Frigidaire Pro, but Kitchen Aid, Whirlpool... all the same thing.
Under the radar
OK, I had to look! Well if my Bosch DW has more than a cup of water left in it I can't see it when I pull the strainer out. BTW, I had cleaned my case and heads of most gunk before I put them in and I did not notice any residual odor.
Back to our normal thread...
Member 911 Anonymous
Ah, it's a Bosch :-)
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Weekend Fun:
Just finished wire brushing all the carbon out of the innards and hot washed via Dish Washer, again :-P. Oh man, a ton of carbon came out. I think she will breathe better now :-) For added fun, I used Craft Store's Oil Based Red Paint for metal on the Logo.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC Last edited by DRACO A5OG; 04-01-2017 at 09:49 AM.. |
Under the radar
Looking good. Is extrude hone in your future?
I was thinking about it but probably not. Want to see what my current set up is going to yield in HPs before squeezing out every drop of the HPs. ( Ring Seating MOST Important )
Update, all accesorries installed, just need intake and Throttle Body
Engine is staring to get to big for two cars in the garage, thank goodness I can rotate the engine on the stand ![]() Note, Put on the rear tin before the muffler and the air duct shroud to measure the cross member to the intakes or it will never fit after it.
Dial 911
Wow!..You've more or less finished the job Jim!..You've become quite a talented little devil eh!
...Your tranny, and now a complete engine rebuild - Very impressive!Hats of to You!!!
Cheers! “Simplicity is the ultimate sophistication.” Leonardo Da Vinci Last edited by A horse with no name; 04-02-2017 at 10:40 PM.. |
LOL, thanks Brother.
Yeah, amazed that I can remember how everything goes back together but Lots of Help here. Thanks to all :-)
Update:
Waiting on the Intake Manifold Rubber Sleeve 930-110-573-01. I think I could have re-used it but I really did not like the strange deformation at the bottom portion of the sleeve. This one is not an easy replacement as it requires removal of one of the intakes at a minimum. Here is my old sleeve: That crease really concerns me plus oil residue just sits there. That pic even after I cleaned off the crease, it remained gummy wet and porous, so definitely compromised. Side Note: Throttle Body, no sealant but new black o-ring that is in the Wrightwood Seal Kit, Allen Bolts = 7.3 ft lbs ( 9.9Nm )
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC Last edited by DRACO A5OG; 04-04-2017 at 07:39 PM.. |
Schleprock
I'm guessing that crease is from misalignment of the manifolds. I guess it was easier to make the manifold two-piece instead of one
You know the way to get rid of that oil residue in there? Disconnect the oil tank vent hose from the throttle body rubber elbow and connect it to a catch can.
Kevin L '86 Carrera "Larry" |
Good Idea
Master KTL
Under the radar
There is got to be a way to put an inline filter or trap liken to a gas line sediment trap
Heck, even a Drip Leg ![]()
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC Last edited by DRACO A5OG; 04-04-2017 at 01:10 PM.. |
Chain fence eating turbo
Jim, that hose is super soft naturally. You can simply loosen the clamps, allow the ends to situate themselves, then tighten.
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel |
Schleprock
Absolutely good point about the smog cops you guys have to deal with. That said, it's not too much work to have a catch can and dedicated hose you use for it. When you're scheduled to do your inspection, swap out the catch can & its personal hose, remove the plug in the throttle body elbow, replace the original hose connecting the throttle body to the oil tank.
Eh, I am only testing anyways :-)
Damn, Delivery from Atlanta is slower the molasses
Update:
All assembled, AFM on after she is in :-) Break In FRIDAY! Pray for me Fellas
Good job !
We are with you !!!
1992 C2 964 (Nevada USA & France)
May the ring seating force be with you !! Will be right behind you in about a month (I hope)
1979 SC 1986 Carrera 3.6 L+ |
