Throw it on the ground!
Why does only one gauge fog up?
Seems like I've read other posts indicating the propensity for only the oil/temp & oil pressure gauge to fog up. Why would this be?
We've had rain in ATL for 7 straight days so it extremely humid...past couple of days the oil pressure gauge has totally fogged up and nada on the others. What gives?
Mark
1987 911 Coupe
Granite Green Metallic
My Cousin's Wife's Sister's Husband is a Lawyer.
Old 09-22-2009, 07:23 AM
2002 996 C4S
jcsjcs's Avatar
Same problem on mine. It tends to fog up early in the morning after a somewhat cool night.
jcsjcs
Have: '02 996 C4S
Had: '87 944, '84 911 Carrera Targa
Old 09-22-2009, 07:32 AM
Mark
Me too - though I haven't been driving in the floods like you.
'85 RoW 911 Coupe
'65 356 SC
'72 BMW 2002Tii
'10 Cayenne
'20 Ram Longhorn
Old 09-22-2009, 07:34 AM
Talewinds's Avatar
WTF? Same here, started just last week in the cooler evenings. And ONLY the oil temp/pressure gauge.
Looks like only Carrera 3.2's on this thread so far....
88' Carrera, Black/Black/Black, "Murdered Out" OEM.
06' BMW 'M' Roadster (Wife's car and WAY faster than mine)
Old 09-22-2009, 08:17 AM
Same with my 86 3.2. Was going to just swicth out the gauge but it seems there may be more too it if lots of people are having the same issue
Old 09-22-2009, 08:49 AM
mca mca is offline
mca's Avatar
At some point water found its way around the gauge.
When I first got my SC the same thing happened. Water was getting past my windshield seal and running under the dash. Two of my gauges were fogging.
I replaced the seal then pulled both gauges out and used a hair dryer to get rid of the moisture. In all likelihood you won't be able to "see" moisture in the guage ... but if it is fogging ... then the moister is there.
82 911SC Coupe Chiffon / Chocolate
9.5 JEs, 964 Cams, SSIs, Dansk Exhaust, CIS (SOLD)
Old 09-22-2009, 08:50 AM
Same issue on my 75S and 73.5T. Without any real investigation, I'd guess it has to do with the location of the gauge--directly in line with open area to trunk--and the construction of the gauge itself--possibly more openings to outside atmosphere in the case or more "empty" space inside the case itself allowing for easier condensation. Just a wag, and something to live with during the cooler months.
L.J.
Recovering Porsche-holic
Gave up trying to stay clean
Stabilized on a Pelican I.V. drip
Old 09-22-2009, 08:53 AM
My other ride is a C-130J
RNajarian's Avatar
Add my '75 S to the list. . . I wonder if replacing the gasket would help
1975 911 Targa S 3.0 2000 911 Carrera Cab 2005 Cayenne Titanium Metallic
2022 Mercedes-Benz E450 Coupé 2020 Mercedes-Benz E350 2006 ACG Hummer
Previously Owned Art from Stuttgart
2000 Boxster -1983 911 SC Cab -1984 944 N/A
Old 09-22-2009, 09:14 AM
carreraken's Avatar
Ditto on the windshield leak - had the same problem with foggy gauges which stopped once I fixed the leak.
Ken
06 Cayman S - gone
85 911 Targa - gone back home to Germany
73.5 911T Targa - long gone...
Founder ncPOG: nevada county Porsche Owners Group - disbanded post covid after 15 yrs
Old 09-22-2009, 09:15 AM
In my 1973.5T, 1974 911 and 1979SC the guage has never failed to fog under certain conditions. I attribute the fogging to the location closest to the door and outside conditions. I have never had a failed or faulty guage as a result of the fogging in any of these cars over a span of 30 years.
If it did not "fog" it would not be a 911!!
Bob
73.5T
Old 09-22-2009, 09:30 AM
normal. smoke at start up, normal, g50s rattle, normal, heater could work better, normal, etc. they have quirks.
206 637 4071
Old 09-22-2009, 09:44 AM
Son of a Son of a Sailor
Looking_for_911's Avatar
Here's a curve ball for you!
My SC did it last week while out on a short hop.
And the car lives indoors, it wasn't raining. I suspected that the cool temps of the basement combined with the rather hot and humid ambient temperature caused it, much like when my camera lenses fog when going outside from inside the house.
I will check for water leaks, though!
"Living and Dying in 3/4 Time"
Old 09-22-2009, 10:00 AM
sean m's Avatar
Mark,
Mine was doing the same thing. I did a search here and there was a very good thread on how to "carefully" take the glass off, clean the glass, let sit a few days to get humidity out, then carefully put glass back on.
I did it and mine no longer fogs up....
As I remember, you have to use a tiny screw driver to carefully pry open the lip of metal that holds the glass on. I used one of those eye glass screw drivers.
Do a search, I'm sure you'll find it.
Sean M
'77 911S Targa Ice Green
Old 09-22-2009, 10:04 AM
SCWDP911's Avatar
I think 3 or 4 (left to right) of mine will do this on cool mornings, if I have the top down
Shane
- 1984 928S
Old 09-22-2009, 10:15 AM
Senior Advisor
James Brown's Avatar
happens in the PNW all the time so I looked into the cause, plenty of moisture outside but none behind the dash. after pulling the gage, I noticed a whole in the firewall leading to the trunk. I left the Gage out and drove around a bit an sure enough, you an feel quite a bit of air coming from the trunk area. So, I figure that moist air, from the trunk, is being blown in/around that gage combining with increased OAT and elevated moisture and most of the time the Gages are cooler than the outside=fog/condensation. I'm working on a deflector for the back of the gage (just some cardboard or plastic) that should help.
08 Cayenne Turbo
Old 09-22-2009, 10:46 AM
mca mca is offline
mca's Avatar
So yours is fogging on the outside of the glass (meaning that you can wipe it with your finder) and not the inside?
The gauges don't have the best seal but they still shouldn't fog on the inside. I suppose it is possible but in 2 1/2 years since I replaced my windshield seal, I haven't had any issues. My car is also stored inside and it is hot and humid down here in Charleston.
Old 09-22-2009, 11:05 AM
cfries's Avatar
Add my 75 to the list. Its stored in the garage and hasnt been in the rain. Took it out last night and the oil/temp gauge fogged right up. Its been doing it for years.
61 VW Karmann Ghia
63 European Bug
75 Carrera Coupe 2.8L #81
75 911 Targa
2006 Cayenne S Titanium
Old 09-22-2009, 12:41 PM
Sorry, I am with John on this one.........."normal". Some quirky things about the 911 must remain!
If I had to advertise my 911, it would have as part of the description, "fogged left instrument" as factory specified..............
Old 09-22-2009, 12:46 PM
No... When I first saw it I did the finger wipe and was quite dismayed to see it was inside.
But, I did have the fleeting thought that this was a "normal" 911 quirk and wasn't too concerned with it.
I know Charleston's humidity well. Birmingham has the same humidity with none of the Charleston charm!
We're there a couple times a year. Absolutely love it. I'm trying to get the finace' to apply for admittance to the SC bar so we can move there! Sullivan Island is my favorite place. Folly Beach, too. But if I had that mythical boat load of money I'd buy a house on Sullivan in a heart beat.
mca mca is offline
mca's Avatar
I guess that I would be concerned that water was entering the dash area. Or that rust might form around the windshield if the seal is leaking. This is what I saw when the shop had my glass out.
"normal" no ... "tolerable" probably
Old 09-22-2009, 12:50 PM
