350HP930's Avatar
Great progress Rick.
Are those new nylock fasteners on the case perimeter?
Old 06-26-2011, 09:21 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #181 (permalink)
CaptainCalf's Avatar
Yep, all new nylocks and washer all round
FS 1987 930 DTAFast EFI w/Electronic Dash, 17x9x11" Lindsey Racing Fuchs, Andial 8.39 R&P, C2 Intake, SuperCup Cams, Flame Ringed Heads & Cylinders, TurboKraft Full Bay Intercooler, RearlyL8 Twin Scroll Headers, Big Bullseye Twin Scroll Turbo...SOLD
1999 Harley Davidson Custom 1250 Hardtail Bobber..SOLD
2014 BMW X6M, 2012 BMW 128i, 2014 GMC Sierra, 2015 Cobia 237 Center Console 300hp Yamaha
Old 06-27-2011, 05:05 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #182 (permalink)
3 of 6 heads on!
I got to get my hands dirty before work this morning
Old 06-30-2011, 08:25 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #183 (permalink)
More pics
made a little more progress this weekend
Old 07-05-2011, 06:59 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #184 (permalink)
350HP930's Avatar
Looks great Rick. Do you already have your wheel for degreeing the cams? I'm pretty sure one of the boxes I gave you contained a gauge holder block for measuring the cam lift so all you should need is the wheel and the gauge you used to measure your rod bolt stretch.
Old 07-05-2011, 01:27 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #185 (permalink)
Yep, I found the dial gauge holder & thanks!
I've got a degreeing wheel and a few more dial gauges to choose from so I should be able to zero those super cup cams in soon
In the meantime, I finished up rebuilding the struts. New HD inserts & all newtie rod ends and ball joints
Old 07-05-2011, 04:31 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #186 (permalink)
Air Hole Plugs for heads
If anybody ever needs something to plug up those pesky little air holes on the exh side of the heads I have the perfect solution. A very wise ole race car builder turned me on to...Thanks! them
Old 07-07-2011, 07:09 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #187 (permalink)
Pelican sells those in a kit with copper sealing washers. Some people have had them unscrew and blow out while driving. I put them in my car as tight as I dare with the threads coated with red loctite and they havn't come loose in 4 years.
Usually I only put a dab of red loctite on a corner of some bolt threads so they can still be removed without too much hassle but I used more on those hoping they stay put.
Old 07-07-2011, 07:47 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #188 (permalink)
Good advise! I have copper washers in one of the 930 gaskits that I was also advised to use and now I'll also plan on some red locktite...Thanks,RC
Old 07-07-2011, 07:53 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #189 (permalink)
more progress
I made a thread chaser today using an old used m10x1.5 head stud and paired with a snap-on collet it worked great.
I ended up with a couple of head bolts that were loose in the case so I added some green sleeve. Hope that does the job cuz timeserts wont be as easy
taped a new keg too
Old 07-08-2011, 07:17 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #190 (permalink)
PFM PFM is offline
PFM
PFM's Avatar
Captian,
I like how you roll. Fresh keg and all.
Stay Tuned,
PFM
Old 07-08-2011, 07:25 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #191 (permalink)
Originally Posted by PFM View Post
Captian,
Thanks PFM, it helps keep me cool in a hot FLORIDA garage
Old 07-08-2011, 07:33 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #192 (permalink)
Schwarzeritter's Avatar
Location: PaloAlto Calif, IndianWells PalmDesert, Japan
Nice work man!
Taze em..TAZE EM ALL!!
A man that builds a thousend bridges is a bridge builder, but a man that sucks one ( blank ) is a ( blank ) sucker.
It looks like the 4th of July from my rear view, how about from your view?
Old 07-08-2011, 07:34 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #193 (permalink)
Fuel tank filter
Cleaned out all of the old gas today. I was glad to see there was plenty in there cuz it kept the tank from rusting. Replaced the tank filter screen and it needed it after 24 years
Old 07-09-2011, 01:18 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #194 (permalink)
350HP930's Avatar
So how many gallons did I appear to have left in there Rick? If it was my typical amount I would guess somewhere between 5 and 10 gallons.
I would ocasionally add a can of marvels to a tank to keep the pumps and CIS components supplied with some detergent/lube so hopefully that helped to prevent corrosion and gunk build up in the fuel system.
Old 07-10-2011, 04:53 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #195 (permalink)
There was approximately 6 gallons in there and it was high octane smeely stuff that I gave to a friend for his burn pile starter
Changed out the fuel line between the pump and tank cuz it was loose and had hardened, but overall the fuel system looks good to go...Thanks
Old 07-10-2011, 06:54 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #196 (permalink)
Distributor MIA
Found this distributor plug for an Italian motorcycle that fit well and looks great
Old 07-11-2011, 05:27 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #197 (permalink)
jsveb's Avatar
Where do I buy that beer?
Really nice progress.
Good luck.
Jesper
Carrera 3.0 1975
930 1978 OEM Matte Schwartz, ANDIAL IC, BL WUR, SC cams. LMA-3 w. XD-16 and CP transducer
www.stauningwhisky.dk
Old 07-11-2011, 07:46 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #198 (permalink)
Good luck.
Thanks Jesper
As for the beer, I have a good friend that I've been riding road bikes with for the last 15 years who's a Miller distributor in Tampa, FL. Whenever my kegerator runs dry he sends me a list of about 100 craft beers that they have in stock at that time and I just pick one and he brings it to my house. We then proceed to tap it and taste test it
Old 07-12-2011, 05:23 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #199 (permalink)
350HP930's Avatar
Good find on the distributor plug Rick.
Old 07-12-2011, 06:00 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #200 (permalink)
