Member 911 Anonymous
Hewh! Glad that's over.
So what year are those "stabilizers" from?
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Racer
These are all names for the same device: anti-roll bar roll bar sway bar anti-sway bar stabilizer bar stabilizer The term "anti-roll bar" is generally preferred by chassis/suspension engineers. Note that they are never called "torsion bars". Scott |
Let's hope we will see his issue posted tonight.
Here is a picture of an early Porsche 911 Front Through-Body Sway Bar. I have no idea what size it is because I sold it ten years ago. I'm posting the picture just for reference.
Here is a picture of Porsche 911 Front & Rear Torsion Bars. I would not call these thru body because they don't actually go thru the body - they do however go thru the suspension.
Here's a picture of three girls "Planking". This has nothing to do with sway bars or torsion bars however, there is a car in the parking lot that uses sway bars.
![]() The point is: Original Poster, you need to post photos when talking about something that is confusing like this: swar bars marked 15 but measure 23 but factory never made these but front and rear are mis-marked and somehow ended up on my car by the factory? Last edited by Tidybuoy; 11-01-2012 at 12:15 PM.. |
Wow! I feel so stupid right now that I really did not want to even post this, but since so many of you tried to help me, I am going to admit fault. So my caliper was set at 32nd's, 19/32 = 15mm and 23/32 = 18mm. So the bars are correct based on what is stamped on them. Now I need to contact the person I bought them from and discuss that I was sold a 19mm bar and ended up with a 15mm.
Just out of curiosity, anyone running larger rear sway bar than front? |
I upped my OEM 85 stabilizers to 87's, both front and rears, larger id bushings had to be installed as well.
Don't sweat it brother we all done similar, ;-)
Racer
It is not at all uncommon to use a larger anti-roll bar at the rear. But, it all depends on your setup. I prefer to use adjustable anti-roll bars of the same size front and rear. I don't even know where to start using Factory anti-roll bars. Anyone would need to know what size torsion bars you are running front and rear. Scott |
Max Sluiter
You can add roll resistance independent of heave in many ways. Bellville washers, coil springs, bending of blades, etc.
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
Racer
Torsion Springs Or here: http://www.wisegeek.com/what-is-a-torsion-spring.htm Scott |
Thanks for understanding. I want to share my set up with you guys and see if you can point me in the right direction. The car is a 1967 912, the car was not original by any means, so dont get upset when I explain the mods. I swapped the motor with a EJ2.5 Subaru, Stinger ECM, making around 200hp. The car has been flared in the back. Running 16x7 with 205/50 in the front and 16x8 with 225/50 in the rear. Stock torsion bars but I lowered it, added a strut brace. It has RS bumpers and has been lightened throughout. It has a 4 point roll bar. It was not equipped with sway bars so I thought I would run a 19mm up front and a 18mm in the rear. I bought the bars used online and the seller sent me a 15mm for the front by mistake. I notice that everyone seems to run a larger bar upfront, but I am curious if anyone runs larger bars in the rear. I am guessing with the light Subaru motor in the rear and SWB a larger bar might end up with excessive oversteer. Any thoughts?
Will you be tracking or street only? DO you know your front and rear weights?
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC Last edited by DRACO A5OG; 11-01-2012 at 06:19 PM.. |
Max Sluiter
It also brings up the point that coil springs are actually torsion bars!!
OP I think you've been hi-jacked :-o
Okay parttime AX/DE er, okay do you happen to know front and rear weights or at least total weight?
After suspension upgrades, you should consider corner balancing to optimize the mods.
Racer
Racer
