all the fish in the Puget Sound will love that run off from the cleaning.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 09-25-2011, 06:39 PM
rexav8r's Avatar
Like a proud Daddy !
You do nice work Thor !! What direction carb wise are you going to go with ? I'd like to do that eventually (PMO ??) with the SC, but it's going to take a lot of money & time to get it track ready first ! I like your exhaust too!
Friday, spent the day at my friend's putting the new oil cooler on the 2.2 '70E engine (small leak found on the old one after the engine rebuild.). Hopefully ready this week --> Mid-Ohio next week !!!
Nuthin' like a clean engine !
Richard W.
Red '70 E, 2.2
White (w/ Red & Blue), '82SC, "Frankenstein" -a bit tweeked
Old 09-26-2011, 06:47 PM
ipapilot's Avatar
Way to go Thor! It looks great! Are you adding cams or was this just meant to be a repair and clean job? Either way, it looks great and you have been truly indoctrinated
Brian Starr
Alabama Region PCA
1983 911SC/Rebodied as 993 w 3.6
1995 911 C2 (Sold)
Old 09-26-2011, 08:02 PM
rexav8r's Avatar
Hey Brian ! What have you been up to ?? I see a PCA treasurer now.....
Richard W.
Red '70 E, 2.2
Old 09-26-2011, 08:13 PM
ipapilot's Avatar
I've been the Treasurer now for 7 years brother, lookin' forward to hanging up that hat next year sometime if they'll let me
I've been well, just chasing the family around as the kids grow older and get more active in sports. Very little track time for me, unfortunately. I don't think I knew you had an SC as well, but it's been a long time...
Brian Starr
Alabama Region PCA
1995 911 C2 (Sold)
Old 09-26-2011, 08:19 PM
Captoz's Avatar
Nice collection of plastic on the shelf in the background!
Working on my 77, 911 has cut into my modelling time too.
Cheers
James in Oz
Originally Posted by Brown747 View Post
Engine is coming out for a broken head stud, SSI's , reseal, de-smogging, and a growing list of "while its out" items. Followed Wayne's book and all was straight forward.
Thor
Old 09-26-2011, 08:29 PM
Brown747's Avatar
Good eye James! I've found a new hobby for now.
Thanks Rich and Brian. No carb$ and no cam$ for now. Just want to get it back together and learn to drive it.
Thor
1978 SC coupe #1834
Old 09-26-2011, 11:14 PM
Brown747's Avatar
Krylon overhaul of the oil tank....Stripped , primed and painted. Engine tin back from powdercoating. Cylinders installed. Cam timing coming up soon.
1978 SC coupe #1834
Old 10-16-2011, 07:49 AM
al lkosmal's Avatar
Thor,
Nice work. Taking all that time to get it clean, really pays off while you're working on it......and when you are done...it's a thing of beauty.
regards,
al
RGruppe #669
http://www.x-faktory.com/
Old 10-16-2011, 08:13 AM
Brown747's Avatar
Progress report
Progress has been slow with life going on but with stormy weather outside I was able to spend the last couple days in the garage. Got the cams timed and valves set today. Picked up the rebuilt starter and alternator and the tins from the powder coater. No rush now that winter is setting in but things should progress rapidly now.
Thor
1978 SC coupe #1834
Old 11-16-2011, 05:25 PM
Brown747's Avatar
Getting closer to being back together. CIS restore up next...
Thor
1978 SC coupe #1834
Old 11-21-2011, 12:03 AM
al lkosmal's Avatar
Looking good Thor.......................this week is supposed to rain right through the weekend.....should get a lot done.
regards,
al
RGruppe #669
Old 11-21-2011, 07:51 PM
Great job Thor. Looking mighty fine.
Rob G
Old 11-21-2011, 09:41 PM
That's a nice piece of work --- of art! Congrats on the outcome. It's clear that you spent lots of time and hard work on it.
I see that you mount the engine directly to the engine stand. Is that the Harbor Freight stand? Or Ebay?
BTW --- "Brown747" --- I would guess that you fly UPS 747 cargo planes?
[QUOTE=Brown747;6383459]Getting closer to being back together. CIS restore up next...
Thor
1983 911 SC Coupe w Sunroof, Metallic Silver --- AKA 83 Silberpfeil
Old 11-29-2011, 04:46 PM
Brown747's Avatar
"That's a nice piece of work --- of art! Congrats on the outcome. It's clear that you spent lots of time and hard work on it.
I see that you mount the engine directly to the engine stand. Is that the Harbor Freight stand? Or Ebay?"
Harbor Freight stand and the top engine studs fit directly into the stand mounting plate. Because of the protruding lower studs it will not rotate beyond about 30 degrees either way from horizontal. As it is just supported only by the top 2 studs I would not want to turn it much beyond 30 deg. I will mount the exhaust then lower it to my ATV jack to finish up mounting the flywheel and clutch as there is not room with this stand setup. Next time I will spring for the correct mounting flange. I would also like the stability of a stand that has 2 "feet" as this single in the middle T design is getting less stable as the weight from accessories adds up.
BTW --- "Brown747" --- I would guess that you fly UPS 747 cargo planes?"
Yes, I fly the Whale for UPS.
Thor
1978 SC coupe #1834
Old 11-30-2011, 08:51 PM
al lkosmal's Avatar
Thor,
I have the adapter for the engine stand. You are welcome to borrow it and my stand, if you'd like, for the duration of your rebuild.
regards,
Al
RGruppe #669
Old 11-30-2011, 10:22 PM
Brown747's Avatar
Thanks for your offer Al! I'll give you a shout next week sometime....Thor
1978 SC coupe #1834
Old 12-01-2011, 03:15 PM
Brown747's Avatar
Back together!
Just wrapping up my lower stud change and cleanup project. Deleted A/C, cruise control, smog pump and associated plumbing, backdated heat, installed later style cam chain idlers, powdercoated tins, added SSI's and Monty. Next up , replace clutch cable and tunnel fuel lines before re installing. On track for a spring return to the road. Thanks to all that offered help and advice during this project.
Thor
Before
After
1978 SC coupe #1834
Old 12-18-2011, 11:41 AM
Member 911 Anonymous
DRACO A5OG's Avatar
Whoa, she cleaned up nice , my compliments!
'85 Carrera Targa
PCA/POC
Old 12-18-2011, 11:48 AM
The Dude abides...
bigel's Avatar
Sweet job indeed!
'03 Carrera 4S
Old 12-18-2011, 05:13 PM
