That was a drive by wire development setup I photoed at Neil Bainbridge's workshop in the UK last year sometime, so unsure if carried into Production. He's rebuilding my engine and has been involved in the development of these ITBs with ATPower. My set should be received by Neil shortly.
Shirish 1987 Carrera, Granite Green |
single 3.2 TB?
I don't want to divert this thread but would a shaftless single TB (cable actuated) design benefit a 3.2 carerra?
The individual TB set up looks great. Regards, Steve QUOTE=Lowrance10;9582075]Hi, Brian from Reno Rennsport. A customer of ours informed me that there were some posts on here regarding the Shaftless throttle design from AT that we adapted for 911 engines. Happy to answer any questions. We originally developed these for our Spec 911 cars as competition is very high in the class and small gains are of high value. But now we have been using them on street cars as well because the performance was a bit more than expected. In short we have seen improved port velocity leading to power gains starting as low as 3500 and of course top end power was much improved also. Throttle response is also greatly improved as the butterfly can be placed closer to the head and still have clean air. We are currently working with AT on a drive by wire single throttle which should be ready sometime this summer. thanks.[/QUOTE] |
Subscribed... working on one now.
Does anyone knows where I can get a half tea air filter setup? Thanks
http://917burger.blogspot.com |
83 911 Production Cab #10
Just normal tea ball split in two. You need 6 as only one side of the tea ball is usable.
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
I was going to use these at one time, but some knowledgeable friends of mine mentioned that they had problems with tuning while using the real tea ball filter halves ......., that the mesh is too fine and they are very restrictive. There are some filters available that resemble the tea balls style, but are less restrictive. Your experience may vary.
regards, al
[B]Current projects: 69-911.5, Previous:73 911X (off to SanFrancisco/racing in Germany).77 911S (NY), 71E (France/Corsica), 66-912 ( France), 1970 914X (Wisconsin) 76 911S roller..off to Florida/Germany RGruppe #669 http://www.x-faktory.com/ |
These turned up with the engine builder today:
Looks like the hardware is 3,250 GBP / 4,160 USD.
Porsche 911 45mm Throttle Bodies (for 42mm Ported head - 102-102-00133 | Design 911 |
Eng-o-neer
No idea how it'll perform, but the silver gleaming off the black looks outstanding...
911SC Tinkerer
Reading older threads on the Triumph forms indicates that you can pick up 6-8% on the top end by eliminating all the airflow restrictions in the intake path. This included filing down the throttle plate shaft and knife edging the throttle plates.
It looked like a tremendous amount of work for small benefit, however on a motorcycle every bit counts. I'd like to know the optimum intake length from velocity stack to intake valve. I feel a lot of the set ups we have available leave power on the table in the low rpm band for the sake of looks and ease of install. I've tried using this site Intake Runner and Peak Torque Calculator And it spit out 18-24 inches depending on inputs given. If anyone else has a more relevant calculator please share. -Steve
-'83 911SC Coupe SSIs, Dansk GT3, EFI ITB, Instagram: @ Zinnmetallic_sc Last edited by merlinfe; 05-28-2017 at 06:52 AM.. |
![]() A first move in this direction I'm considering is grinding down the split plate screws. The other changes are something better done on a full race motor. Sent from my iPad using Tapatalk Pro
Chris https://dergarage.com ‘11 987.2 CS, '01 986S, '11 958S, '24 R1T, '87 Defender V8 |
Now, if modding those triumph throttle shafts and screws gives 6-8% on a 150hp (I have no idea, just guessing) engine, if your 911 engine makes 300hp, it could be a roughly similar beneft. If your 911 engine makes 200hp, would likely be a minimal benefit - depends on what the bottleneck is, of course. Optimal intake length depends on a lot of variables (valve event timing, displacement, rpm etc), and I've only dabbled in it over the years. I'm sure some engine builders/tuners could weigh in on it with some authority. With an ITB setup like this, part of the benefit is removing the long, possibly restrictive intake of a CIS setup (again, depending on the engine). If I was building a hot rod NA engine, I would go with ITBs for a couple reasons - sound, cleaning up the engine bay, and a likely increase in power over factory manifolding. Plus, in an older car, they look more period, IMO, even if there are fuel rails and injectors poking out here and there.
Dealer for Cibie & other Period Fog/Driving Lights, brackets, Corbeau Seats, Fuchs, Torque Thrust, Minilite, Coromodora and other Period Alloy Replica Wheels GregGearHead com Ask me about Replica Fuchs (Even Deep 6 & 7R) wheels! |
There is a great discussion on runner length, etc. on this 928 thread. May have to go back a page and read through the next several pages but worth it I think.
https://rennlist.com/forums/928-forum/961748-highwayman-bringing-the-devore-928-back-from-the-dead-45.html
Tru6 Restoration & Design |
I know there are some newer style ones out that claim they aren't restrictive, but I haven't seen anything empirical or scientific to prove it. When you work so hard to make power on a 911, then kill of some hp just to run some inadequate filters makes no sense to me.
Current setup with rain hat filters on top
Life moves pretty fast.
Here's mine.
![]() 3.5 conversion with Nikkies. SDS ECU Twin plugged Home brew manifold for the Triumph TBs Lots of time and money spent but love every minute of it.
Twin plugging, you know it makes sense
Certified User
Bored tonight so I pulled together a bunch of pics of my ITB journey for your viewing pleasure
![]() ITBs are from a Triumph Daytona 675 on home-built intake runners. Engine is a 3.6 with 12 Toyota COP ignition and MS3X. And yes, it flies! I bought the ITBs new on eBay for $100 each and spent maybe another $300 for various materials and the filters. ![]() ![]() ![]() ![]() ![]() ![]() ![]()
Bill 1988 Carrera - 3.6 engine with ITBs, COPs, MS3X 2024 Macan S Day job ... www.jesfab.com.au Memories: '68 912, '72 911T, '80 911SC, '84 911, '85 930, '86 930, '87 911, '21 Macan S Last edited by billjam; 06-17-2017 at 08:31 AM.. |
Certified User
A few more pics ...
Fuel rail is standard 3.2 part. ![]() ![]() The oval shape of the TBs below the butterfly was opened out to the same diameter as the buterfly (44mm). ![]() Injector ports in TBs were tapped M12 and plugged with short grub screws. One set of vacuum ports are brought together at a manifold to supply brake vacuum and a second set are used for idle control. ![]() Air cleaners have been through a few iterations. I started with these in carbon fibre but they weren't robust enough for my liking and were too close to the engine cover. I tried six foam type socks but kept blowing them to bits or melting them due to backfiring during initial tuning problems. Current arrangement is with top and bottom aluminium plates. Small rain shields are fixed to the underside of the engine cover to deflect rain water. ![]() Throttle linkage is two cables connected to a modified adjustable bell crank.
Bill 1988 Carrera - 3.6 engine with ITBs, COPs, MS3X 2024 Macan S Day job ... www.jesfab.com.au Memories: '68 912, '72 911T, '80 911SC, '84 911, '85 930, '86 930, '87 911, '21 Macan S Last edited by billjam; 06-17-2017 at 08:25 AM.. |
2.8L built on an early sand cast aluminum case with PMO throttle bodies and controlled by MoTeC. I backdated as much as I could to make it appear period correct.
'67 911S '69 911S, '70 911ST '73 911T Targa Signal Yellow '78 911SC backdate |
beauty Chris....and that dyno run is excellent........nice power and flat torque curve.
