@reimaginedcoachwerks
meanwhile, jose is lapping all of the ancillary parts that have flat surfaces to prevent any leaks.
Old 01-07-2021, 12:28 PM
about to gap the rings. all of the cylinders mic out exactly 98mm.
Old 01-07-2021, 01:37 PM
just finished gapping the rings. the ring grinder is turned off in the pics as obviously i do not want to ruin a ring trying to grind while taking a pic.
Old 01-07-2021, 04:52 PM
to measure the gap i had to use two feeler gauges, a 0.40mm and a 0.04mm for a total of 0.44mm per mahle.
Old 01-07-2021, 05:12 PM
carrillo suggests stretching their rod bolts over torqueing.
Old 01-07-2021, 11:00 PM
so i just realized a vendor did not send the new timing chains. i have the crank ready to drop in. i hope my local dealer has them on the shelf...
Old 01-07-2021, 11:02 PM
great thread. I'm envious of the tools you have!
What was the stretch spec of the bolts you used on the con rods and did you also get a corresponding torque value to compare with the spec sheet they supply?
Old 01-08-2021, 05:05 PM
the minimum tq spec was 40 which i ignore.
the stretch value for the rod bolts we used is 0.005 - 0.0065" per carrillo.
the actual tq value ended up being 55 ish ft lbs
Old 01-08-2021, 05:52 PM
so i had to drive to get the chains from a local supply house today. i just got done getting everything ready to carry on. i like to lay everything out and wash each part as i install them.
Old 01-08-2021, 05:58 PM
i just realized my helper laid the blue orings out that are in the picture. i do not use the blue orings, but in fact go with the viton orings and dc molykote 55.
Old 01-09-2021, 04:50 PM
Cairo94507's Avatar
Loving this build.
'71 914-6 #0372
'17 Macan GTS
Old 01-11-2021, 06:53 AM
Call 911
dkirk's Avatar
Nice to see your great attention to detail. Thanks for this great post - really enjoying it.
Dave Kirk
My Porsche restoreth my soul.
Old 01-11-2021, 04:51 PM
JED
ARCSinAK's Avatar
Master class is in session!
Old 01-11-2021, 11:13 PM
sorry keeping this updated is as much or more time than blueprinting an engine! plus i am in the middle of 2 other restorations on a 964 c4 and 72 911 rsr extra widebody.
Old 01-12-2021, 06:29 PM
Originally Posted by Cairo94507 View Post
Loving this build.
thx!
i can not say that the rest of the shop is as organized as the engine room, but somehow i know where everything is!
Old 01-12-2021, 06:30 PM
such a compliment! i simply try to build every car as if i am going to keep it till my last day.
Old 01-12-2021, 06:31 PM
so i am using the old original headsutds for my dry run to check clearances. i thought to do it both the old school way with modeling clay fully assembled and then take it down to the short block then pull the valve springs and show you the more accurate and faster way.
Old 01-12-2021, 06:34 PM
once the short block is together i assemble each piston into it's respective cylinder. i find this is so much easier to do than trying to install the pistons in the cylinders on the eng, although when i do 996/997/991 i install them in the cylinders already on the engine.
be sure you put the top ring on top with the writing facing up, the second ring has a M and the oil ring is last. they are all 90* apart with the oil gap at the top.
Old 01-12-2021, 06:41 PM
sorry i got a phone call last night then took off for the day.
Old 01-13-2021, 11:17 AM
