That would do it, they need lots of heat.
Old 04-17-2017, 07:11 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #121 (permalink)
Member 911 Anonymous
DRACO A5OG's Avatar
Thumbs up Diagnosis
Update:
Finally removed P-Side Cam with Heads
Bottom lower corner #6 pulled from case
No apparent damage to heads or cylinder, finger nail test
Bonus, the walls look great no signs of adverse wear or tear after 500 miles.
Ready for surgery, split between TimeSert of Case Saver, Wayne likes the Case Savers for Mag Cases I wonder if TimeSert will be find here? TimeSert is 24.5MM long not sure about CaseSaver's out course pitch and size. I have the kit for the TimeSert
'85 Carrera Targa
PCA/POC
Old 04-23-2017, 11:07 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #122 (permalink)
Chain fence eating turbo
I'm sick for you, thst has to be disheartening.
Anyways, did you clean the piston and combustion chambers, or were they that clean?
Old 04-23-2017, 12:08 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #123 (permalink)
DRACO A5OG's Avatar
No big deal glad I don't have to tamper with D-side.
The good thing is I can check ring seating and piston to valve clearance are good to go :-)
Oh no, I wiped them down to look for irregular wear pattern, wiped very easily surprisingly.
'85 Carrera Targa
PCA/POC
Old 04-23-2017, 12:45 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #124 (permalink)
Nice
Old 04-23-2017, 01:52 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #125 (permalink)
good news and nice post
Thank you for sharing
1992 C2 964 (Nevada USA & France)
Old 04-24-2017, 07:39 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #126 (permalink)
Dial 911
A horse with no name's Avatar
Thumbs up Well Done!
Hi Jim...It appears that you have more patience than Job! - Again... 'Hat's off to you Bro"
Cheers!
“Simplicity is the ultimate sophistication.”
Leonardo Da Vinci
Old 04-26-2017, 01:15 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #127 (permalink)
DRACO A5OG's Avatar
Thanks for the well wishes Fellas.
So, upon recommendation of Master KTL, I decided to go Case Savers, the M16 ( 14MM X 24MM x 2.0 Pitch ), just waiting for taper/threader. Maybe over kill for an aluminum case, but better safe than tear down again due to pulling.
Built a jig with left over aluminum and copper tubing to help me thread in straight, no need to porcupine the repair :-D
Drilling holes to use the cylinder place holders and a pilot hole for the threader/taper.
Might make another bar to make it even more accurate.
Thank goodness it is only one, if it was more, I would definitely take the case to a Machine Shop to avoid the notorious porcupine affect
'85 Carrera Targa
PCA/POC
Old 04-26-2017, 08:28 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #128 (permalink)
Great thread! I could only hope to handle the pulled head stud as well as you have...
2007 911 Turbo 6-speed, 1984 911 Carrera, 1974 911S, 75 914-6 conversion/project, 2007 Mercedes SL63 AMG, Coyote Powered FFR Cobra
Old 04-30-2017, 08:37 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #129 (permalink)
DRACO A5OG's Avatar
Fixed and Torqued to Spec!
Update:
Success, my little jig actually worked!
Believe me I was pooping bricks while doing this with the M16 Drill Bit and 14MM x 24 X 2.0 CASE SAVER.
19 ft lbs then 38 ft lbs. DONE!
Now to put everything back together and re-check timing
'85 Carrera Targa
PCA/POC
Old 04-30-2017, 09:02 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #130 (permalink)
DRACO A5OG's Avatar
Thumbs up Timing Verified, Repair complete!
Whoa!
I gotta tell ya, life is funny
Lucky me, timing did not change, wow. fortunately I thought ahead and gambled by marking the sprocket before removal, glad I did. I am sure this never happens the first time checking timing, :-) well maybe Nick FUlljames :-P. But my ghetto technique worked
Yeah, I took the intake off to prepare for splitting the engine, yes split because I fuched myself when I dropped a wrist pin in there using the stupid expensive Porsche SST ( which totally sucks btw, Thanks Porsche! ) In desperation I used my HF video borescope and luckily found it on my first attempt and used a magnet to pull that little sucker out. OMG!
