964 intake on 3.2?
Any advantage to putting a 964 intake on a 3.2/3.4? Lets say you had one laying around (aluminum) and you saw the adapters in the SRP catalogue......
Jeff
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
PRO Motorsports
Yes.
The Plastic 964 intake is much smoother and more uniform inside. It flows much better. It's also significantly lighter, and won't absorb as much heat and transfer that into the incoming air as the aluminum 3.2 intake will. Oh, and it has a resonance chamber that opens up at, I think, 6300 rpm for a little boost.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer) '72 911T Targa MFI 2.4E spec(Formerly "Scruffy") 2004 GT3 |
Still Doin Time
I just got one. Traded my complete 3.2 set-up to Kevin @GAS motorsports in Cali for a complete plastic 3.6 deal even up. We each paid the shipping. The only additional investment is the adaptors. sssssssssssschweeeet!
Kevin was building a early turbo engine and the SC intake is the solution for the turbo guys going to a more modern EFI over the CIS. I'd highly reccomend it because it solves all the short commings of the SC intake, has a larger throttle body and is much lighter. You will have to fab some linkage
'15 Dodge - 'Dango R/T Hauls groceries and Kinda Hauls *ss '07 Jeep SRT-8 - Hauls groceries and Hauls *ss Sold '85 Guards Red Targa - Almost finished after 17 years '95 Road King w/117ci - No time to ride, see above '77 Sportster Pro-Street Drag Bike w/93ci - Sold |
MBruns for President
SC or Carrera - Carrera, right?
But doesn't the Aluminium 964 intake have the same issues as the aluminium 3.2 Carrera intake as far as uneven flow?
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
Carrera, and the 964 intake I have on the shelf is an aluminum one. I was just thinking out loud, need to do something with the intake.....
Jeff
Indeed all is true 'cept for the resonance flap opening point; thats optimized around 5250-5500 RPM. Remember now, the 3.2 Carrera Motronic isn't wired to actuate those since the OEM alloy doesn't have one. When we do these conversions, we replace the Motronic box with DTA engine management and we can set the resonance flap operation wherever we want.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
Any one want a 964 aluminum intake?
Jeff
PRO Motorsports
I guess I was thinking it would be cool to use the whole 964 DME, but that's cool that you can actuate the solenoid that feeds vacuum to the resonance flap with the engine management system. I think it'd be even cooler to have a button for it! Labeled "nitro-boost!".
![]() Good point, one would need to do some research but thats potentially a good idea. If the 964 DME can be made to work, that will work just dandy with some custom software, of course.
How about the AL 964 intake for a TT 3.2? Yes, no, who would know how to do it? Would I be able to do it?
Regards,
Bernard |
Still Doin Time
I'll use a simple programable ignition box like the MSD with controller. I believe there are a few others devices where they pick up the ignition signal and then you can use rpm 'pills' to have the switch activate any 12v electrical device to work the flap w/o additonal engine management
Sorry to break inn on your thread, but you mentioned
"saw the adapters in the SRP catalogue.." What adaptors ARE THAT ??? And what is "SRP catalouge". I ask since i got a 964 intake system that i want to use on my 3.0L when i'm converting to EFI. And the 964 uses the 3 bolt's intake vs. the 2 bolt's intake manifold on pre 964. I anyone make Efi intake manifold's or the like please let me know.
Steen Andersen 1979' SC Targa. + 2006' Peugeot 206. |
Irrationally exuberant
There are a few places that have a solution.
Smart Racing Products (SRP) has these ![]() Pro Technik (Sam Shalala) sells these: ![]() In Sweden Stigs Garage sells intake adapters that replace the injector block completely. Click on the "RESERVDELAR" button to get to their parts. ![]() -Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
Many thanks.
Sweeden is my neighbour country, and i also miss the intakes with the injector holoders; so i think stig's garages solution is just right for me. Thanks again.
I have a plastic 964 intake for my 3.5 turbo engine. It has been covered in kevlar for strength and Marco Manzie made billet injector blocks on the cnc for me. The center section is a custom aluminum section that houses a very large accufab throttle body. If you need the 2 bolt injector blocks let me know. Here is a pic of the blocks on one of my cylinder heads.
Eric
Erik: Thanks for the offer. But those very nice looking 2 bolt injector blocks look like big $$$. I don't think they are inside my budget. My goal is I expect the intake and efi conversion to be inside $1600 tab. That leaves me approx. $600 to injector block's, the injectors, and all the fuel lines to injectors.
I'm trying to make my conversion on a budget, by using used parts; f.i. the EFI computer i use is home build from a web group (www.vems-group.org), and the 964 plastic intake i have from a guy in Germany for $400, but missing the injector blocks. I went to Stig's Garage and the injector block's is €600 ($700), that's quite a lot. I'm trying to find used original plastic blocks at first, and then use the SRP adapters, or have some made if that pays out. For those interested: My plan is to have the 964 plastic intake and VEMS EFI computer on my 3.0L SC engine for a start. And learn about Engine management and programming. Then the scene is set for later enhancements like 3.2 P&C, high compression, twin ignition, SSI exhaust a.s.o. Happy MotoringRemember i live in a country with 180% TAX on automobiles, so my ´79 was $40K
Steen Andersen 1979' SC Targa. + 2006' Peugeot 206. Last edited by steand; 07-17-2005 at 12:49 AM.. |
Still Doin Time
Now THAT'S a lot-o-tax!!
The injecter blocks marco makes are pretty reasonable. 400 for the plastic intake is a bit much. Usually you can find them in the 175-300 range with everything you need
