Crotchety Old Bastard
It'll fit.
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
Cool thanks!
Ok, another probably dumb question but bare with me. Haven't done this project before. The adapter, do I have to drive it down to this lip (yellow arrow)? Or is it already on where it should be. I just didn't want to force it on there because it's already down to that out lip.
Bill 997.2 |
After the next project
Response
Bill,
That orange seal inside should disappear and that lip should fit flush with the top of the turbo resting against where your yellow arrow is pointing. Bryan |
Alright, I guess it may be 'hammer-time'.
Bill 997.2 |
Bill,
That should not be fitting (at least for me it wasn't) that tight. Have you put a little oil around that orange seal. This will allow it to slide easier. I would try and fit that over the top without the seal first to make sure that there is no metal burrs or something that would prevent it from sliding on. Without the seal it should slide on with not too much force. Then, add the seal with your lubricant of choice, then gently (with a rubber mallet or dead blow) tap it into place. You don't want to damage that seal. Hope this helps, Bryan |
Yeah, I'll probably take it off and do as you suggested. In that pic it's REALLY tight. I don't want to mess up anything.
Bill 997.2 |
Macht Schnell
---Les Garten---85 930, Andial IC, GHL Headers, Fabspeed Dual, K-27 HF2, 3.4 JE Full Finned 7.5:1 CR, 964 CAM'd, Carerra 3.2 Manifold Cut/Flipped, Tec3r, Siemans 55#, GSF Fuel Rails, Clewett Crank Trigger, Clewett Cam Trigger,Dual Plugged, ARP Head Studs/Rod Bolts, Clewett Wires.Tial 46mm WG, Tial 50mm BOV, WEVO Shifter,934 Boost Gauge, Wideband EGO Sensor/Gauge, C2T Head Gaskets, '88 MB 300TE,BMW R100RT |
Les, mine was easy without the o-ring seal. I am shocked that they would be so hard without, but I appreciate your input.
I wonder is Stephen at Imagine does this to ensure a tight fit, or it's just too tight of tolerances. Have a good one. Bryan |
Macht Schnell
At the turbo outlet, is there a little bit of a raised edge around the outlet?
Mine has a raised edge. But it isn't too far off. I will have to grind some down to get it to fit without pounding on it too much.
Bill 997.2 |
Macht Schnell
Hi,
I had to take that edge down. It was so tight that I was sure it would "cut" the O-ring if it was forced. I took it down very slowly with a Hand file.
Yup that's what I'm getting ready to grind down. I thought I would use my bench grinder and go slow. Maybe even tonight.....
Bill 997.2 |
Here is another option for you that will not involve grinding the turbo lip.
I cut the end off of the stock up-pipe and added a length of hose. Cures a world of fitment woes.
Yeah, I thought about that. I ended up grinding it down to make the adapter fit. I think all that's left in question is the 'TIN' that needs to be trimmed. I'm not sure what needs to be trimmed to make all this fit. Unless anyone has suggestions I'll figure it out on Friday..
Bill 997.2 |
Macht Schnell
Hi, I've not wanted to carve up my boost pipe, but I'm going to do the same thing. All those O-rings and slip/swivel joints are leak prone. Also the change of IC and Turbo exacerbates the fitting/sealing process in the extreme. I'm not crazy about that adapter at all.
Not sure how the previous owner did it- but there's a picture of my cut down tube earlier in this post if you missed it. Looks like you need to cut, then grind it a bit to take the taper out and allow for a good seal. Bill- take a look at the pics on page 2, then Brian's attached, modded pipe- it makes sense to me and removes another link in the chain of possible leaks. I'd think about it some more before you start grinding on that turbo and take too much off- the lip may be nice to have to seal the hose if you're considering the tube mod option.
Jay '86 930 '60 Land Rover Series II SWB Last edited by jay71; 03-20-2008 at 08:46 PM.. |
That small length of hose is a lifesaver when removing and installing the intercooler. You can wiggle the up-pipe all around until everyhting settles in and fits snug. It can also be adjusted up or down to give the exact hieght needed when everything is flush. I've had zero issues with it after what seems like 1000 intercooler removals.
RarlyL8 - What kind of hose did you use? Is that just standard radiator hose or is something I can get from Lowe's? I just wouldn't want it to melt. I'm thinking I may go this direction after all.
Bill 997.2 |
No, it is a silicon hose made for the application. Not inexpensive. The adapter you have is about the same money as my hose and clamp setup.
I did not mean to derail your use of the adapter only to offer an alternative if it does not work for you. I've seen some line up perfectly and some not even close. Depends a lot on the headers.
Where would I get a hose like that locally? Hydraulic shop?
I'll try out what I have, but I do like the flexability with a hose like what you have. Besides by going to a hose would that avoid trimming the tin?
Bill 997.2 Last edited by wcc; 03-21-2008 at 05:30 AM.. |
