Hey guys, here are some pics of the car.
PMB Performance
Any more planking pics?
Max Sluiter
Subaru-powered 912? Looks like there is plenty of room in there for a turbo!
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
definitely enough room for a turbo. I contemplated the idea, but was worried about how much horsepower the 901 gear box could handle, besides the NA 2.5 makes about 200hp with the stinger ecm and pulls great off the bottom end, no turbo lag. It's pretty crazy how light the Subaru motor is compared to the 1.7 914 motor that was in the car when I got it. I plan to have it weighed soon just to confirm how much weight has been shed so far.
Member 911 Anonymous
Oh Snap!
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Max Sluiter
300hp 1800lbs is the goal
That's the route I have planned. Subaru gearbox and motor ![]() Can trim even more weight off car cause the modified transmission is supposed to weigh less then a 915.
The '66 912 Bastardization project has begun. Note to PO's: LAY OFF THE FREAKING BONDO!!!! The science was settled: Earth was flat. Galileo : Flat Earth denier. ![]() |
Ya, I have heard of them. The $2275 conversion price tag on top of the trans cost is what kills that idea and I am not sure it would work with my SWB axles and flanges. I do love the idea though and bet it shifts great.
Just had the car weighed today at the dump scale (note sure how accurate it is)
Weight: 2080lbs 1967 912 full tank of gas subaru EJ25 fiberglass bumpers 4 point roll bar 16" wheels RS door panels and carpet Three gauge dash dash pad removed and using plastic cap only radio and glove box removed all ducting and wiper system removed I am not sure if that is considered light or not, I thought the curb weight of a 912 was around 2200lbs, and I thought I removed more than 120lbs, maybe not. Would you guys consider 2080lbs to be light? |
Very cool Hot Rod you've got there.
Dean
2017 Toyota Tacoma TRD Sport(Hate it) 1965 Chevy Biscayne |
You have added weight back to car because of the bigger/heavier tires and wheels. If you weight them off the car you could post. also, it would be helpfull to see front axel weight and rear axel weight for sway/torsion bar size. good luck Henry
do you think the 15" steel wheels are lighter than the 16" mags? Less sidewall on the tires as well, but they are wider. I know the roll bar added another 40lbs too. Maybe I need to replace more panels with fiberglass.
Banned
![]() Blow through about 1/2 tank of gas and save 8 lbs/gallon., then subtract from 2080. The more fanatical among us might weigh theirs with only have 3 gallons of fuel and remove the spare, jack, handle and tool kit before weighing. Of course, all this weight savings can be offset by one's own set of personal baggage. Sherwood |
I'd say with that weight 19 and 23 anti rolls are overkill.
1973 911S (since new) RS MFI specs 1991 C2 Turbo |
Racer
Racer
Sherwood |
Thread Tools | |
Rate This Thread | |
