peppy's Avatar
I called and asked, on the 98mm JE's the compression rings are the same.
Peppy
2011 BMW 335d
1988 Targa 3.4
2001 Jetta TDI dead
1982 Chevette Diesel SOLD
Old 07-30-2012, 02:28 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #101 (permalink)
KTL KTL is offline
Schleprock
KTL's Avatar
Yeah those piston circlips are a real PITA. That's why Stomski invented the circlip injector. Expensive, but man does it work (and eliminate cursing).
Kevin L
'86 Carrera "Larry"
Old 07-30-2012, 02:31 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #102 (permalink)
PFM PFM is offline
PFM
PFM's Avatar
Peppy,
It may be a lot too late to say this but if the edges pointed out by the arrows are as sharp as they look you might want to consider a slight blend to take the sharp edge away. Not a pro here but been around the block a time or two.
I will also second the clip injector tool worked perfect.
Stay tuned,
PFM
Stay Tuned,
PFM
Old 07-30-2012, 06:55 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #103 (permalink)
peppy's Avatar
PFM, those edges are pretty sharp, I thought it was to help them cut through the air better. How should they be smoothed? Emery cloth?
Peppy
2011 BMW 335d
1988 Targa 3.4
2001 Jetta TDI dead
Old 07-31-2012, 09:07 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #104 (permalink)
peppy's Avatar
Ok I need to let everyone know that letting a 5 yo play with zip dry may sound like a good idea, but it isn't.
My son put a scoop in one of the cylinders.
How bad could it be?
Peppy
2011 BMW 335d
1988 Targa 3.4
2001 Jetta TDI dead
Old 08-05-2012, 02:10 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #105 (permalink)
KTL KTL is offline
Schleprock
KTL's Avatar
Smoothing the edges of the pistons is done to reduce detonation. The sharp edges are very thin and heat up easily.
I'd pull that cylinder off and clean it & the piston + rings very good!
Kevin L
'86 Carrera "Larry"
Old 08-06-2012, 06:32 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #106 (permalink)
peppy's Avatar
That's what I did, and lesson learned.
Peppy
2011 BMW 335d
1988 Targa 3.4
2001 Jetta TDI dead
Old 08-06-2012, 08:03 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #107 (permalink)
peppy's Avatar
Didn't make much progress yesterday after the incident.
Peppy
2011 BMW 335d
1988 Targa 3.4
2001 Jetta TDI dead
Old 08-06-2012, 08:10 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #108 (permalink)
He was just trying to stop the oil from leaking.
Old 08-10-2012, 01:11 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #109 (permalink)
peppy's Avatar
Maybe my son should consult with Wayne and Henry on some new ideas about sealing a cases.
Peppy
2011 BMW 335d
1988 Targa 3.4
2001 Jetta TDI dead
Old 08-10-2012, 04:27 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #110 (permalink)
You dont want nyloc nuts inside the engine, the plastic will melt
Bruce
Old 08-10-2012, 05:31 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #111 (permalink)
peppy's Avatar
Bruce
Crap...Thanks Bruce, I guess I will be changing those.
I am doing a lot of the steps twice. I put the wrong cam in yesterday and now I have to change all the nuts. I wonder were all those are supposed to go? They came in one of the "kits" I got?
Peppy
2011 BMW 335d
1988 Targa 3.4
2001 Jetta TDI dead
Old 08-11-2012, 08:28 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #112 (permalink)
911 tweaks's Avatar
...nuts for the valve covers possibly...??
I live for 911 tweaks...
Old 08-11-2012, 10:48 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #113 (permalink)
peppy's Avatar
I am beginning to think this was a bad idea. I was replacing the nuts and washers on the cam towers and dropped a washer in the case.
I got lucky fishing it out but there was a lot of cussing.
Can you reuse chain ramp washers? How about the lock nuts? I know the aluminum crush washers are wasted.
Peppy
2011 BMW 335d
1988 Targa 3.4
2001 Jetta TDI dead
Old 08-17-2012, 07:01 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #114 (permalink)
Sboxin's Avatar
PAIN BUILDS CHARACTER
Regards,
2002 Porsche Boxster S Cobalt Blue/Blk/Blk
Crew Chief for Son's 1978 Porsche 911SC Original Porsche Mocha Brown 3.8L NASA race car
Previous Porsches: 1958 356 Red Coupe - 1972 914 Blue -1972 911T Coupe Aubergine
Old 08-17-2012, 08:37 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #115 (permalink)
Inside the engine youre suposed to use wavey spring steel washers with non nyloc nuts
I get them from Lilly Fasteners in Shelby, NC, or Newark, Del.
The aluminum washers are used on chain box covers and the valve covers. Centerline of the case uses the steel washers provided and prevailing torque nuts on the Carrera and later.
Bruce
Old 08-17-2012, 09:38 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #116 (permalink)
peppy's Avatar
Bruce I originally used aluminum washers and the nyloc nuts. I was changing them over to the original spring washer and nuts (reusing the old ones).
Am I doing it wrong?
Peppy
2011 BMW 335d
1988 Targa 3.4
2001 Jetta TDI dead
Old 08-17-2012, 09:47 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #117 (permalink)
Youre not doing wrong. You have a PM
Bruce
Old 08-17-2012, 11:36 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #118 (permalink)
peppy's Avatar
Getting back on track...
Can I use copper washers on the chain ramp bolts instead of aluminum?
Peppy
2011 BMW 335d
1988 Targa 3.4
2001 Jetta TDI dead
Old 08-24-2012, 01:31 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #119 (permalink)
KTL KTL is offline
Schleprock
KTL's Avatar
As long as they're the right size for the shank of the bolt, copper is fine. Just need something relatively soft to crush and seal the oil from weeping out.
Kevin L
'86 Carrera "Larry"
Old 08-24-2012, 01:55 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #120 (permalink)
