carrerarsr65
valve spring compressor
are there any inexspensive valve spring compressor tools out there maybe somebody know some other way to get the valve out
Old 01-31-2014, 03:19 PM
Sears has a good selection of them with good warranty. The big C clamp ones with a lever and fine adjustment don't touch the springs and are usually stocked in the store. I have this one and it works well for $35. You get what you pay for.
Sears.com
Old 01-31-2014, 04:40 PM
abit off center
cgarr's Avatar
Looking for one to do heads on or off the engine?
______________________
Craig
G2Performance
Old 01-31-2014, 04:58 PM
carrerarsr65
off the engine
Old 01-31-2014, 06:00 PM
abit off center
cgarr's Avatar
This may look crude but what I made out of an old 6" C-clamp has worked better than some fancy ones I have tried, it's small and easy to handle made just for 911 heads and have done hundreds of them with this.
Craig
G2Performance
Old 01-31-2014, 06:20 PM
Jeff Alton's Avatar
We use one that looks like this, works like a charm. My guess is that this is available pretty cheap in the US at a place like Harbor freight.
www.turn3autosport.com
Old 01-31-2014, 06:31 PM
carrerarsr65
thanks jeff i seen these here in us
Old 02-01-2014, 06:48 AM
Walt Fricke's Avatar
I like Craig's approach.
Here is one I bought - from Sears I think, as they were recommended. It wasn't up to the task, at least with race springs. I'd start squeezing, and something would bend. I'd weld on some reinforcing plates, and try again. Something else would bend. I mount it in a vice, and have gotten so that I can get things on first try most of the time.
The handle was way too short for the force needed, so that got lengthened as well as reinforced (it was flexing).
Not sure Harbor Freight quality ones would do any better. Sure would be nice, though.
Ugly welding, but it did the trick.
Old 02-05-2014, 09:05 PM
Ken911's Avatar
i got one of those also worked great until i used it for racing springs in the new heads. now it bends
88 turbo Guards red Targa slant nose, and yes I am a horsepower junkie, 3.4liter,7.5 to 1 JE pistons, Adjustable WUR, Imagine fuel head, 1 bar waste gate headers,allthe cis toys. Now apart to become the next EFI monster. fabbing my own intake, headers Individual throttle bodies, MS-3, pauter rods, Xtreme twin plugged heads, gt-2 evo cams cop's.
2019 Silverado 6.2L
Old 02-06-2014, 04:16 AM
KTL KTL is online now
Schleprock
KTL's Avatar
Yah that universal spring compressor is a pile of crap. The forked "foot" that sits on the spring retainer wants to walk off when you really have to apply a lot of compression to the spring. Been there done that. Thing is freakin' dangerous on stiff springs.
The one that Jeff posted is much better because it captures the entire spring/retainer. The one that Craig made is the hot setup & very sturdy. My buddy Brian made a similar one he showed me.
Kevin L
'86 Carrera "Larry"
Old 02-06-2014, 09:22 AM
When you switch to titanium valve spring retainers, you end up with a lot of steel ones just crying to be put to use in something like this.
Old 02-06-2014, 08:59 PM
IXjamesXI's Avatar
I made a c-clamp style one today, very similar to craigs (cgarr). Is there any risk of bending valves with this type of tool? I worry that if I don't have the clamp EXACTLY centered that I will be compressing the spring at an angle to the valve stem and possibly bend it.. or am I too worried.
'82 SC Coupe / Pacific Blue
Old 05-31-2014, 02:14 PM
abit off center
cgarr's Avatar
They will not bend, might have some tight keepers at times. Over 600 heads and 2400 valves later and never a problem.
Craig
G2Performance
Old 05-31-2014, 02:33 PM
IXjamesXI's Avatar
A little crude! But it does work.
Old 05-31-2014, 03:08 PM
ROW '78 911 Targa
timmy2's Avatar
KTC Auto tools HO-7002 is one I bought on ebay. Just loaned it out for an Audi head or I'd take a picture.
Sold as a heavy duty unit for motorcycle heads. Worked on my Toyota head too.
Here it is on Amazon:
Amazon.com : Car & Motorcycle Valve Spring Compressor Tool Set : Everything Else
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 06-03-2014, 11:43 PM
Alan L's Avatar
If the keepers are tight, try pinging the top of the valve stem with a hammer before compressing. Weird, but works.
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-)
Old 06-04-2014, 04:51 PM
