I'm about ready to start the building process and having this thread revived was fortunate and timely. I decided that getting the Viton green O-rings was imperitive and stopped by the local NAPA store for some more sealants. They had never heard of ThreeBond.
I called and talked to Henry at SuperTec and he discouraged me from usng him for this small order as parts is not their preferred business. Their website does have the ThreeBond products listed in this thread. Henry did not say weather he had them on hand but referred me to Engine Builders Supply in Reno. EBSracing.com was my next stop and I called them. They do not have the ThreeBond products listed in this thread and said they are no longer being produced because of environmental issues. They did have ThreeBond 1194. I ordered the Vitron Green O-Rings and RSR seals while I was at it. Has anyone sourced the ThreeBond 1101 and 1211 lately?
75 911S Targa - Mine from 2001 until sold to Germany buyer 10/2016 <ALL DIY> Brakes/Wheels '01, Body/paint/restoration 7/04, Suspension 3/07 Engine rebuild - done 7/08 - added 28 tube cooler and SSIs - running strong. Ducktail painted. 2021 MachE, 2012 Outback, 2019 Crosstrek, 2018 Impreza wagon Last edited by notmytarga; 07-01-2008 at 03:33 PM.. Reason: finish |
Try not, Do or Do not
We do have ThreeBond products listed on our website and we would be more than happy to sell our products.
Our web site clearly states that we have a minimum order of just $100 dollars. You wouldn't believe the number of grommet hunters who ask to buy 6 washers and a nut. The purpose of the minimum order is to allow us to sell parts and supplies without loosing money on each sale. As with all symbiotic relationships, the buyer /seller relationship should benefit both parties. If a company can afford to give something away [loose money on a transaction] then they are making it up somewhere else. Generally that means overcharging on something/everything else. We do not operate that way.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
GAFB
I think I ruined it for everyone when I called Henry for a 915 needle bearing spacer a couple years ago. Sorry guys
Several BMWs |
It is good to know that there is a source for the ThreeBond products. I apologize to Henry for overstating his concern with parts orders. He did explain to me on the phone that outgoing orders need to be driven to the shippers requiring an employee to do so. SO.. give the SuperTec site a lookover and find some other goodies to boost your order when you need these sealants.
75 911S Targa - Mine from 2001 until sold to Germany buyer 10/2016 <ALL DIY> Brakes/Wheels '01, Body/paint/restoration 7/04, Suspension 3/07 Engine rebuild - done 7/08 - added 28 tube cooler and SSIs - running strong. Ducktail painted. 2021 MachE, 2012 Outback, 2019 Crosstrek, 2018 Impreza wagon |
I think Henry has gathered a kit so that you guys can get what you need if you cannot get it from Pelican.
Aaron. ![]() Burnham Performance https://www.instagram.com/burnhamperformance/ |
I thought I'd save a little time just sourcing the 574 locally...what a PITA. Ended up accidentally ordering the huge tube which would probably cover 5 rebuilds then ordered the smaller tube which took forever. I should have just ordered from Pelican like everything else. Probably will for the Curil T but now I've sort of been scared off of using it.
Buck '88 Coupe, '87 Cab, '88 535i sold, '19 GLC 300 DD Warren Hall, gone but not forgotten |
I could have used the big tube since I had to seal my case TWICE!!!
Yep, long story ... but I had to tear the case apart 3 hours after sealing it. I used up all of my 574 on the second try and I need more for the cam housings. The strange thing is that when I took it apart, most of the sealant was either on the inside mating surface or it had squeezed to the outside. Not much on the mating surfaces at all ... makes me wonder. I, too, thought I could get it locally ... no dice. For the record, I used 574 on the left side of the case. I will report back after I get the engine completed and drive it a while ... let you all know if it leaks.
82 911SC Coupe Chiffon / Chocolate 9.5 JEs, 964 Cams, SSIs, Dansk Exhaust, CIS (SOLD) |
Hopefully I have not shot myself in the foot by switching to the smaller tube. I guess the purpose of the 574 is to fill in the microscopic gaps and keep it from leaking which would "seal" it but not impact the fit of the bearings on the crank. I'd hate to have to account for the "sealant factor" when putting an engine back together.
Ambitious Outsider
I found all my Three Bond sealants here, http://www.z1enterprises.com
This company is really good and reliable.
