Administrator
In 2000, I had a 1993 3.6 put into my 1973 tub: ![]() But then I totaled the car by hitting a wall at Laguna Seca at the end of 2002, and the drivetrain went into version 2 of the car. 1972 911T Non-Sunroof Coupe (9112100777) ![]() Suspension and Brake mods 930 Brakes Front JRZ single-adjustable struts, modified by ERP and Tyson Schmidt, including raised and re-cambered spindles and extended control arms (by Tyson and also FABCAR), 23mm torsion bars Front upper strut mounts modified for additional caster by TRE Motorsports Elephant Racing front Monoballs Turbo Tie Rods with ERP bump steer kit Elephant Racing triangulated strut brace Aluminum front crossmember Smart Racing 23mm front antiswaybar Aluminum rear trailing arms with Smart Racing Camber Boxes and monoballs Smart Racing 23mm rear antisway bar ERP 935-style spring plates Rear Bilstein struts and adjustable inserts with 600# coil-overs ![]() Engine, Driveline and Oil Cooling mods 3.6 liter engine from 1993 C2 I-G Engine Swap Kit, with NBD 2-position performance chip B&B Headers, Flowmaster muffler Expanded-capacity 72 oil tank ahead of rear axle Dual front fender oil coolers 8:31 transaxle with custom 2nd, 4th and 5th, 141 mph max gearing, internal swaybar and external cooler Wevo shifter, coupler, and internal gate-shift Guard Transmission ZF-type limited slip, set at 80% ![]() Body and Misc mods 9.5x11x17 2-piece Lindsey Racing Fuchs-centered wheels with polished spokes Fiberglass RSR front fenders, bumpers, hood, doors, rear quarters, by Rennspeed Motorsports RSR-style reinforcements to rear shock towers, caps, and rear crossmember 965 leather dash, leather Recaro SPG Pole Position seats Center console with battery, CHT and trans temp gauges Safety Devices full cage with 8 attachment points Lindsey Racing 3-outlet 5 lb Halon fire suppression system 37-degree Air Conditioning with Performance Aire underbelly condenser 3.8RS tail with extensions and 50-inch wing Ducktail for street driving
Jack Olsen 1972 911 My new video about my garage. • A video from German TV about my 911 |
Insert Tag Line HERE.....
72 tub, 95 993 3.6
RETIRED
Hey, Tyson and or Jack....how much is the add piece for the 3.8 wing?
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Administrator
60-inch wing, uprights and endcaps, at GT Racing will set you back over $1,200.
![]() I made my own end caps, had KevinP73 make me a set of uprights, and got a slightly-misformed wing for free from the manufacturer (who couldn't sell it). There's got to be a way to get the wings cheaper. It's a very simple part.
Picture is pre modifications....
Engine '97 3.6 Vario-Ram [13,600 original miles] Wevo semi solid engine mounts no heat, no air 3" resonator tips direct from cats Turbo clutch Suspension Elephant 23 front, 29 rear torsion bars Elephant adjustable sway bars front and rear Elephant poly/bronze throughout Elephant low friction a-arm mounts Rennsport mono balls front and rear Rennsport triangulated strut brace Bilstein Sport rear, HD front 7" X 16" front, 8" x 16" rear W/1 1/8" spacers [H&R] Lowered WAY down there.....rolled the left front fender using a piece of 1" PVC schedule 40 and a hammer! Experts said the suspension was going to beat me to death. They were wrong.....comfortable but PLANTED. Body Took the big, ugly turbo whale tail off, had the holes plugged the old fashioned way [with metal, by hand] and repainted. Looking for a way to mount a removeable wing without drilling holes in the outside [visible] metal. The early '87-'89 Carreras look so much better without the wings [just my opinion, of course]. Drums ![]()
'89 G50 w/ 3.6 V-Ram-now Ca. legal! FORMER Yosemite Chapter PCA V. P. |
Sorry guys-wrong picture. The picture is of a lake in the forbidden zone section of Yosemite National Park. PM me if you would like to know where it is.
Drums ![]()
Where's Muffinman(Rob f) and Joe A.??
