abit off center
I would do both because it skins over pretty quick
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
Thanks! Will do.
Have a great thanksgiving. Bo |
abit off center
I only used it once, see what the min temp you can apply it at, if it’s 50 I would apply it as cold as they allow giving you more time to assemble
Try not, Do or Do not
One side only as per TB instructions.
Cleanliness is paramount. Apply a moderate bead and spread it evenly. I use my finger to insure that the sealant is adhering.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
It's 50 -60 degrees in my garage... What do you figure safe working time is? Seen posts mention 10 minutes to 30 minutes Last edited by bpu699; 11-22-2017 at 02:02 PM.. |
The instructions are printed in the package.
"apply as thinly and evenly as possible" I interpret that to mean, coating one side is thinner than coating both. As far as work time: I apply the sealant and put the case together quickly. If you're set up and ready to go, time shouldn't be an issue. ![]()
Just want to be clear so I have the best chance for success. Also, I'm assuming that doing this slightly amends the assembly procedure and timing as the crank has to be OUT of the case in order to apply the 1211 in the nose bearing area, THEN the crank goes in the case, THEN you apply the perimeter & main bearing web sealant, THEN you mate the case halves... All of which adds an extra step or 2 during the scramble to mate the case halves before the sealant goes off - is that correct? Thanks so much, Tom
'74 911 Red Sunroof Coupe, 3.6L, etc... '76 912 Yellow SPEC 911/911CUP |
I put the 574 on the main bearing web surfaces first since it wont go off until absence of O2... then I applied a very thin coating of 1211 to the nose bearing itself all around(bearing is on the crank, but not in the case), being careful not to get it on the o-ring.. if a tiny bit gets on, it shouldnt matter. Then I quickly get the 1104 on the perimeter, then crank goes in, and it all gets buttoned up. Pretty sure that is the process you had outlined above. To speed it up, I put my through bolts all in and torqued down, without putting the o-rings on.. then went back one at a time, and removed each through bolt and put the o-ring on. All this did was save a bit of time in getting the case torqued down. I am sure that the pros don't need to do this step and work a lot faster than I. |
A further #8 O-ring question - so if the 1211 goes on the nose bearing itself, avoiding the O-ring as much as possible, the O-ring is essentially getting installed dry? The reason I ask is that in my test-fittings of the crank in the right case-half, I've been having issues pinching the #8 O-ring to the point of cutting it. (Try finding a replacement viton #8 O-ring outside of a full engine rebuild seal kit - it's not easy!) Test fitting w/a little oil on the o-ring provided much better results... So, I guess my question is: using this method, is the O-ring installed dry? and if yes, what's the technique to doing it cleanly w/out slicing and/or pinching the O-ring between the case halves? Thanks, Tom ![]()
On my 3.6 rebuild I put some Dow 111 grease on the o-ring, well on all the o-rings in the engine.
Magnus 911 Silver Targa -77, 3.2 -84 with custom ITBs and EFI. 911T Coupe -69, 3.6, G50, "RSR", track day. 924 -79 Rat Rod EFI/Turbo 375whp@1.85bar. 931 -79 under total restoration. |
Thanks, Tom
Just the 111 on the o-ring, not saying that is right, probably not...but its dry at the moment.
Schleprock
Dow Corning 111 on the o-ring is a great choice. The silicone paste of course lubricates the o-ring and also protects the rubber from long term oil contamination/degradation.
Kevin L '86 Carrera "Larry" |
War Vet
Bump...cuz I need this thread.
MattR
Dr. Phatt |
yeah this needs a sticky like the no start thread in the turbo forum
88 turbo Guards red Targa slant nose, and yes I am a horsepower junkie, 3.4liter,7.5 to 1 JE pistons, Adjustable WUR, Imagine fuel head, 1 bar waste gate headers,allthe cis toys. Now apart to become the next EFI monster. fabbing my own intake, headers Individual throttle bodies, MS-3, pauter rods, Xtreme twin plugged heads, gt-2 evo cams cop's. 2019 Silverado 6.2L |
Hi everyone,
First time 911 engine rebuilder. Has anyone made a start to finish video of themselves applying the currently recommended sealants and assembling the case halves? An assistant holding a modern cellphone from a location where they would not interfere? Thanks, Mark. 1989 911 3.2
1989 911 Carrera 3.2 2009 Audi A4 2.0TQA 2017 BMW X3 2007 BMW 328xi 1971 BMW R60/5 |
well, i do not have start to finish but check my videos , applying the 576 loctite..only to one side of the engine case..the one without the oil pump
Ivan https://www.youtube.com/watch?v=IandhtwG5no https://www.youtube.com/watch?v=ZoOEFOkC2aA https://www.youtube.com/watch?v=STWf7WnC4xo engine case marriage.... https://www.youtube.com/watch?v=fKsuUBZih78
1985 911 with original 501 587 miles...807 226 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. Last edited by proporsche; 01-05-2019 at 11:45 PM.. |
Some of you might find this interesting.
I recently helped open a factory sealed 996 99/00 cup car engine. The engine had nearly 400 hours on it with the factory seal intact. They clearly used a silicone sealant vs the normal 574 and there were lots of strands of sealant everywhere. Just thought I would share. The engine overall was in great shape minus the 20% leak down in each cylinder and it being down 100 hp. Some wear on teh bearings but not bad considering the number of hours and about 19k track miles. These are the strands we removed from the inside of the case. Curious what everyones opinion is regarding this since this is so similar to the earlier cases especially 964/993.
Anthony PCA affiliate '77 member '83 '90 3.8 RS tribute, 91 C4 converted to C2,'93 964 C2, '93 928 GTS M '94 Turbo 3.6, '15 Boxster GTS M,16 GT4,23 Macan GTS, Gone worth mentioning '71 E '79 SC, '79 built to '74 3.0 RS tribute (2390 # 270 hp), '80 928 euro 5 speed, '74 2.0l 914, '89 944 S2,'04 Cayenne TT '14 boxster, '14 Cayenne GTS 14 Cayman S, 18 Macan GTS many others |
Puny Bird
Factory recommended case sealant, but it looks like young Dietter was a little heavy on the application.
SI 5900 is a superior RTV, squeeze out doesn't swell from oil and when applied properly any squeeze out stays put. I even think the long strands from to much sealant may be by design, it doesn't break off in chunks small enough to get past the pump screen. You will have fun removing that RTV, it doesn't like to come off, even after soaking in diesel. Torn down quite a few 996/997 engines and have seen the same, but it was never part of the issue. RTV gets a bad rap because peeps only think of the permatex stuff, but Threebond, (yamabond) is RTV, so are many others. Loctite SI 5900 is factory spec, LN recommends it, look at Raby's vids...that's what he's using. I use it on 996/997 case halves, plus I rub it into (no excess) many paper gaskets I install. It's definitely not the same as the old permatex.
'74 Porsche 914, 3.0/6 '72 Porsche 914, 1.7, wife's summer DD '67 Bug, 2600cc T4,'67 Bus, 2.0 T1 Not putting miles on your car is like not having sex with your girlfriend, so she'll be more desirable to her next boyfriend. |
So Loctite is superior to the (yamabond, hondbond, threebond) whatever you want to call it? Thx
Thread Tools | |
Rate This Thread | |
