LinkBack Thread Tools Rating: Thread Rating: 19 votes, 4.26 average.
WUNDERWAFFE
JINKATIN's Avatar
Today I replaced the plastic door lock operating rod on driver side, with metal one. The plastic one kept bending and not allowing the door to unlock with keyless entry.
Charlie
1986 Carrera
Old 01-30-2015, 07:19 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #3721 (permalink)
amitch's Avatar
Drove from Christchurch to Auckland and back for the New Zealand festival of Motor Racing featuring F5000. About 2700 Kilometers.
We met Teddy Pilette ( two time European F5000 Champ and ex F1 drive) who ended up staying in the house we were staying at.
It was 41 years since he last raced in New Zealand so we took him to Pukekohe racetrack for a few laps in my 3.2. It had changed a lot since he was last there, but Teddy certainty hadn't forgotten how to drive fast! The only problem was the change from 5th to 6th!!
85 Carrera
2000 Boxster
Lives in Christchurch New Zealand.
Old 01-31-2015, 12:11 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #3722 (permalink)
flyn-hawn's Avatar
Originally Posted by BRAIDusa View Post
I need to do that. How much stuff do you need to remove verses masking off?
The wiring harness and fuse block, gas tank which is easy and I am doing thru hood fuel fill so it had to come out, brake booster, gauges and all the wiring, hvac system. I figured if I took out the electric system the car never would have run again, unless I had lotsa help ($$$$)
Old 01-31-2015, 01:12 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #3723 (permalink)
Doug&Julie's Avatar
Tried to fix our broken shift rod (top part spins in the bottom part...not good for shifting!). Couldn't get my fat fingers between the shift rod and base, so asked my helper to try...
Can't really say it was a successful fix, so most likely I'll be updating to a Rennshift system. To help with that ($$$), I need to put the winter Fuchs up for sale, so out they came for a good cleaning. Check out Julie's cool cleaning glove!
I promise, I actually did more than stand around and take pictures...
Doug
Currently Between Porsches
PART OF MY SOUL: '09 Boxster 2.9 PDK, '86 911, '76 912E, '06 Cayman S, '90 911 C4, '74 911, '78 911 Targa, '01 Boxster, '70 911T, '99 Boxster (#2), '72 911T, '88 911, '99 Boxster (#1), '84 911 Turbo Look, '73 911 Targa, '88 944
Old 01-31-2015, 01:26 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #3724 (permalink)
joefrantz's Avatar
Doug
If the shaft is just loose in the socket with the ball on the bottom, that's just an epoxy bond. A little heat and it comes right apart and you can re-stick it with some jb weld, or have it tack welded.
Joe Frantz
73 911 T
Old 01-31-2015, 06:20 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #3725 (permalink)
Driver
Noah930's Avatar
Gave it an Eye-talian tune-up, Mulholland-style.
Old 01-31-2015, 09:25 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #3726 (permalink)
Cooper911SC's Avatar
Busy day for me... Not exactly my 911, today a client's '81 SC Targa.
(I get to work on Porsche's every day)
10am start, install right door panel complete. Re glue plastic vapor barrier to door shell with rubber cement. Clean and paint machine screws for bottom of door pocket.
Remove old rubber seals for door light contact switches. Remove switches and clean contacts. Reinstall with new rubber seals.
Next paint white inset on heat/defrost knobs that are being restored. Let them dry in sun while lifting rear of the car.
Remove rear wheels and do a final wipe down of wheel wells and hand wax.
Install the heat knobs.
Remove old sun visors and install new 964 targa visors.
Remove rear rotor retaining screws, mask off rear rotor hats insitu, prep., and paint with Zinc weld thru primer.
Open and prep. new 1" spacers for rear wheel hubs.
Reinstall cleaned rotor set screws and rear wheel spacers.
Reinstall rear wheels.
Lower rear of car.
Lift front of car. Pull front wheels. Remove front AC Impact bar and cage. Prep. and repaint.
Final hand clean on front wheel wells. Hand wax.
1:30pm lunch
Pull front plate and clean valance area. Repaint plate screws.
Address hole torn in right wheel well from road debris near oil line. Pull and shape sheet metal. Fill small remaining hole with JB weld.