This is definitely a cool thread...I'll add to it.
1977 911S '97 3.6 Varioram w/ Weiner reflashed ECU (details here) 993 factory heat exchangers & Triad muffler (pics here) SC rear flares 930S front spoiler Factory Carrera tail 993 TT big red brakes (details here) Custom brake ducting...CFD flow tested 17x8 & 9" Fikse FM10s Guard Transmission 40% LSD B&B FPOR-9400 front oil cooler & RS duct (details here) WEVO shift coupler WEVO shifter Odyssey battery in smuggler's box (details here) Momo Corse steering wheel Sparco Supersport suede seats Suspension (details here) 23/33 Sander torsion bars 22/22 weltmeister adjustable sway bars Elephant Racing Polybronze bearings front & rear Elephant Racing rear trailing arm sealed monoballs Front strut bar Front strut top monoballs Custom-valved rear RSR shocks shortened 1" Custom-valved RSR struts with ~48mm raised spindles & decambered 1 degree ERP bump steer kit Elephant Racing offset ball joints I'm sure I forgot some things, but that's the bulk of it...the car is an absolute joy to drive. ![]() ![]()
Rob Fusi 77 911S | 3.6 Varioram | Triad Muffler | B&B 9400 Cooler |WEVO everything | Big Reds | 23/33 | 22/22 sways | Polybronze | RSR shocks/struts | FM10s | GTC Motorsports Last edited by MuffinMan; 09-03-2005 at 05:58 PM.. |
Here are a couple of oldies but goodies. Note, these are with the old suspension.
Rob Fusi 77 911S | 3.6 Varioram | Triad Muffler | B&B 9400 Cooler |WEVO everything | Big Reds | 23/33 | 22/22 sways | Polybronze | RSR shocks/struts | FM10s | GTC Motorsports Last edited by MuffinMan; 09-03-2005 at 05:34 PM.. |
Senior Member
I bought Bill's 964 3.6 and stuffed it into my '85 Targa. While doing so backdated the car to look like a '72 RS.
Stock engine and 915 gearbox. Suspension and brake updates to follow. JoeA ![]() ![]()
2013 Jag XF, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
89 G-50 Carrera Targa with
-97 3.6 Varioram -930 brakes -22/29 t-bars -7's and 9's -Koni Yellows -Recaro SRD's -etc., etc., etc., ![]()
Mike 89 Carrera 3.6 V-ram #94 Livin' for Targa time! Want to make God laugh? Tell him your plans! Last edited by Mike Feinstein; 09-03-2005 at 06:18 PM.. |
Mike 89 Carrera 3.6 V-ram #94 Livin' for Targa time! Want to make God laugh? Tell him your plans! Last edited by Mike Feinstein; 09-03-2005 at 06:24 PM.. |
One more...
Mike 89 Carrera 3.6 V-ram #94 Livin' for Targa time! Want to make God laugh? Tell him your plans! |
Jack,
Was that SC rear flairs on your old 73?
Derek Oxford PCA - Nationally Certified Instructor 2002 Boxster S ( race car) 2010 LR4 2009 GMC Sierra (Porsche Support 2011 M3 4Door Last edited by deoxford; 09-03-2005 at 08:28 PM.. |
'79 SC with a '95 3.6, short gears, new suspension and 930 brakes. 2280# with half tank of gas.
Administrator
Guys, I've counted 21 3.6 conversions so far. GREAT LOOKING CARS !!! Keep them coming
Are 'in-progress' 3.6 conversions allowed?
'89 3.2/3.6 coupe |
Guess so !!!
There is a couple we have done.
One is a 72RSR with a 92 RSA engine and a 73 911 race car with a 93 965 turbo engine in it. ![]() ![]()
Thanks! Don Ramsay E Mail: aircooledclassicsporsche@gmail.com The father of 964 Backdating! ![]() www.aircooledclassics.co www.facebook.com/AirCooledClassicsPorsche/ www.instagram.com/aircooledclassicsporsche/ |
Thread Tools | |
Rate This Thread | |
