Con Rod Nuts
I've ordered new con rod bolts from our host but planned on reusing the nuts....is this acceptable or not?
TIA
Buck
'88 Coupe, '87 Cab,
'88 535i sold, '19 GLC 300 DD
Warren Hall, gone but not forgotten
Old 05-22-2008, 07:34 PM
Try not, Do or Do not
Henry Schmidt's Avatar
Reusing the rod nuts won't hurt, but why would you ? A 911 engine rebuild is a gamble at best. Why cut corners?
We carry rod nut replacement one step further. We use the serrated flange 928 nut with all new bolts, even ARP and ty bolts.
@ 2.50 ea it seems like the best choice.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 05-22-2008, 09:02 PM
Porschekid962's Avatar
Send a message via AIM to Porschekid962 Send a message via Yahoo to Porschekid962
Reusing rod nuts? No thank you, no need for Ti nuts either. Plus using a Ti(tanium) nut on a steel bolt is not the proper thing to do, those metals dont like each other that much. ARP is one of the better fastener companies, stock will always work but buy new ones. I hear of people dropping a lot of money on all the wrong stuff and then want to reuse rod nuts or flywheel bolts or this or that. Just replace it.
74 911s neverending story. two feet and a jetta for now.
Old 05-22-2008, 10:19 PM
I'm about to buy a set of ARP connecting rod bolts for a 2.0S rebuild.
Is there an option for metric nut sizing, I know it'll probably never
come apart again but it just seems wrong to stick imperial sized
rubbish inside a beautiful machine.
andy
Old 05-23-2008, 05:17 AM
304065's Avatar
Buck, I would get new nuts, the threads fatigue too, and the facets of the nuts may be rounded if you look very closely.
Andy, you are exactly correct. As I was assembling my engine I noticed that a metric socket didn't fit around the ARP nut. The bloody thing is SAE! That's like white socks with a suit, how can anyone produce a metric sized bolt (10mm) with an SAE nut? There is absolutely no reason for it.
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 05-23-2008, 05:43 AM
No one was recommending Ty nuts on steel bolts, although if properly coated they will work fine. What we recommend is the Porsche 928/944 rod nut (steel, serrated, flanged) on all 10 mm Porsche rod bolts. Even Ty and ARP bolts. They are of the highest quality and offer a serrated flange for better stability/reliability.
They also have a 14 mm head and are far more cost effective than ARP nuts.
928 103 172 02 msrp $ 1.86
As I stated above, the 928 /944 rod nut (12 point 14mm head) will fit the ARP10mm bolt ( 2.0, 2.2, 2.4, 2.7, 3.0 and GT3) and the ARP bolts can be purchased sans nuts at a greatly reduced price.
Henry Schmidt
Ph: 760-728-3062
Old 05-23-2008, 08:19 AM
Weight?
Henry,
Is there any weight savings? Probably not much, but didn't know if that was a driver in using these.
Lyn
Track: 91 C2 SuperCup wannabe, 08 Cayman S
Street: 85 RUF BTR Slant-nose, 70 911 T Coupe Pastel Blue
Projects: 82 911 SC 3.6, 72 911 T Coupe, 74 914 Signal Orange
Old 05-23-2008, 08:31 AM
There is no weight savings. In fact the 12 point nut actually weighs 2 grams more. The reason for using them is the quality. Higher quality/ low price equals good investment.
Henry Schmidt
Ph: 760-728-3062
Old 05-23-2008, 08:52 AM
My main reason for asking was b/c I was probably going to start the reassembly this weekend and there was no way I'd get them from Pelican in time, but I can just buy them locally now that I think about it. I've been so brainwashed by the Pelican Kool Aid I forget sometimes I can buy parts here in Dallas....D'OH!
Buck
'88 Coupe, '87 Cab,
Old 05-23-2008, 09:20 AM
Henry im just figuring on a streetcar the Ti nuts in any form would not be the right choice. I like stock and I like arp, just depends on your application.
Guys, SAE fasteners are some of the best out there, AN and NAS are in prolific use throughout all kinds of racecars. Metric is pretty much for motors. ARP makes some of the best aftermarket fasteners you can buy, its probably also the biggest name in the public. You can always call up Coast Fabrications and they can have custom bolts made for you but open wide...
Old 05-23-2008, 07:00 PM
mcinturff's Avatar
If titanium is strong enough to be used for con rods it will certainly hold up to the stresses of rod nuts.
1988 930 Cab - Peru Red
1983 911SC - Black
1992 964 C2 Cab - Amazon Metallic Green
Old 05-24-2008, 09:41 PM
Max Sluiter
Flieger's Avatar
The issue is not strength as far as breaking is concerned. Titanium nuts on steel studs or wheel hubs have a tendancy to "creep". The factory used steel nuts on 917 Dilavar studs for the same reason. They tried Titanium on wheel nuts but found they backed off during a race, if I remember Fere's The Racing Porsches correctly.
Titanium does not break, it just flexes and heats as it expands and lets go of its clamoing force.
Old 05-25-2008, 08:39 AM
Max Sluiter
Flieger's Avatar
Correct me if I am wrong
sww914's Avatar
Nobody suggested using Ti nuts. Henry said that he uses the 928/944 STEEL NUTS even on Ti bolts. STEEL NUTS.
Old 05-25-2008, 10:56 AM
mcinturff's Avatar
has inconel ever been used in a Porsche motor? I know F1 cars use it for exhaust due to better heat retention properties than steel and especially aluminum.
1983 911SC - Black
Old 05-25-2008, 11:58 AM
Henry, how could somebody go about ordering ARP bolts without the nuts? I am in Australia.
I have only seen the nut+bolt kits online, is there a part number for a special order?
andy
Old 05-25-2008, 06:34 PM
Navin Johnson
TimT's Avatar
Yes, I have a set of 935 headers made from iconel. Not a fastener....
'69 911 GT-5
'75 914 GT-3
and others
Old 05-25-2008, 07:17 PM
mcinturff's Avatar
i'll bet you had to shell out a few bucks for those, eh? How is the quality?
1983 911SC - Black
Old 05-25-2008, 07:32 PM
Navin Johnson
TimT's Avatar
How is the quality?
Suberb... the welds are impressive, all the flanges live in the same plane, and the turbos mount right where they should........
I have some pic (somewhere), but then this is a thread about fasteners.... not exhausts..
'69 911 GT-5
'75 914 GT-3
and others
Old 05-25-2008, 07:39 PM
Author of "101 Projects"
Wayne 962's Avatar
A marketing guy I used to chat with told me that your goal is to not to make your company the preferred choice, but instead in the customer's mind to make it the *only* choice they ever think of. Mission accomplished here!
-Wayne
Old 05-26-2008, 01:51 AM
Tags
trade secrets
