New Project, SC to RSR Style Hot Rod
Ok I finally found the car to start my next hot rod build. I have been searching everywhere and just missed on a couple cars, barely. But I was lucky enough to hear about this car today, it is a local San Diego car with 175K miles, but a straight tub and runs and drives great. Will be removing the engine and trans this weekend and start disassembly. Have already ordered new turbo fenders from Porsche and they will be shipped in from Germany, I was lucky enough to source new factory turbo flares here in SD.
I am aiming to have the car done in time for Monterey, lots of work ahead so I better get off the computer and get ordering stuff! ![]() ![]() ![]() ![]()
Follow me on instagram, @flyin.hawaiin www.davekealoha.com |
Cars and Cappuccino
Oh boy!!! What will be different about this build? Subscribe ided .
Hmmm, the color?The basic car will be a wide body sunroof delete hot rod, thru hood fill, 15" wheels, with a bright color paint job. Maybe some bespoke pieces here and there. Sticking with a touring style car that is comfortable and compliant but definitely not soft. Seriously after doing the last one there were a lot of people that had said they needed AC and or heat so incorporating that into the build and keeping it uncluttered will be something different and a priority. The body will be similar, I am really kicking myself for not pulling my own molds off the bumpers of the last one, we spent so much time getting them perfect. This time that will not happen, also I will have my metal guy make several sunroof panels and short hoods into long hoods. After speaking with him last nite he said I can get my price down if he knocks out several at the same time. This one will come down to bare metal as it had been repainted and there are some areas that filler is cracking so will need to check the car over. Not sure yet on suspension, been thinking about coil overs but it is not a track car so I'm not sure the extra expense will be a well spent option, but it is bouncing around in my head. Not sure what to do with the motor but EFI is high on the list, a friend has a complete fresh 3.4 twin plug race motor ready to plug and play, some talk about 3.6 and 3.8 has been going on, need more thought on that I do. I guess just stay tuned and we'll see what happens!
Looking forward to seeing this one develop.
Tru6 Restoration & Design |
How can you change to EFI and still be smog legal in California?
I thought that changing the fuel injection in California was against the law? Thanks, Rahl |
![]() I guess the Beverly Hillbillies were wrong when they said "California is the place to be"
Subscribed again!
Subrd
Max Sluiter
You could swap to a later motor with EFI and smog it according to the year of the motor provided that all the emissions control equipment appears to be in place and working and it passes the (tougher) sniffer test.
Otherwise you would need an EFI kit that flies under the radar, or temporarily put the CIS back on for the test.
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
RETIRED
You will enjoy it. Will lose the electric side view mirrors? I kept them as I appreciate the functionality.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
likes to left foot brake.
off to a good start! again
Eng-o-neer
Some guys in the UK are rigging up some electric AC that fits wholly in the frunk. It won't be Griffiths performance, but it might take the edge off. I'm not sure how far along they've gotten as the thread died:
Classic Retrofit: Lightweight Electric Air Conditioning Modest heat is easy. Just stick some CEET tubing from the engine shroud to a T-spitter to the exhaust headers and on to the flappers. No additional fans needed. Lots of threads and info on torsion bar suspensions. I'd probably stick with rubber and maybe polybronze. If the car has Bilsteins, having them custom valved will perform better in every way and be cheaper than off-the-shelf components, allowing you to up the spring rate without adding harshness. In terms of air/fuel delivery, it looks like ITB and EFI is maturing, though I'm not aware of any bolt-on kits yet: x-faktory: 3.0 with PMO/EFI & Rasant AEM Infinity A 3.6 adds something like $10-20k over a comparable 3.2-based motor (depending on what has been done to either). Everyone is moving so fast with their RSR tributes that by the time I'm done with mine I'll be another in long line of followers... Last edited by Tremelune; 12-22-2016 at 05:03 PM.. |
Cars and Cappuccino
And I hear you on the heat and AC. You know my thoughts/solutions on the heat topic already. ; ) And I am holding out/hoping for the electric AC system Tremelune is mentioning in his post. I know it needs the massively oversized washer tank removed, which I've already done on my build. I originally did it more for weight that anything. Figure I can carry a squeegee and some cleaning fluid with me n case it ever gets too dirty. : ) Might want to consider doing the same in anticipation of this new AC system. Good luck and Aloha Brother! I am sure it will be another epic build!
http://www.carsandcappuccino.com 1987 Grand Prix White "Outlaw" Turbo Coupe w/go-fast bits 1985 Prussian Blau M491 Targa 1977 Mexico Blue back-dated,flared,3.2,sunroof-delete Coupe 1972 Black 911 T Coupe to first factory Turbo (R5 chassis) tribute car (someday) |
15's mostly aesthetics, but ride is nicer, all things being equal anyway, the 15 provides a bit more cushion with them, personally i do not care for the 17's but I would not throw a Singer out because of that.....
The AC will just upgrade with Griffiths or Rennaire parts, the heat will be a simple backdate like Tremelune alluded to.
Love your builds, can't wait to se where this one is going
And Merry Christmas - from Denmark. |
Ditto. Loved the orange 911. Merry Christmas from Western Australia.
2012 Porsche Cayenne S V8 1974 Porsche 911 IROC Tarmac Rally 1978 Porsche 911 Gravel Rally 1978 Porsche RSR Speciale under construction |
Can't wait to see this!
Subscribed |
Some more pictures before we get started.
First off trans will be getting rebuilt with new bearings, sliders, synchros, lsd, larger turbo flanges to g50 axles to cope with bigger power 3.0 is going away to make room for 964 based 3.6, full rebuild with larger valves, bigger cams, arp hardware, cp pistons, 12 pin distributor, 50 pmo carbs. I had wanted to go efi on this build but just not happening on this one, hopefully the next one. ![]() ![]() ![]()
Administrator
Great stuff! Don't forget to check out our RSR tribute thread while you work on yours: Finishing the Pelican Parts 911 RSR Tribute Project. Looking forward to watching your progress.
