RETIRED
Joe Bob's Avatar
Mine are hooked into my turn signal circuit.....
2012 ML350 3.0 Turbo Diesel
Old 05-30-2008, 03:44 PM
KatoKato's Avatar
I checked it out and the delay works as it should. When I open the door the fogs go out....
As for moving the power windows to fuse#2 - I did for a while and then moved them back.
I had to remove the crimped piece of metal binding the copper together on the end of the power window wire and twisted the copper from the foglight relay onto that. I did fit much better into fuse#1 this way.
Thanks for the help ....
Kato
Old 06-30-2008, 07:32 AM
Habitual User
BLEW911's Avatar
OK experts, as you can see I have no grey wire on the bottom of fuse # 5. On my '80, the 1st fuse is fogs and the 5th is low beam right. can you tell me what bottom grey wire to move and to where? No guessing please.
#2 has a grey wire on the bottom ( the only one ). #2 is license plate light.
Don
'80 911 Targa
Old 09-28-2008, 03:36 PM
davidrivers's Avatar
Hey Don..
Try disconnecting the grey wire from the #2 fuse and see if the foglights still work. If they do not, then that is the correct wire to move.
1984 911 Cabriolet - Destroyed :-( - Looking for the next one..
1997 M3 sedan - Daily Driver
1988 Ferrari 328 GTS - Needs to be driven more
Old 10-05-2008, 08:57 PM
dfk911sc's Avatar
subscribed
Dan - schnell fahren, leben hart
83 RoW 911 SC Cab
SCWDP Conspirator
C.R.A.P Gruppe Registry #27
Old 10-09-2008, 01:44 AM
orange911's Avatar
subscribed
Regards,
Olin
1972 911T w/Carrera 3.0 - Light Yellow
1994 964 30 Jahre 911 - Viola metallic
Old 12-08-2008, 06:12 PM
Oracle's Avatar
You can force the Fog lights relay to the ON position so everytime you turn the key the fog lights go on.. (at least in the 964 there is a relay, don't know about 911 thou... I can't remember.)
Anyway I wrote about it here: http://forums.rennlist.com/rennforums/showthread.php?t=292399
Good luck!
We're all in the gutter,but some of us are looking at the stars.
-Oscar Wilde
Old 12-08-2008, 09:13 PM
In my 89, when I put the parking light/headlight switch in the "parking light" (first detent) position, and turn on my fogs, they come on. As the switch isn't activating the headlights, no headlights, only fogs.
I had thought this was standard?
89 Carrera 3.4
"There is a right way to go around a corner - it's called the line." -- PCA DE speaker
bryteside.com - good things happen.
Old 12-09-2008, 06:31 AM
Member 911 Anonymous
DRACO A5OG's Avatar
Question Any Updates on Mod?
Hey Fellas,
Reviving this old thread.
I did not intend to make this mod but my Fog Light Switch's internal capacitor burned out and no longer illuminates the internal light, Tested it on a 9 volt source and it lit up fine. The worse thing is that it would cause a surge and blow the #8 (#18) Fuse to the Fog Lights.
I ordered a new switch but in the meantime, I jimmed the two Fog Light wire to #7 fuse where the License Plate wire comes out from. Disabled #8 and insulated the wires. This also by passed the Fog Light Relay all together.
To my amazement, it worked. But I did have to replace the 5 amp to an 8 amp fuse. I know that is bad.
I really like the fact that the fog lights turn on when parking light are on.
I wondered if everyones mod is doing fine and no issues came up due to the mod?
Also has anyone moded like me and if so, did you place a relay on the two wires?
'85 Carrera Targa
PCA/POC
Old 07-28-2009, 06:01 PM
zugelassener benutzer
teamfee3's Avatar
Fog lights to running lights
Thanks to all, I just did this on my '86 and it took 30 seconds, very cool!
Team Fee '86 Carrera 3.2 Coupe blk/blk, no wing
7&9x16s BFG GForce SS 205/55 & 245/50s, SW Chip, Maxspeed catbypass, B&B, Sachs Power Clutch, Turbo mounts, oil cooler scoop, RS door panels, Momo Prototipo, Rennline fully adj gas pedal & floorboard, RS replica dead pedal, Weltmeister yellow h/l lenses, factory short shift, custom speedo
32C #7
Old 03-07-2010, 11:56 AM
I'm a loser, baby.
oregonmon's Avatar
Don
Ok, reviving this thread too. I have a wiring setup like this so, I'm not sure which wire to switch. The 2nd wire from the right (gray for 79SC) says license plate and fog relay). I tried moving that one to different fuse but it didn't do anything to the fogs.
The 1st set of two white wires on the right are fog according to Bentley but do I move both or what?
It seems the 78,79s are a little different than the others posted.
1979 911 SC
Old 05-12-2010, 09:56 PM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Originally Posted by KatoKato View Post
Is there an easy way to make it possible to turn the fog lights on without having the main lights on?
In this scenario I would like to keep them switched with the ignition.
Cheers,
Kato
Kato,
For your '86, move the grey wire to fuse #10.
Good luck,
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 05-13-2010, 06:48 AM
Ckt
1986 911 Targa.
Only in L.A.:
Old 05-13-2010, 06:51 AM
Thrlls's Avatar
Does anyone know if the '84 wiring is the same as the '86?
Looks like this would be nice to have at dawn/dusk prior to needing the H4s.
Woody
Slow n Fast
1984 Guards Red 911 Carrera
Old 05-13-2010, 11:21 AM
The circuit is the same, but the fuse panel is not.
The #10 fuse on the '86 is assigned to:
1. Heated windshield nozzles.
2. Rear window wiper.
3. Windshield wiper switch.
4. Wiper delay relay.
1986 911 Targa.
Only in L.A.:
Old 05-13-2010, 12:13 PM
I'm a loser, baby.
oregonmon's Avatar
Can anyone help on my 79 with my post from above?
Old 05-13-2010, 12:21 PM
Brillo's Avatar
I am interested for mine as well.
Ray H.
1979 911SC Coupe
2000 986
Old 05-25-2010, 02:32 PM
Thrlls's Avatar
Mahalo...I'll check this out when the car comes back from the Dr.
Woody
Slow n Fast
Old 05-25-2010, 04:45 PM
subscribe
Its easier asking dumb questions than fixing dumb mistakes
1974 Porsche 911 Coupe, RSR Project
1976 Porsche 911 Targa, Black
1986 Porsche 911 Carrera, Black
2006 Porsche Cayenne S, Black
Old 10-10-2011, 03:59 PM
Brillo's Avatar
Question
Did you ever figure this out?
Ray H.
1979 911SC Coupe
2000 986
Old 10-10-2011, 06:02 PM
