Today (hopefully) is my cam tower to head attachment...
So, I plan to use the 1104 Neo, which I believe is recommended. How Much sealant do I need to apply? Is it a matter of applying a small bead to the tower around the bolt holes or does the whole surface need to be "spread" with a thin layer? The below photo I pulled from a screen shot of the Pfixit dvd (which I have watched about 20 times) ![]() |
hi guys
where do you put the curil T between the cylinder and case ? just on the copper gasket ? both side or around the cylinder going inside the case ? thanks for your help |
Try not, Do or Do not
We use Curil T on both sides of the base gasket and on any gasket that may be removed regularly (IE: sump cover gaskets).
The sealant you see on the cylinder spigot is excess wiped from the gasket. Won't hurt but isn't necessary. ![]()
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
Puny Bird
Personally I'm not a fan of Curil T, never fails to leak for me.
I have 2 unopened tubes here both from supertec kits. I'll never use them. ![]() Only place I use RTV is the base shims, If you're a RTV hater you can use something like Elring Dirko....oh wait that's also RTV....or maybe...damn it's RTV again ![]()
'74 Porsche 914, 3.0/6 '72 Porsche 914, 1.7, wife's summer DD '67 Bug, 2600cc T4,'67 Bus, 2.0 T1 Not putting miles on your car is like not having sex with your girlfriend, so she'll be more desirable to her next boyfriend. |
Send them back and I'll give you credit for both tubes.
thanks Henri
will use the Curil T as I asked you, I don't know what kind of grease or perhaps oil I should use with the supertec head stud kit. porsche rebuild manual says to use optimoly HT for the washer and the stud thread (hex nut side). some friends just use oil or dry ? (I don't think so) what's the best solution ? Last edited by florent78; 12-02-2016 at 02:14 PM.. |
It's a formula we've developed over the past 15 years that we've used in our engine for at least 10 year. Over 300,000 test miles. ![]()
Puny Bird
Other person(s) bought the kits.
Also in Canada so cost of shipping would likely be the same as the refund. ![]()
FYI, the blue o-rings supplied in the Victor Reinz kits are silicone rubber. Our host here offers 5 different flavors.
Pelican Parts - European Automotive Parts and Accessories - Porsche • BMW • Mercedes • Volkswagen • Audi • Saab • Volvo • MINI |
Under the radar
Perhaps off topic but.....
What sealant should I use on my transmission gaskets? This leak started suddenly about 2 weeks ago. Trans was rebuilt, by me, about 5 years ago. Lots of autocrosses and DEs since. Nuts are tight. ![]() Thanks,
Member 911 Anonymous
I used the paper gasket plus copper spray on gasket.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
When I rebuilt my transmission everyone recommended paper gaskets with curel t. I have no leaks thus far.
Matt. 83 911SC 85.5 944 NA - Sold |
I used Loctite 574 and no paper gaskets.
Magnus 911 Silver Targa -77, 3.2 -84 with custom ITBs and EFI. 911T Coupe -69, 3.6, G50, "RSR", track day. 924 -79 Rat Rod EFI/Turbo 375whp@1.85bar. 931 -79 under total restoration. |
Under the radar
Thanks.
I am leaning toward curl-t this time around. It's weird, to me, that one week my trans was dry. The next week it starts to leak from the gasket?
Over the years, my method varied depending on specific intent.
In a race transmission where it is likely to be disassembled frequently, I use Curil T. When building a gear box that will likely be together for an extended period of time, I use a thin coat of 574 on the paper gasket.
Chain fence eating turbo
Is the original post up to date?
Going to reseal mine shortly. |
Under the radar
BTW. I used a thin coat of RTV on the gaskets when I built this trans about 5 years ago. Worked for five years. Once I get it apart in a couple of days maybe the point of failure will be evident ![]()
Straight shooter
This truth still stands:
Sent from my SM-T580 using Tapatalk
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.” ― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values |
After 16 plus years and literally hundreds of 911 based air-cooled engines assembled using Dow 55 o-ring lubricant, we have had zero reported instances of case leaks due to o-ring failure. Over the past few years of selling our case sealing kit through our host, Pelican Parts, the feedback has been overwhelmingly positive.
As a matter of fact, we are sending out a stock order for sealing kits today. You don't have to trust me, the DOD uses Dow 55 today after decades of success in the weapon systems listed below that are still in service. Dow 55 Military Application NSN 9150-01-066-1823 02 N Strategic Weapon Systems(Poseidon and Trident) 23 N Ohio Class Ssbn (Trident) 43 N Aircraft, Hornet F/A-18 55 N Aircraft, Harrier AV-8B 6F M Howitzer Medium Towed Light Weight 155 BE N Missile, All-Weather Anti-Ship, Harpoon (AGM-84) BM N Torpedo Systems, Mk 46 CM N Adcap Torpedo, Mark 48 CT F Aircraft, Osprey CV-22B CX N Aircraft, Osprey V-22A, Marine Corps EX N Los Angeles Class Ssn (688) EZ N Ticonderoga Class Cg (47) FJ A Lightweight 155MM Towed Artillery System, M777A2 HZ N Forrestal Class Cv JA N Nimitz Class Cvn JC N Fms - Kidd Class Ddg JD N Arleigh Burke Class Ddg JF N Oliver Perry Class (FFG-7) JG N Seawolf Class Ssn JM N Emory S. Land Class as JR N Fms - Knox Class Ff YJ N Virginia Class Submarine, SSN-774 Z9 N Aircraft, FA-18, a - D, E/F, G (Growler)
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net Last edited by Henry Schmidt; 01-13-2017 at 06:24 AM.. |
Straight shooter
How many of those applications are in contact with viton?
![]() Sent from my SM-T580 using Tapatalk
