don't want to steal this great thread...
but it looks as if you intake pipe should be closer to the charge air pipe. Philip
87 930 GHL/Rarlyl8/Garretson/GT3582R/1 Bar/Wevo shift, mounts/Meth inj/LM-2/Custom Fuchs/Carrera intake manifold/Xtreme Carrera heads P&P/3.4/DR 993SS cams/ Mahl/Pauter/JE/Niresist/ARP/twin COP/8.25:1/KEP stage 2/twin tials/close 2,3,4th. MS3Pro Evo 500+ HP, BTSOMP Dyno
Yes, you can see the orange flex piping in some of the pics. Also I had to modify my tin. (cut hole closer to charge pipe hole). No mods to stock heating system. Philip
You ran the fuel line OUTSIDE of the car?!?
I was curious on that as well, I went all AN modern fuel setup on mine, but still ran the lines through the tunnel, seems sketchy taking the same route as the old AC lines.
'74 911 ('73 RSR "tribute") - Backdate project that sort of went off the deep end. http://forums.pelicanparts.com/porsche-911-technical-forum/996223-bergos-1974-911-backdate.html |
But fuel lines need protection ... I've never seen any manufacturer run a fuel line outside of the car. |
Most manufacturers run fuel hard lines under the chassis but I agree it's not necessarily the best route but perfectly safe in my opinion. Plenty of race cars and modified street cars run this exact route on the 930s.
1987 930 Turbo - 3.4L EFI Conversion |
Great project to be followed, I look forward to knowing the continuation!
One thank you for photos, explanations and especially videos!
I ran 6AN hardlines through the tunnel anything larger is an event to put in. I talked to Chris about this and he said that the larger lines (8AN) are almost impossible to run through the tunnel - so they run them where the AC lines are.
Look at most american cars - they run hardlines out side of the car along the frame since forever. Which is not saying much. If you do it very minimal - I think that works fine.
08 Aston Martin Vantage V-8 (6 spd manual) (DD) 20 Cayenne white-black/red (hers) 78 930 (heavily modified) 08 GT3 RS (white/black) (modified of course) 67 911S outlaw (sold) |
Although I think hard-lines inside the tunnel is the best solution for safety and longevity, you could argue that having flexible hose outside the tunnel allows it to be regularly inspected for leakage and more easily replaced (compared to flex-lines inside the tunnel, where it's impossible to inspect them thoroughly).
Metal Guru
Manufacturers don't run fuel lines in the "crumple zone" on a unit body (between the rocker and the first hat section floor reinforcement) for fear of having those lines rupture during a side impact. Further inboard is better with the centerline being the absolute best (if there is no propshaft). The positioning of the lines get verified with crash testing.
Paul B. '91 964 3.3 Turbo Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, H&R Coilovers, ESB spring plates- 210 lb |
935 Suspension with Moton Coilovers for the street The TechAFX hose has a cover over the braid so it doesn't chew up everything it touches. -8 BlackWrap SS Braided Teflon® Hose (10' length) | TechAFX
1986 911 Turbo 3.3L, K27HFS, Tial 46mm, TurboKraft Intercooler, 964 Cams, Monty Muffler, MS3Pro Evo, M&W Ignition, Zietronix WBO2 Data Logger, Wevo shifter, coupler and motor mounts. |
I'm waiting for the back to back dyno results of the two turbos.
Cool series of videos- thanks to Chris at TK for the behind the scenes access. Awesome!
Ken 1986 930 2016 R1200RS |
Thanks!
Chris Carroll TurboKraft, Inc. Tel. 480.969.0911 email: info@turbokraft.com http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft |
Ditto. Really cool to see the guys at TC do there thing. Thanks for taking the time to post the vids Pete.
81 Pacific Blue 930 Euro coupe slicktop on a strict diet, Rarlyl8 headers, Blowzilla turbo, Tial waste gate, Full bay I/C, Home made center out exhaust, Leask WUR, MSD 6AL, PLX wideband Wevo shifter, LSD. Next up, Cams, Heads and port work |
Scottsdale Arizona USA
Nice new build guys! Thanks for setting the example by going EFI and I'm certain you will enjoy the new drive efficiency. All original isn't living with these older cars!
Really enjoyed the vids as well. Mike, that was considerate turning down the death metal music!
Day @ Euro Parts West, LLC, Scottsdale, AZ USA // Automotive Part Connectors & EPW MODE : Motorsport Design +1 (844) URO-PART // modepw@europartswest.com |
The one caution I'm sure Chris went over with you was in regard to the exhaust manifold wastegate tube. The solid welded tube may eventually fracture at the collector with that configuration. The stainless (hopefully 321) expands quite a bit and also with that arrangement it could contribute to some boost creep. A danger worth taking into consideration if you haven't already.
Love the black anodizing! Maybe in a year or so you can follow up with the TurboKraft Billet Intercooler!
Pete,
I am stoked to see the results and finished product. Been really enjoying the videos. My car is in Chris's trusty hands to work his magic. (struggling sleeping at night with anticipation) Jeff |
Cheers, Chris 1986 951 SOLD: 1975 Carrera / 965 tribute w/ 1989 3.3 turbo 8.5:1, custom Evergreen K27 7200, 964 cams, euro CIS, TEC1 dual plug, rarlyL8 headers & hooligan pipe.
Soon afterwards!
Work in Progress
Pete hasn't updated the thread in a while, but he did put up two videos on rebuilding the transmission. Pretty good look at the process.
"The reason most people give up is because they look at how far they have to go, not how far they have come." -Bruce Anderson via FB -Marine Blue '87 930 |
