Hey guys, here are some pics of the car.
Old 11-02-2012, 04:39 PM
PMB Performance
Eric_Shea's Avatar
Any more planking pics?
Old 11-02-2012, 04:53 PM
Max Sluiter
Flieger's Avatar
Subaru-powered 912? Looks like there is plenty of room in there for a turbo!
Old 11-02-2012, 06:13 PM
definitely enough room for a turbo. I contemplated the idea, but was worried about how much horsepower the 901 gear box could handle, besides the NA 2.5 makes about 200hp with the stinger ecm and pulls great off the bottom end, no turbo lag. It's pretty crazy how light the Subaru motor is compared to the 1.7 914 motor that was in the car when I got it. I plan to have it weighed soon just to confirm how much weight has been shed so far.
Old 11-02-2012, 07:27 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Oh Snap!
'85 Carrera Targa
PCA/POC
Old 11-02-2012, 08:01 PM
Will these do?
Old 11-02-2012, 10:30 PM
Max Sluiter
Flieger's Avatar
Old 11-02-2012, 10:41 PM
300hp 1800lbs is the goal
pksystems's Avatar
Check out subarugears.....
That's the route I have planned.
Subaru gearbox and motor
Can trim even more weight off car cause the modified transmission is supposed to weigh less then a 915.
The '66 912 Bastardization project has begun.
Note to PO's: LAY OFF THE FREAKING BONDO!!!!
The science was settled: Earth was flat.
Galileo : Flat Earth denier.
Old 11-03-2012, 05:36 AM
Ya, I have heard of them. The $2275 conversion price tag on top of the trans cost is what kills that idea and I am not sure it would work with my SWB axles and flanges. I do love the idea though and bet it shifts great.
Old 11-03-2012, 07:44 AM
Just had the car weighed today at the dump scale (note sure how accurate it is)
Weight: 2080lbs
1967 912
full tank of gas
subaru EJ25
fiberglass bumpers
4 point roll bar
16" wheels
RS door panels and carpet
Three gauge dash
dash pad removed and using plastic cap only
radio and glove box removed
all ducting and wiper system removed
I am not sure if that is considered light or not, I thought the curb weight of a 912 was around 2200lbs, and I thought I removed more than 120lbs, maybe not. Would you guys consider 2080lbs to be light?
Old 11-03-2012, 12:42 PM
Very cool Hot Rod you've got there.
Dean
2017 Toyota Tacoma TRD Sport(Hate it)
1965 Chevy Biscayne
Old 11-03-2012, 01:20 PM
You have added weight back to car because of the bigger/heavier tires and wheels. If you weight them off the car you could post. also, it would be helpfull to see front axel weight and rear axel weight for sway/torsion bar size. good luck Henry
Old 11-03-2012, 02:33 PM
do you think the 15" steel wheels are lighter than the 16" mags? Less sidewall on the tires as well, but they are wider. I know the roll bar added another 40lbs too. Maybe I need to replace more panels with fiberglass.
Old 11-03-2012, 03:49 PM
Banned
Originally Posted by Tidybuoy View Post
Will these do?
Absolutely not! Please only post pics of female plankers!
Old 11-03-2012, 04:18 PM
Weight: 2080lbs
1967 912
full tank of gas
subaru EJ25
fiberglass bumpers
4 point roll bar
16" wheels
Three gauge dash
It's not as light as 1800 lbs. but everything's relative. I'd say 2080 is pretty good. Do you have a target weight or will you ever be satisfied? As you might be aware, it gets increasingly more difficult and costly to continue the weight reduction scenario.
Blow through about 1/2 tank of gas and save 8 lbs/gallon., then subtract from 2080. The more fanatical among us might weigh theirs with only have 3 gallons of fuel and remove the spare, jack, handle and tool kit before weighing. Of course, all this weight savings can be offset by one's own set of personal baggage.
Sherwood
Old 11-03-2012, 05:36 PM
I'd say with that weight 19 and 23 anti rolls are overkill.
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 11-03-2012, 05:53 PM
Racer
winders's Avatar
That would depend on the spring rates of the torsion bars and the application....
Scott
Old 11-03-2012, 06:28 PM
Scott
Please explain how a torsion bar (e.g. 23mm) can produce different spring rates on the same vehicle. Just curious.
S
Old 11-03-2012, 11:54 PM
Racer
winders's Avatar
S
They can't and I didn't suggest that they did......
You might want to look at the post I responded to again.
Scott
Old 11-04-2012, 12:45 AM
Scott
Thanks. My bad..... reading, comprehension, etc.
Sherwood
Old 11-04-2012, 06:58 AM
