Yes,
I certainly did not buy this car for the 1/4 mile... |
It's extra width also creates huge drag. A narrow-bodied Carrera with sport pack option (common) would give it a run for its money. The benefit of bigger brakes is really only good for reduced fade as either will lock your wheels with ease.
Chris - - - - - - - - - - - - - - - - - - - - - 1982 911 SC Hellblau Metalic - - - - - - - - - - - - - - - - - - - - - 1997 Boxster 986 2.5l |
How unimportant is it? Why do so many narrow body owners upgrade to bigger bakes then?
85 911 SuperSport No more looking! The jewel is mine! 89 Jeep Wrangler A jewel in the rough 2000 Grand Cherokee Family Wagon with Jewels on board |
Somewhere in the Midwest
Lets keep this thread about backdating gang. How about taking the Turbo-look versus the rest brake merits discussion to a new thread?
Jens: Your car looks mean and all business just the way it is! Sure a longhood would look good too, but....oh man! Decisions decisions! ![]() |
Great, keep us posted.
And Jens, the wife just called your car cute. I think it is time to backdate. ;-) Just kidding Dean
Dean 911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno, |
backdating question #2
RS door panels? How is the door release actuated and are these worth the installation. Can I still put a speaker and the electric window switches in it? I've seen plenty of different ones advertised; where is the best place to find a quality set? P.S. Would two black panels look gaudy with my blue leather interior? I'm eventually going to change the interior to black because no one makes anything in blue.
Paul 1980 911SC Targa - Sold 1972 914 - Sold |
Schleprock
RS door panels use a pull strap to open the door.
You can put whatever you want in the door panel. Depending on where you get them, you can specify exactly which features (power or manual windows, speaker(s), etc.) you want and they'll make them up for you as you request. Good writeup here from TurboRuf: RSA Door Panel How-To I think the black would look fine in a blue car. Most people probably wouldn't notice otherwise if you didn't mention the black panels.
Kevin L '86 Carrera "Larry" |
Thanks, KTL.
That thread was exactly what I needed. Now I need a second job. Quote:
Any update on the availablity of the parts from Series900?
I need the parts for the frontend.
Time Bandit
Jens RatBasterd- '70ish Ltwt Coupe, Factory IMSA RSR Bilstein coilovers, 993TT Brembos (Singer brakes) slotted & drilled, tweaked 3.0Ltr, 911R/ST pipes, DAS roll bar |
Time Bandit
Senior Member
Souk,
I am trying to wire up the final things, front turn signals and headlights. How did you do this on your car? My '85 model has a wiring loom that goes all the way out to the headlight and turn signal, while the early style turn signals have a socket that plugs into the trunk bulkhead then the car chassis wiring loom goes into this and completes everything. Do not want to reinvent everything and hope someone else has been through this before. Joe A
2013 Jag XF, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
Joe:
I just determined what the leads are for each (chassis and early harness...ground, marker and turn signal leads). The early lights I got did not have the connectors, just pig tails on the harness. I connected the corresponding wires using spade connectors so I can take the fenders off fast for changing out track-street fenders. |
Senior Member
Thanks! Will work the two harnesses together this way.
Joe
Has any one ever removed the center console.
I pulled my out to remove the AC wiring and I like the look. I think I'll be backdating to the old stick on the floor look. The console is pretty useless anyways. It probably weighs a freaking pound or two. After I clean up the car, I'll post a pick.
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
Well, mine might be for sale pretty soon.