I love YouTube, trying to find a proper tool I stumbled on to this guy, he showed how to properly install the damn pins without gimmicky tools or craziness. Just a small flathead screwdriver and my thumbs, WOW. 3-5 seconds, that is all it took. BINGO!
Well, I took this opportunity to clean up the aircraft tar like sealant that made it's way into the intake from the intake gaskets.
'85 Carrera Targa
PCA/POC
Old 05-01-2017, 12:26 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #131 (permalink)
DRACO A5OG's Avatar
RFLOL, that is the problem my job, if I was jobless this would have been done 2 weeks ago
Eh, I fear no more with this car. I can do it all now
'85 Carrera Targa
PCA/POC
Old 05-01-2017, 02:04 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #132 (permalink)
KTL KTL is online now
Schleprock
KTL's Avatar
Mahle tips and tricks installing the wire locks
https://youtu.be/3kdhGBCpuxM
Kevin L
'86 Carrera "Larry"
Old 05-01-2017, 07:23 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #133 (permalink)
Under the radar
Trackrash's Avatar
Originally Posted by DRACO A5OG View Post
Whoa!
I would like to see this work on JE cir-clips. NO WAY. AHIK.
I spent some time today making my own installer. A piece of EMT tubing, a 14mm bolt with the head machined to fit in the tubing, and a long socket extension. Worked like a champ.
Gordon
'71 911 Coupe 3,0L outlawed
Old 05-01-2017, 08:11 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #134 (permalink)
Ken911's Avatar
the above method does work on JE clips i will admit to bloody fingers when completed though.
88 turbo Guards red Targa slant nose, and yes I am a horsepower junkie, 3.4liter,7.5 to 1 JE pistons, Adjustable WUR, Imagine fuel head, 1 bar waste gate headers,allthe cis toys. Now apart to become the next EFI monster. fabbing my own intake, headers Individual throttle bodies, MS-3, pauter rods, Xtreme twin plugged heads, gt-2 evo cams cop's.
2019 Silverado 6.2L
Old 05-02-2017, 06:19 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #135 (permalink)
Under the radar
Trackrash's Avatar
I gave up after about 30 minutes of chasing circlips across my garage. One is still MIA. I did have the head studs installed, which may complicated things.
I spent less time making my tool than cussing about trying to install them without using it.
I have installed all 12 in the past without the tool. For some reason this time it just wasn't working for me.
Gordon
Old 05-02-2017, 09:59 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #136 (permalink)
Ken911's Avatar
I have to get new clips when i took it all apart a couple went sailing across the garage never to be found again.
2019 Silverado 6.2L
Old 05-02-2017, 11:06 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #137 (permalink)
arbita1's Avatar
Those JE circlips were hell. Some went so easy. And some took all the allotted time you had to work on the engine that day.
Matt.
83 911SC
85.5 944 NA - Sold
Old 05-03-2017, 05:52 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #138 (permalink)
Under the radar
Trackrash's Avatar
I spent a half an hour shooting them across the garage and digging them out of the motor, before I gave up and made a tool to do the job. Took 15 minutes to make the tool and then 30 seconds each to install them.
Gordon
Old 05-03-2017, 07:17 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #139 (permalink)
DRACO A5OG's Avatar
Thumbs up Success!
Ah man, are those JE clips bigger than CP's? I thought they were the same thickness. I must be lucky.
Well in any case, all ready to go back into the car.
For the heck of it, actually in retrospect, I should have done this the first time. May have found the leak but the head stud did not pull then, Hmmm.
I did a cold leak down on stand at 100 PSI:
#1 90/88 (2%)
#6 90/86 (4%)*
#2 90/88 (2%)
#4 90/86 (4%)*
#3 90/88 (2%)
#5 90/87 (3%)*
So within 2% of each other cold seems pretty good, no?
*I suspect due to me having to remove the cylinders on P-side because of the lost of that freakin wrist pin clip, I had to re-clock/confirm the ring positions. Will need to break them in again :-). Happy the D-side kept consistent
Cigar Smoke tested, no leaks.
'85 Carrera Targa
PCA/POC
Old 05-03-2017, 10:38 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #140 (permalink)