1988 3.2 Cab 2005 997.1 C2S |
Ambitious Outsider
Allow me to state the facts here; first of all, Z1 Enterprises is a company that supplies Motorcycle parts and accessories. Does Porsche make motorcycles? I know BMW does but we are not talking about BMW, we are talking about Porsche and Porsche engines. Secondly, to my understanding on this BB, people help each other out. In the past people on this BB have helped me tremendously, and with out this BB I would have been in serious trouble, therefore I would try to help my fellow pelican's to the best of my ability. Lastly, if I have offended the higher up's at Pelican by posting a measly link so that a fellow Pelican can sleep a little bit easer tonight than I offer my apologies. If you want to talk about loyalty to this company, than I am loyal and I have every single receipt that tally way over 13k so far to prove that I am. So instead of being a flamer be a helper instead!
Thanks! (although I already used Loctite 574 that I purchased from Pelcian ![]()
Maybe you should search Henry's name on the forum here before you make a suggestion such as this?
Ed Hughes 2015 981 Cayman GTS 6 speed,Racing Yellow Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4 |
Constitutional Liberal
As for being a "Flamer instead of a helper" I assume you're kidding. Henry has helped more people on this forum than you with your limited understanding can fathom. The sealing techniques listed in this thread were primarily quotes from him. Go back and read and perhaps you'll get it.
Jim “Rhetoric is no substitute for reality.” ― Thomas Sowell |
abit off center
I don't know about all of you but when I click on Henry's XXXXXXXX.com site I just get porn!! No sealer?
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. Last edited by cgarr; 07-11-2008 at 07:11 PM.. |
Ambitious Outsider
Pelican Parts provides this forum for free. They don't get paid by any of us for this very valuable service. They and volunteers have compiled a great deal of information as a service to us while asking for little in return.
We are very lucky to have several world class experts posting here regularly, just to share their wealth of knowledge for our benefit. I truly appreciate all that these people do for us for free, asking for little in return. Pelican Parts asks that we not post links to their competitors' websites and that's very little to ask in return for all of the time and expense that is required to build and maintain a forum as big and comprehensive as this. They even allow used parts classifieds! They could be selling some of those parts to us new, but they see classifieds as yet another service that we can benefit from. Have a little grace and some class, please. |
Overall , its a fantastic symbiotic strategy and has benefits to both sides. There are other just as active forums (Rennlist comes to mind) that do not have this orientation, but have memberhship fees that fund the infrastructure. They also have some restrictions regarding sponsors and such. IMHO anyways, for what's its worth! Cheers, Mike
Mike 97 993TT Arena Red - "Scarlett" |
When people come together in a community, self control & community standards (rules) are the only things that prevent anarchy. Learning to exist in that community requires that you respect the rules when expressing yourself. If being suspended doesn't matter to you, perhaps you should just move on now. I personally enjoy this community and believe me I am not a champion of rules but this forum is worth the simple effort required to obey the standards set by the owner. Try to remember that this is private property and as such the owner can regulate the content any way he sees fit. I think I'll climb down off my soap box now, cheers.
I got my engine back from the shop and did the initial run in before break in. The engine had gone back to the shop back in February because it was leaking from all of the base cylinder gaskets the worst of them was coming from #3. Well the shop got all of the leaks plugged but #3 still is dripping. Should i at this point go break the engine in and drive it, and live with the leak. I plan on removing the engine to adjust the valves in about 500 miles of break in driving. is there anything i can smear on the area that i find is leaking like a Threebond 1104 to slow it up. If i bring my engine back to the builder i am afraid i will have to wait another year to drive my car it's already been over a year and a half since this started.
I am at a point now to consider shipping it out to Henry to look at... I TOOK THE CAR OUT FOR A COUPLE OF BREAK IN RUNS Car is very scary, even trying to drive it careful was very difficult for me. I am sure i will get used to in time, but feel i need a few more gears. I had a hard time looking at the gauges and when i was i didn't like what i saw, I was boosting way higher than what i should of been since i set it lower for the break in. I couldn't hear the BOV let go either. Everything is hooked up the way it always has been, and double checking it i find nothing in the wrong order. I will turn back my MBC further to see if that helps things. I was at 14lbs in a snap. not sure of the A/R's but when i did look they were on the leaner side of my comfort zone. The BAD news now, engine is leaking oil from the same areas as it was before, this sucks so bad, the shop has wasted so much time getting the engine built the first time and the second time now, i have waited over a year and a half for this engine to get built right and it looks like i am back to square one. I could drive it sparingly for awhile and mop it up after every drive, or i pull the engine and ship it out to Henry at Supertec to fix right and hope i get it back to enjoy the Fall season. Anyhow it was fun finally driving the car again, but am very disappointed with the shop guys right now. I am going to drink a few Benders and go to bed........
![]() 914 6 Turbo twinplug 3.12 87 924S Lexus SC400 Lexus LS400 Last edited by iamchappy; 07-30-2008 at 07:15 PM.. |
