Subscribed
That's awesome. Any more pics and info on the TBs or the engine build?
Dealer for Cibie & other Period Fog/Driving Lights, brackets, Corbeau Seats, Fuchs, Torque Thrust, Minilite, Coromodora and other Period Alloy Replica Wheels GregGearHead com Ask me about Replica Fuchs (Even Deep 6 & 7R) wheels! |
97 varioram conversion>3.6 L with RS cams,Ceramic = length Headers,MK 2/2, and Koenengsberg (KMS) ECU.
(Pic is w dansk2/2 ) Build is by Specialty Cars -Nick Burkit /Allentown ,Pa. ![]()
1979 SC 1986 Carrera 3.6 L+ |
Eng-o-neer
How does the ram vario without that crazy stock intake?
72 911t
72 911T TWM Tec3r Cam Position Sensor
Tremalune , the vario is no longer, hence ,3.6 vario conversion.
1986SWT , Nice !! Questions: What Injector size/vol? What was the motivation to go with Tec3r Cam Position Sensors? How long have you been running the Tec3r? Are the air filters std PMO bases w K&N's or modified filter bases? Are the internals stock,or is it massaged a bit ?
Do the Rennsport and Rothsport plenum setups truly have an operational valve between plenums?
I understand the purpose and existence of these valves, just wondering if they are present in these specific setups? If there have valve just hard to see from the pics I've seen. Also if they have a valve, what triggers it, the ECU? ![]()
Yes they do. I received a quote from Rothsport which detailed the resonance tube, solenoids etc
Shirish 1987 Carrera, Granite Green |
https://renorennsport.com/wp-content/uploads/2016/11/AT-Power-Porsche-Throttle-body.pdf
Eng-o-neer
Shaftless, drive-by-wire throttle bodies?
A buddy of mine just finished his install and the car runs just as good with ITBs with throttle based load as it did using MAP only and a regular intake on a Ford Coyote. My car is currently running throttle based load and MAP based fueling and it runs great on the street. David
2007 911 Turbo 6-speed, 1984 911 Carrera, 1974 911S, 75 914-6 conversion/project, 2007 Mercedes SL63 AMG, Coyote Powered FFR Cobra |
Just shaftless, not drive by wire, at least not the ITBs.
Those are very cool and I admire the design ingenuity. However, I would be very interested in seeing some back-to-back, 3rd party, test results between ITBs with shafted butterflies (doesn't sound good or perhaps they're just the male of the species)) vs shaftless butterflies. Does this invention and the associated flow improvements translate into price/performance gains that will be meaningful and significant to the end user(s).
I'm always very interested in new design improvements...... and then gaining and understanding of how the improvement translates to improvements in the real world. regards, al
[B]Current projects: 69-911.5, Previous:73 911X (off to SanFrancisco/racing in Germany).77 911S (NY), 71E (France/Corsica), 66-912 ( France), 1970 914X (Wisconsin) 76 911S roller..off to Florida/Germany RGruppe #669 http://www.x-faktory.com/ Last edited by al lkosmal; 05-09-2017 at 09:26 AM.. |
Those ITBs look great. I'm less interested in the shaftless design than the direct-to-head config - looks really sharp!
I haven't used or built any shaftless style throttle bodies, but I've been around them and talked with people that have built and used them - so for what that's worth: The slide throttle setup seems to be hard to make easily progressive at lighter openings, because the vacuum is pulling the slide against it's runner/guide etc. Barrel throttles don't seem to have that issue, but more of a seal/leak issue due to the machining involved.
These shaftless ones - I'd be interested to hear about as well. From old flowbench work, of course reducing or removing the shaft increases max flow, but if the throttle bodies flow more air than the engine can use at redline, it's no benefit...
Yes....regardless of shafts or no shafts...i really like the design of these ITBs.
regards, al
[B]Current projects: 69-911.5, Previous:73 911X (off to SanFrancisco/racing in Germany).77 911S (NY), 71E (France/Corsica), 66-912 ( France), 1970 914X (Wisconsin) 76 911S roller..off to Florida/Germany RGruppe #669 http://www.x-faktory.com/ |
A T power
Take a look at ATpower in the U.K. They have just started manufacture of these straight to head tbs I don't think they actually have them on there web site currently, I have one set of the first manufacturing run for my ss3.2 anodised black breathing through mfi air box, I'll update on quality once delivered.
Shaftless Throttles
Hi,
Brian from Reno Rennsport. A customer of ours informed me that there were some posts on here regarding the Shaftless throttle design from AT that we adapted for 911 engines. Happy to answer any questions. We originally developed these for our Spec 911 cars as competition is very high in the class and small gains are of high value. But now we have been using them on street cars as well because the performance was a bit more than expected. In short we have seen improved port velocity leading to power gains starting as low as 3500 and of course top end power was much improved also. Throttle response is also greatly improved as the butterfly can be placed closer to the head and still have clean air. We are currently working with AT on a drive by wire single throttle which should be ready sometime this summer. thanks. |
I love seeing this stuff - it's always fun to see what others are playing with.
Regarding the setup shown in the picture of post #150 - Are the push-connect fittings and poly tubing used to gather a vacuum reference? (Most push-connect fittings are not rated for vacuum applications and tend to leak under light vacuum.) |
