Then you lose the single biggest advantage to the lever gun - the ability to keep topping it off without taking it out of action.  With a pocket (or two) full of ammo, you can stuff a couple of more in the loading gate at any lull in activities, without taking your eyes off of the threat, purely by feel.
	Jeff '72 911T 3.0 MFI '93 Ducati 900 Super Sport "God invented whiskey so the Irish wouldn't rule the world"  |
			 Somewhere in the Midwest
			That was a consideration and I'm looking for a bolt action that has a drop down magazine, like a CZ.
 I think too many people confuse military weapons for civilian weapons. Situations where one will require them are vastly different. In the military, you will normally have all the gear - like the proper clothing for carrying several extra magazines, and your fellow soldiers to provide cover if you empty your rifle and/or magazines. In a civilian SHTF scenario, you will likely have none of that. You will be on your own. A reliable lever gun, with several pockets full of ammo, will be far more useful. You can keep it "full" while on the move; it is essentially self-contained with nothing else to missplace or lose along the way. The only thing you leave behind is empty shells.
			I do have other gear to choose from
	 . But for arguement sake, how much ammo can you easily stash in your pockets before it becomes cumbersome? Anymore so than fishing out a 30 round mag from a side bag or chest rig? In a SHTF situ I would guess that a well prep'd gunner will have several loaded mags ready and dropping a few empty ones in the heat of battle is not a major concern. What's in you bug out bag? ![]() Really I am not dogging the lever gun, but I kinda like the semi-auto with 30 rounds or even a drum if need be. If by the time I run out of loaded mags things are pretty bad. Probably worst off if I had had a lever gun while trying to load 300+ rounds...min that a SHTF needs in loaded 30 rd mags
			Still is a 5.56 round at a disadvantage in urban combat when the enemy has a larger caliber?  I say urban because the 5.56 lacks punch compared to a 7.62 and it's likely to be the case in civil unrest.   One would want more penetrating punch no?
	So back to the 7.62. But not in an AK?  |
			 Cars & Coffee Killer
			How do the 70 grain .223 bullets compare in weight to .30 cal?
	Some Porsches long ago...then a wankle... 5 liters of VVT fury now -Chris "There is freedom in risk, just as there is oppression in security."  |
			 canna change law physics
			Why not both?
			I have rifles in most of the "common" calibers, just in case in need to forage ammo. .22LR 5.56 Nato 7.62x39 30-06 7.62x51
	James The pessimist complains about the wind; the optimist expects it to change; the engineer adjusts the sails.- William Arthur Ward (1921-1994) Red-beard for President, 2020  |
			 A Man of Wealth and Taste
 The Arsenals are copies of the Bulgarian AK's. They use the same tooling. The only comment is that the Milled Receiver whether it is Chink, Russkie or Bulgarian is BETTER than Stamped>. It is stiffer and doesn't flex.
	Copyright "Some Observer"  |
			 Banned
 I honestly just don't like AK style sights at all. Last edited by m21sniper; 09-09-2009 at 02:59 PM..  |
			 Banned
 Mini-14's are great rifles too. Quote:
 ![]() Quote:
 You can do this with a shotgun too. If i was going to go the tube fed route, i'd get a 12 gauge semi as opposed to a center-fire lever action, but that's just me. PS: My tac vest will hold 8x30rd mags and 10x 20rd mags. That's 440rd's, plus the mag in the weapon... Quote:
 Supposedly it will penetrate an engine block as long as the range is greater than about 50 meters. Inside that range, and the high velocity just causes it to grenade on impact....or so i hear. I have never actually shot an engine block at any range with M855 or any 5.56mm or 7.62mm rounds. If you want good penetration, a good 12 gauge semi firing .50cal 3" magnum sabot slugs would probably be hard to beat. Last edited by m21sniper; 09-09-2009 at 03:00 PM..  |
		![]() If you are considering the AR platform and/or a .308 bolt action, you might consider an AR in .308. Pretty nice compromise IMO, and plenty of quality versions out there (from mild to wild).  |
			 Banned
			I so wish someone would make an AR in .220 swift. That would be a neat-o toy.
			I don't need another AR. ..well maybe a couple more barrels for larger caliber, but then a solid AK with cheap ammo would satisfy the need for more punch.
			I am considering a .308AR just because. Tabs - the conclusion was the result of your post but a general though based on what I read here and on other forums. I'll look for a milled receiver example that's imported and see if it will satisfy the role as a all around beater with punch. Quote:
			Snipe - the reviews for a mini-30 aren't very favorable.  Twice the cost of an AK, harder to fine mags and not as reliable as an AK.  I admit I like the idea of a mini-30 but it doesn't sound like a winner.
			So are all BUL, CHN and RUS made with milled still recivers?
			Anything wrong with this? I assume it has a milled reciever:
			http://www.centerfiresystems.com/AKAGUNUF.aspx and why are Saigas cheaper? Last edited by MotoSook; 09-09-2009 at 07:11 PM..  |
			Ok so what are some milled receiver types?
	Don't they sell stripped milled receivers?  |
 I'm a huge fan of the old Swift. I've owned a rifle of one description or another in that caliber for over 30 years. The one downside to it is that it absolutely will not survive any sort of rapid fire or, for that matter, even any sort of sustained fire. It builds barrel heat very, very quickly, and then begins to erode the throat at an exceedingly rapid rate. While certainly not nearly as bad as its reputation, that reputation is not without some foundation. My current Swift is built on a Ruger #1 action. It wears a 28" Lilja stainless barrel, 1:12" twist. I like the single shot approach to the Swift, as it reminds me to slow down. A shot every few minutes is about as hard as you want to push one of these. They simply will not tolerate any sort of sustained fire. In an autoloader, I would venture to guess a guy could ruin a barrel with one 20 round magazine, if he tried to empty that mag as quickly as possible. Not a good marriage of cartridge/weapon.
			 Banned
 How about an M1A( M-14)? Pricey, but damn nice. Last edited by m21sniper; 09-10-2009 at 08:10 AM..  |
