-10-2017, 12:23 PM
DRACO A5OG's Avatar
Yeah, Wayne forgot to add that feature on editing. So I just copy from photo bucket and paste
'85 Carrera Targa
PCA/POC
Old 03-10-2017, 12:46 PM
KTL KTL is offline
Schleprock
KTL's Avatar
Gordon & Jim,
I do it this way. Create a new reply, use the picture upload feature and the link/path for the picture is created. Copy those picture path(s) and paste it into the placeholder post you want to edit. Easy way to do this is have two Pelican windows/tabs open at the same time on your 'puter- one for the new reply (doesn't even have to be the actual thread we're on) and one for the editing of the placeholder post. The key is, DO NOT click on the submit button for that new reply which you created for nothing more than uploading pictures.
Make sense?
Kevin L
'86 Carrera "Larry"
Old 03-10-2017, 01:29 PM
DRACO A5OG's Avatar
Lol
Never give up Never surrender
'85 Carrera Targa
PCA/POC
Old 03-10-2017, 01:34 PM
KTL KTL is offline
Schleprock
KTL's Avatar
No commercials, NO MERCY!!!!
https://youtu.be/ipsPgNEmAXI?t=2m28s
Kevin L
'86 Carrera "Larry"
Old 03-10-2017, 01:49 PM
