AutoBahned
Clay - what material is on the firewall? And how is it holding up in use?
Thanks again for everyone's replies. Have a happy holidays, stay safe and be healthy. Scott
72 911 T Targa in Orient Red / Black - more like a 85 Euro RS IROC now - 85 Euro 3.2 with x-faktory EFI ITB + SSI + Dansk, 915 + Wevo, flares + IROC bumpers + duck tail, RS door panels, Corbeau LG1 microsuede seats, Speedware harness bar + drop links + Scroth DOT harnesses, adj Tarett sways, sport shocks, alloy trailing arms, Elephant Racing oil lines + spring plates + bushings, RSR Rota Foxes + Bridgestone S-04 PP, 2450 lbs |
My car actually has a close ratio gearbox. We’ll see how it behaves with more power. I’m expecting it to be just more of what it currently is, which is a high revving canyon carver. Maybe a bit more mid range. If I’m rowing through the gears faster, well that’s the idea! Last edited by BLACK3.2; 12-06-2020 at 12:17 PM.. |
ITBs = Happy New Year......
More x-faktory RHD kits headed out........EFI = Happy New Year.....
regards, al
[B]Current projects: 69-911.5, Previous:73 911X (off to SanFrancisco/racing in Germany).77 911S (NY), 71E (France/Corsica), 66-912 ( France), 1970 914X (Wisconsin) 76 911S roller..off to Florida/Germany RGruppe #669 http://www.x-faktory.com/ |
911SC Tinkerer
Al,
What ignition options do you find work best with MS2? I’d like something plug and play but I am willing to do wiring if necessary. -Steve |
Went through all the posts again in this thread. I noticed dyno posts from a lot of engines with 3.0 or lower displacements. Who has dyno graphs of 3.2 engines with EFI ITBs that they would like to share? Would be great to see a before / after graph (like Al's 3.0ss post) with no other mods. Additionally, if you have SSIs on your 3.2 I would like to see those graphs also.
Thank you very much everyone, I really appreciate it. Scott
Greetings. I typically mod my MS2s to fire an MSD Streetfire. You can use your stock distributor to continue to distribute the spark, but the ECU controls the fuel and spark timing. Next step up from that is a crankfire/EDIS system......both work vey well. My kits are as complete as I can make them and provide a great price/performance value....but "Plug n Play" is a little misleading for anyone's systems. These are aimed at the DIY market and while they do come with wiring harnesses, etc....they require mechanical installation and electrical termination of the harnesses and final tuning.....and while the kits come with a good start-up tune file, fine tuning is required........some folks head to the dyno, but the majority do it themselves with very good results. regards, al
Fingers crossed. Scott
72 911 T Targa in Orient Red / Black - more like a 85 Euro RS IROC now - 85 Euro 3.2 with x-faktory EFI ITB + SSI + Dansk, 915 + Wevo, flares + IROC bumpers + duck tail, RS door panels, Corbeau LG1 microsuede seats, Speedware harness bar + drop links + Scroth DOT harnesses, adj Tarett sways, sport shocks, alloy trailing arms, Elephant Racing oil lines + spring plates + bushings, RSR Rota Foxes + Bridgestone S-04 PP, 2450 lbs Last edited by sbrown.nw; 12-31-2020 at 08:58 AM.. |
Are you all using factory recommended plugs with your EFI ITB setups? Currently, I have Bosch WR7DC installed after my mechanic did a tune up a 1.5 years ago. Is this plug too warm for my 3.2 euro compression engine as the factory plug listed is a WR4CC (still available from Bosch)? They also list a WR4DP0 but that is an $18 platinum plug. What are the NKG equivalents? Any recommendations? Will the WR4CC be too cold with 92 octane gas (I try to get ethanol free whenever possible) when I have Al do his EFI ITB Option 2 kit on my car?
TIA, Scott
Retired Member
With the SSIs I had on the 3.0 and a Dansk sport muffler - 2 in/1 out.
Goal was mid and upper improvements. Turn3 worked their magic. ![]() ![]() Will retune this year - now with M&K 2 in/1 out with a GT3 style outlets that can be capped. The GT3 outlets is basically wide open and far too noisy. I will add some basic baffles to the 2 outlets this winter - test my metal fabrication skills.
1982 911 SC Targa - Rosie....my Mistress. Rosewood Metallic on Dark Brown and Black. Long distance road warrior and canyon carver. A few mods - a little interior, some brakes, most suspension and all of the engine. Last edited by Charlie V; 01-17-2021 at 09:47 AM.. |
Just asking, when selecting to use DIY Triumph throttle bodies the 97-98 come with a metal fuel rail and the newer come with a plastic fuel rail. Finding the 97-98 ones are hard to find but the new ones appear to be plentiful. So what, if I get the later plastic rail ITB's can I replace the plastic rails with metal after market rails easily and what source would fit ?
antares fatnwide - uncle dave 79 steel wide body Targa / euro 915 oil cooled LSD / SSI's / RUF 8 & 10's / Monty M22 / Alum flywheel plus lots of other silly little mods n upgrades |
New-ish 911SC Targa Owner
I found two sets of the t595 Daytona itbs on ebay for about $125 ea when I did mine. They came with metal fuel rails and injectors so thats what I used. I had enough details on the injectors to set them up in the Infinity 506 and dial in my VE map.
They are out there if you search.
'83 Targa 300k w/ freshened 3.0 with 930/52 case# 6770540 ARP and Raceware hardware - AEM Infinity 506, Triumph T595 ITBs, B&B headers, Dynomax muff, Fidanza FW, Alum PP-203whp |
Thanks ... So does the Triumph setup have adjustable throttle shaft rods/linkages at each body or does the shaft run straight through all three with just end adjustment capability ? I have read this gives one the ability for finer tweaking of each ITB for that cylinder's individual dynamics when dialing in the whole setup.
Not to discount at all the value or the efforts of those that have adapted throttles from other applications. In fact, I tip my hat to those that think outside the box. However, there are a few good choices of properly engineered applications that work quite well with our engines for not unreasonable amount of dollars.
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
scumbag
My first Porsche - http://forums.pelicanparts.com/porsche-911-technical-forum/989493-my-low-budget-dream-car-build.html AchtungKraft #009 - IG: @doktor_b |
you want more?
Next EFI/ITB install queuing up......with another kit getting assembled
regards, al
Going from Triumph ITBs
![]() To JSR Roller Barrel ITBs - yeah ![]()
Racer
Those MSD coils are oil filled and should not be mounted in that orientation. They are designed to be mounted upright with the connections up top. You need the black 8222 high vibration coil (encased in epoxy) which can be mounted in any orientation.
Here is what can happen with the red coils mounted like what we see in this car: My 911 on fire! Burning MSD coil
Scott Winders PCA GT3 #3 2021 & 2022 PCA GT3 National Champion 2021 & 2022 PCA West Coast Series GT3 Champion |
Racer
Or do I need to be a professional engine builder/coil installer with years and years of experience to point this out? That's seems to be the requirement around here these days.....
I don't think that's a requirement.
Not related to ITB's, but when I got my '75 it had an oil-filled Bosch coil mounted upside down as those are. I believe it came from the factory that way. I know it was oil-filled because it was leaking... |