Stop work on 911, colorsand and buff Audi A4 rear bumper. (Yesterday's job) reassemble tail light and take care of overspray from someone else's repair.
4:30pm Back to 911, reinstall front AC cage and Impact bar. Mix up single stage Grandprix White and touch up chips around vehicle. Brush paint hole repair area.
Last item of the day, replace Gaff tape edging around expanded mesh screen for air intake at cowl.
End of day 6:30pm.
Always a good time when things get accomplished!
Cooper
Old 01-31-2015, 10:02 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #3727 (permalink)
SpawnyWhippet's Avatar
I finished fitting the new air oil separator and reassembled the top end of the engine, changed transmission oil and did a coolant flush on my 2001 996. Started and ran first time, no check engine light or funny noises, always a nervous moment after doing a bigger job like this.
Only managed to extract 2 liters of old oil from the transmission, it took 3 liters to bring it up to the filler hole.
1972 Porsche 911 coupe
2016 McLaren 570S
2016 Cayman GTS
2016 Land Rover LR4 HSE
2013 Mini Cooper S
Old 02-01-2015, 09:33 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #3728 (permalink)
Doug&Julie's Avatar
Originally Posted by joefrantz View Post
Doug
Good idea on the heat. It rotates right now, but doesn't come out...so we "rigged" it with some Gorilla tape for now. I'm kinda using it as en excuse to update to a Rennshift, but will use your plan if finances don't work out. Eric Hahl had the same thing happen to him, and he said JB Weld works just fine!
Doug
Old 02-01-2015, 10:15 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #3729 (permalink)
Pelican Parts Vendor
BRAIDusa's Avatar
I took mine "Up North" to watch the Sno*Drift rally. Needless to say it had fun
https://www.facebook.com/video.php?v=10204559739611265
Paul Eddleston
BRAID Wheels USA
Team Illuminata Motorsport
Old 02-01-2015, 04:01 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #3730 (permalink)
Eharrison's Avatar
Test fit for coil over suspension.
Ed,
1971 911e Targa, 2018 Porsche Cayenne Hybird
68 VW Transporter
2019 Ford F150 Quad cab 4X4
06 Ducati Monster S4R
Old 02-01-2015, 04:32 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #3731 (permalink)
Drove it!
We got a double whopper of snow. (Last night) One of the worst ever.
Old 02-03-2015, 10:15 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #3732 (permalink)
83 911 Production Cab #10
JJ 911SC's Avatar
Originally Posted by yellowperil View Post
We got a double whopper of snow. (Last night) One of the worst ever...
Wow, where was that, down the East Coast?
Who Will Live... Will See
Old 02-03-2015, 02:01 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #3733 (permalink)
Fastest Hunk of Junk
Today I finally sourced a good set of 16x 6 and 7s with '86 date codes, since my car lost its OEM wheels two owners ago.
-Brent
Old 02-03-2015, 05:34 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #3734 (permalink)
Fixed the clock in my 1972 911 with brake cleaner
2016 McLaren 570S
2016 Cayman GTS
2013 Mini Cooper S
Old 02-03-2015, 05:46 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #3735 (permalink)
Carmagic.us
rothaus's Avatar
Looks good. I see Eibach springs, what setup is it ? Did you had to make any modification at the top where the shock mounts ?
Looks like you use the steel Banana arms.
Cheers
Engelbert
For BA7s Dash LED, and External Marker LED go to carmagic.us - Now Luftgekühlt Emblems
Old 02-03-2015, 06:05 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #3736 (permalink)
IS300's Avatar
nothing...........
Old 02-03-2015, 06:20 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #3737 (permalink)
That's P.E.I.. We get a good bit of snow, like all of Canada, but this was a doosey.
Old 02-04-2015, 03:11 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #3738 (permalink)
Where did you spray it?
Old 02-04-2015, 03:40 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #3739 (permalink)
sugarwood's Avatar
Tried some multi-meter tests in my "Getting to know my 911" thread.
Getting to know our 911's: Performing some basic tests before there is a problem
1986 Bosch Icon Wipers coupe.
Old 02-05-2015, 03:16 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #3740 (permalink)
Tags
fuchs are ugly , stock sucks
