really well done
ECU Doctors has them and recommended Bosch part 0 261 204 376 with Driveblock removed. My research shows it’s for a Tiptronic 3.6. They said it should be an issue because the ECU can sense if it’s a Tip and a Tip has its own ECU.
Anyone know for sure if it’ll work ok with my 915? They said if there are any issues to send it back for up to five years and they’ll make whatever modifications that are necessary.
"Purists are the Karens of motorsports. IG - Iron_Dad_Moto 1972 Porsche 911 - Long Term Project. 3.6TT/G96.50 1981 Porsche 911SC - In Progress. F/A-18C/D, F-15C, F-35B/C |
The original mg. /44 was better in this respect as it came stock w/ a steel girdle stabilizing the si/o shafts, I also went w/ a /67 for the trans cooling feature but recomens adding a steel girdle here too.
on a 55 pin DME I think that it is pin 44 that activates tip coding
If you ever find yourself in San Diego, you bar tab is on me.
"Purists are the Karens of motorsports. IG - Iron_Dad_Moto 1972 Porsche 911 - Long Term Project. 3.6TT/G96.50 1981 Porsche 911SC - In Progress. F/A-18C/D, F-15C, F-35B/C Last edited by Ryan_Cunningham; 07-23-2025 at 05:45 PM.. |
Nice build @plexiform
-Jay '74 Mexico Blue 911 3.0 EFI (Fast and Loud) '70 914/6 Race Car (Faster and Louder) '71 73RSR tribute vintage race car 3.0 '68 SWB 911T "RENNRAT" 2.8 twin plug/915 gearbox '81 Magenta IROC clone in progress 3.6 varioram/G50 |
Thank you both! Drives amazing but now I'm thinking it might be time to see what a modern Porsche race car is like. But sadly prices of modern GT3s are so insane that may never happen.
1975 911s Restomod, 2005 MV Agusta F4 AGO, 2002 Moto Guzzi V11 Scura, 1983 BMW R100RT, 1978 R100S, 1989 R100RS, 1991 R100 classic (x2), 2023 Ford F150 Lightning SOLD: 93 R100R, 03 R1150GSA, 85 R100S Mono, 03 996 turbo, 16 Norton 961 Commando, 03 R1100s BCR, 77 R100s, 09 S63 AMG, 74 911, 88 R100RS, 78 930, 01 996 C4, 05 Cayenne, 09 Audi TT, 03 Moto Guzzi V11 LeMans, 07 WRX STI, 03 R1150GSA, 78 R100/7, 01 Audi S4, 98 Audi A4, 98 R1200c, 78 GL1000, 92 Accord, 89 KE100 |
![]() trans is still #42 I think that you need #56 & 82 the tip has a different way to control idle from the manual, I think I recall a TPS and stepping motor on the throttle
Follow me on instagram, @flyin.hawaiin www.davekealoha.com |
Getting closer… soon to be IROC tribute. Hope to be running next week after ECU comes back from specialized ECU. Then off to paint, wife got to choose one of the IROC colors, she chose Magenta, will see if I can commit to it soon enough. 1982 chassis with 1989 930 turbo G50 torsion tube and trailing arms grafted in.
-Jay '74 Mexico Blue 911 3.0 EFI (Fast and Loud) '70 914/6 Race Car (Faster and Louder) '71 73RSR tribute vintage race car 3.0 '68 SWB 911T "RENNRAT" 2.8 twin plug/915 gearbox '81 Magenta IROC clone in progress 3.6 varioram/G50 Last edited by jmz; 07-24-2025 at 12:53 PM.. |
Kind of looks like a short hood ST right now but the plan is RSR IROC tribute
![]() This one has a 3,6 conversion included the 964 gear box and RS92 brakes. |
And there is absolutely zero room up top.
Congrats man! It's in there. Mine is tight like that too. Zero clearance on the vram to go higher.
Your fan scavenge thing is cool looking. Haven't seen that flavor yet. I heavily modified the rennline CF tube on mine but it leaks at the bottom where the exhaust side and it meet at the tin opening.
Hopefully it's at least worth reading. |
Is that the new version of Fabspeed on yours? If so let us know how it sounds, i love my 3yr old console version.
Any issue with your exhaust bottoming out on speed bumps? Thinking about raising the rear 10-15mm and trying to rotate the exhaust to get a bit more clearance before I just pull it all out and buy a new tin. I want to start this thing!
It is. I’ll post a video once it’s running.
This is what my car looks like. It usually only scrapes on steep driveway transitions and the largest speed bumps.
Thread Tools | |
Rate This Thread | |
