LinkBack Thread Tools Rating: Thread Rating: 3 votes, 2.33 average.
Navin Johnson
TimT's Avatar
This is a major artery into L.A. At first they were talking 3 to 5 weeks. They did it in less than 10 days.
No way is something like that going to happen here...
Depending on the design of the replacement...i.e. steel truss, precast concrete, cable stayed, simply procuring and fabricating the the various elements takes time.. Evn though this project will definately be "accelerated"
Steel mills don't have stock of millions of pounds of various shapes "in-stock", with a project like this pressure will be put on the mills to "cut the line" and roll the required shapes for this bridge ahead of current orders..
Ordering bulk steels shapes usually takes months.. and certain shapes are not even rolled in the States..
Many of the jobs I've worked on have a Buy American Clause in the specs.. One job in particular the contactors detailer specified a shape that was not rolled in the States... an exception was made because of time constraints and redesign costs.. The shapes were sourced from a mill in Germany
Just some pics from the Manual of Steel Construction.. I have the Silver more recent addition somewhere..
The designer has to strike a balance of the lightest member, the most economical construction method, availability, domesticity.
Mill don't have stock of all the various weights of shapes.. Contractor need to order the shapes, then wait in line for the mills to produce the members required.. The the raw product is shipped to a fabricator to cut and drill the pieces.. mills sometimes only cut certain lengths.. So if you need a 46' member, and the mill only supplies 50 footers... you get 4' of waste on every piece...
What goes on behind the scenes to build infrastructure is really remarkable...
Some shots from the Steel Manual
Founds this calc in the Manual... have no Idea what I was designing..
'69 911 GT-5
'75 914 GT-3
and others
Old 04-01-2024, 03:06 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #181 (permalink)
Navin Johnson
TimT's Avatar
This is NOT a concern. We have pipelines all over the place here
Apparently you've never seen the results of a fracture high pressure line..
If the bridge sinking impacted the pipeline.. there can be damage removed from the point of impact..
Also gas leaking underground has this odd habit of following the trench.. makes for interesting situations in populated areas
'69 911 GT-5
'75 914 GT-3
and others
Old 04-01-2024, 03:17 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #182 (permalink)
Bland
unclebilly's Avatar
Don't be so sure... I've been the professional engineer that did the failure analysis on fractured and blown high pressure lines (rated to 15,000 psi) several times. And I've written peer reviewed SPE papers on the matter, one made the JPT.
We also deal with sour gas pipelines here - not something you have much of in the US. When H2S leaks, people die. Failures involving H2S usually involve HIC but thats a different story.
Old 04-01-2024, 03:30 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #183 (permalink)
Bland
unclebilly's Avatar
If this was a priority, there would be several parallel paths already in play. I'm not sure there are.
One of those paths would be reviewing the original design to see what changes could be made to bring it up to 'current day standards' and replicated it which is likely the fastest and simplist path.
Another path would be looking at what options exist for temporary (floating?) bridging with a (re)movable section to enable ship traffic.
Complete replacement would be another path.
I imagine a concrete plant will be setup very close by - this is something that will be needed regardless of the path chosen and could be happening now. Are they looking at concrete suppliers yet?
Steel procurement could also be taking place. Form factor yet to be determined, but the quantities needed are several mill runs. Where are we at with this? I expect the steel grade will be fairly standard regardless of the design path.
There are lots of other things anyone who has ever been involved in construction PM could point out that aren't on the critical path yet but will be when they stop making excuses and start doing stuff.
Old 04-01-2024, 03:39 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #184 (permalink)
A930Rocket's Avatar
Atlanta had a fire under one of their freeway bridges and repaired it quickly as well.
Old 04-01-2024, 05:06 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #185 (permalink)
Depending on the design of the replacement...-snip-
Tim - thanks for your commentary here. Please continue at your discretion. Thanks!
Old 04-01-2024, 08:13 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #186 (permalink)
I see you
flatbutt's Avatar
Sonar images of the submerged wreckage
https://www.dvidshub.net/image/8316597/navy-3d-sonar-images-reveals-challenges-salvaging-baltimores-francis-scott-key-bridge-wreckage
Old 04-02-2024, 06:11 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #187 (permalink)
By-pass channel is open and being used for smaller vessels.
https://www.yahoo.com/news/first-vessel-uses-alternate-channel-131420802.html
78 SC Targa Black....gone
84 Carrera Targa White
98 Honda Prelude
22 Honda Civic SI
Old 04-02-2024, 07:34 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #188 (permalink)
HobieMarty's Avatar
https://youtu.be/kz9pc6_ZiIM?si=VCwIB4nT7jhtQnHP
Wonka
Old 04-02-2024, 11:19 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #189 (permalink)
Thanks, I like his updates
Southwest Oklahoma
Old 04-02-2024, 11:31 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #190 (permalink)
Bland
unclebilly's Avatar
SPOT ON!
When 'everyone' is in charge, nobody is in charge, hence the scattered approach that I elluded to above.
It is great to see the crane and barges starting to remove debris. I also like the idea of a bypass channel, albeit shallow.
Old 04-02-2024, 12:14 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #191 (permalink)
I saw on the news that the Singapore company that owns the ship has filed papers saying they are not responsible. Yea right. Just keep the ship and cargo until their insurance company pays for the cleanup and new bridge.
Old 04-02-2024, 04:20 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #192 (permalink)
WPOZZZ's Avatar
What I read was they used some 1851 Maritime law to limit their liability to the value of the ship.
https://fortune.com/2024/04/01/baltimore-francis-scott-key-bridge-liability-cap-44-million-singapore/
Old 04-02-2024, 05:11 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #193 (permalink)
HobieMarty's Avatar
https://youtu.be/l-DAZqTZCb8?si=D9M2LvpAfO5F8Gvm
Long video but really informative.
Wonka
Old 04-02-2024, 09:26 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #194 (permalink)
Driver
Noah930's Avatar
That's like saying because my POS car is only worth $500, that's the maximum I should be liable for if I crash into your car/house/family. Start freezing their assets and sell them off if need be to pay for this cleanup and loss of business/income.
1990 Black 964 C2 Targa
Old 04-02-2024, 10:09 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #195 (permalink)
HobieMarty's Avatar
https://youtu.be/72SlDMN7_7A?si=48p34wCyiVrAz3lx
Wonka
Old 04-04-2024, 09:14 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #196 (permalink)
Navin Johnson
TimT's Avatar
This is for the tinfoil hat crowd
https://www.usnews.com/news/us/articles/2024-04-03/what-do-a-top-secret-cia-mission-and-the-maryland-bridge-wreck-have-in-common-well-the-same-crane
'69 911 GT-5
'75 914 GT-3
and others
Old 04-05-2024, 02:07 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #197 (permalink)
Edministrator
Steve Carlton's Avatar
How so?
Good post? Leave a tip!
O - $1
O - $2
O - $3
Old 04-05-2024, 02:19 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #198 (permalink)
Still here
pmax's Avatar
Old 04-05-2024, 04:11 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #199 (permalink)
I see you
flatbutt's Avatar
Originally Posted by pmax View Post
what is that?
Old 04-06-2024, 04:43 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #200 (permalink)
