canna change law physics
iPhone 100%
Since the latest up date of iOS, my 4GS iPhone has 100% battery. I take it off the charger, I take phone calls, leave it off the charger, and it still is 100% battery.
Anyone else seeing this?
James The pessimist complains about the wind; the optimist expects it to change; the engineer adjusts the sails.- William Arthur Ward (1921-1994) Red-beard for President, 2020 |
Cool. a battery that never discharges
![]() My iPhone 5 works fine on the latest OS. No issues with it. I guess I got lucky.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
1 hour later, I'm at 99%
Mine did this once and then, blam, I tried to "wake it" and it was deader than a doornail. I have a feeling that if you restart it, it will show the actual battery charge.
Mike 1976 Euro 911 3.2 w/10.3 compression & SSIs 22/29 torsions, 22/22 adjustable sways, Carrera brakes |
I rebooted it and no change. I'll "recalibrate" it by fully discharging it and recharging it.
Huh.... My 4S has had terrible battery life after the last update....
This is of great interest to me because my POS Droid Razr Maxx hasn't worked completely in the entire year or so that I've owned it.
My 4GS goes for days. It does seem the rate of discharge increases ad the phone discharges.
Did you get the memo?
‘07 Mazda RX8-8 Past: 911T, 911SC, Carrera, 951s, 955, 996s, 987s, 986s, 997s, BMW 5x, C36, C63, XJR, S8, Maserati Coupe, GT500, etc |
+1 same exact problem I've had.
2021 Model Y 2005 Cayenne Turbo 2012 Panamera 4S 1980 911 SC 1999 996 Cab |
I read that some iPhones are seeing decreased battery life with the latest iOS version. There's a thread on Apple's discussion forums.
Ron '88 Coupe (formerly) |
That happens occasionally with updates.... They code something wrong and it keeps polling signal or running some process that munches through battery. Id expect another update soon....
now 82%. I definitely think the calibration is off. Again, I'm going to drain it dead and then recharge.
Exchange issues have been the major cause of battery problems. I had it with a recent one. SOP for some (now me) is to remove your exchange account before or after you update, then add it back after running the update. That often will prevent or fix a problem, and cured my battery death issue the one time it happened to me. No issues with the last one though and I didn't remove beforehand. THere are a lot of variables involved with battery life - types of email accounts, how you have them configured, if you're streaming media, etc.
No issues with my 4S with all the latest updates.
Dan 2002 996 C4 Cab w/ Jake Raby 4.0 2024 Tacoma TRD Offroad 4x4 2003 Range Rover HSE |
Well, I ran it down until it turned off and then recharged. Still doing it.
One site says you need to let it sit uncharged for 8 hours before recharging.
Senior Advisor
try this, click the lower button twice quickly and a small window opens up at the bottom of the screen. Then press and hold a icon till the (-) sign appears above the icon and they start to wiggle. Then press again to remove them (it closes them). this help save battery life by closing apps that are running in the background.
08 Cayenne Turbo |
Lowering the screen brightness to about 75% helps save battery life too. Works especially well on the iPad.
'84 Carrera Cabriolet |
I guess you're not getting it. The battery LIFE is fine, the battery calibration is off. It reads 100% for a good hour off the charger.
Senior Advisor
well, i do all the tricks and mine lasts 3-4 days without charging (I4, 3 years old), always hook it up around 50%. So your saying it stays at 100% for an hour or two? i'm at 94% after 6 hours off charger, talking on Skype and taking 2 calls, getting email (and deleting it) I think your ok, try to see how long it lasts till it's down to 10% ooops, already did that, but, how long did it last not on the charger?
08 Cayenne Turbo Last edited by James Brown; 03-29-2013 at 04:28 PM.. |
