Member 911 Anonymous
Day 1:
All parts are in! ![]() Crank Shaft:
Notes: ARP M9 Nuts require a 12 point ( Triple Square ) 11MM Socket Bought this toy to verify my torque settings, works very well considering it is from HF
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC Last edited by DRACO A5OG; 03-09-2017 at 12:15 PM.. |
Case Assembly:
Last measuring task: Ground ( well, I chickened out and had a Pro do it at Vellios $45, Yes I cheated ) and Measured Ring END GAP ![]() Top .017 2nd .022 Oil Retainers .015 Don't worry fellas, the file is for any burrs the shop missed, they didn't ![]() DAY 2: Oil Pump/IMS with New Bearings & Chains, installed GT3 STD Bearings, installed DAY 3-4: Chamfered, D-side Case thru holes and two behind the Oil Cooler (side tracked, modification needed) Case Sealed, used Master Henry Schmidt's method of Case Thru tighten without O-rings as not to panic on time but I still needed to tighten the perimeter nuts within the time limit. She is sleeping over night, O-ring with Dow55 Tomorrow. Used Brand New M8 Oval Lock Nut and M8 Crush Washer for the perimeter. Test Turned the Crank, All Rods moved freely and drop on their own weight, Wow, Smooth ![]() ARP Head Studs, installed ![]() http://forums.pelicanparts.com/uploads26/IMG_4599_1_1489562389.JPG Tested Rotation, SUCCESS!
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC Last edited by DRACO A5OG; 03-15-2017 at 12:24 AM.. |
Cylinder, Rings, Piston, Head and Cam Tower Assembly
Had to wait a week for my WISECO RCS09800 true 98MM Ring Compressor Sleeve/Installer, HIGHLY RECOMMENDED! ![]() Day 5 Measured Deck Height, glad EBS spec'd for 3.2 heads so I still have the step, it allowed me to measure deck height easily. Don't mind the gauge, I dropped it and then stepped on it, also take pic cock eyed the readings Measured 6 times , OCD like thatHeads torqued down verified flat as the Salt Flats. Next, Cam Tower, Camshaft, #1 & #4 Rocker prep for Timing ![]() Another tool recommended either the Stomski Wrist Pin install tool or Porsche 964 Wrist Pin installer, you have to mod the side tabs but it works freakin great. ![]()
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC Last edited by DRACO A5OG; 03-23-2017 at 09:50 AM.. |
Day 6-7
Timing Set, A successful 1.25MM both sides: She is smiling at me ![]() Proper Tools really is a Must! Thanks again Master KTL! Weekend Break: Did some Bling, used Craft's Store Metal Oil Based Paint Pen to paint the Logos on the intake and upper Valve Covers, came out pretty nice ![]() Hot bathed in DishWasher :-P ASSEMBLY COMPLETE DAY 12-14 ( Actual time 4 months waiting for parts and machine service but working on her, about 2 weeks ) Glad to report, no extra bolts and or nuts. WOO HOO ![]() Next, install and break in, Joy Joy Joy
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC Last edited by DRACO A5OG; 04-07-2017 at 02:53 AM.. |
The Break In:
Step 1: Filled with 30 weight SAE Rotella Step 2: Hand Cranked to insure nothing is binding, Nothing is Binding ![]() Step 3: Cranked with Starter, DME disconnected NO FUEL, Cranked Smoothly and Effortlessly Step 4: Start, Run at 2000 RPMS for 20 Minutes, check for leaks, DUMP OIL, Change Filter. Step 5: Refill with 30 Weight, Drive Her for 50 Miles, All RPM ranges and decels, check for leaks, Dump Oil, Change Filter. Step 6: GO visit Mom in Fresno 600 mile round trip, check for leaks, dump oil, change filter, Put in DELO 400 15W40.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC Last edited by DRACO A5OG; 04-10-2017 at 12:57 AM.. |
Lol
For a second I thought, why does your CS have eyelashes?
1986 Carrera Coupe - 1987 W124 300E - 1999 Land Cruiser 100 - 2021 GLA250 |
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Schleprock
Sweet.............
Kevin L '86 Carrera "Larry" |
Chain fence eating turbo
I would really consider a bolt-stretch gauge for the rodbolts.
Mine were all over the place final torque wise. Beg, borrow, or steal one. Our rod bolts are the weak link being smaller IMO. |
Yeap
Will redo with gauge Master KTL lent me
That's great to hear!
abit off center
I like the flooring. Just had ours done.
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
Verified:
0.0105" Surprising, for a POS HF unit, but it wasn't typically cheaply priced
You're stretching 10-thou? Forgot it was that much!
Yes sir, ARP spec states .0100-.0105" or 40 ft lbs
Under the radar
Have you figured a way to post a pic when editing?
Yeah, Wayne forgot to add that feature on editing. So I just copy from photo bucket and paste
Schleprock
Gordon & Jim,
I do it this way. Create a new reply, use the picture upload feature and the link/path for the picture is created. Copy those picture path(s) and paste it into the placeholder post you want to edit. Easy way to do this is have two Pelican windows/tabs open at the same time on your 'puter- one for the new reply (doesn't even have to be the actual thread we're on) and one for the editing of the placeholder post. The key is, DO NOT click on the submit button for that new reply which you created for nothing more than uploading pictures. Make sense?
Lol
Never give up Never surrender
Schleprock
