MFI information wanted
Hi,
I am rebuilding a 1973 911E, and would like to gather information regarding MFI pump. Would like to know how to calibrate and set up. Reason for rebuild is basically oil leak, but nice to look over other stuff as well. I have rebuild several 911 engines, but my first MFI system. All kind of information and links would be appreciated. Thanks Trond
Trond R. 1979 930: Garret GT35r turbo, EFI, carerra intake, Link EMS, custom GT2 cams, 98mm JE P/C, 964 crank (stroker), custom valves & ported (XtremeCylinderHeads) etc..etc.. 1972 914-6 GT replica project 1986 944 Turbo |
Ultimate MFI resources thread
MFI Check Measure Adjust - click for high resolution Trond.........here is a good place to start. regards, Al
[B]Current projects: 69-911.5, Previous:73 911X (off to SanFrancisco/racing in Germany).77 911S (NY), 71E (France/Corsica), 66-912 ( France), 1970 914X (Wisconsin) 76 911S roller..off to Florida/Germany RGruppe #669 http://www.x-faktory.com/ Last edited by al lkosmal; 12-10-2014 at 07:00 AM.. |
Like Al suggested; Ultimate-MFI-Resources & MFI Check-Measure-Adjust. Sounds like you want to dig into the MFI pump, so I would suggest getting the DIY step-by-step guide written by Michael J. Burgess. His web site is: WELCOME - The Home of the DIY Step-by-Step Porsche 911 Guide. All the information you need to rebuild your MFI pump.
Mark Jung Bend, OR MFI Werks.com |
MFI magic
Trond,
Mark Jung...posted above...is the go to guy for MFI knowledge, rebuilds and tuning. When i was rebuilding my 71E, I took my pump apart to learn, refurb, etc............I was amazed by how the pump was actually like another little 6 cylinder engine......incredible design. (check out the pic below) I did my best and then I sent it to Mark to ensure that it was done right. Mark basically took it all apart, replaced all the gaskets, refurbed, dyno tuned etc and sent it back to me as new...............I bolted it in and fired it up. MFI is a great learning experience, made even better knowing that there are experts to back your play.
[B]Current projects: 69-911.5, Previous:73 911X (off to SanFrancisco/racing in Germany).77 911S (NY), 71E (France/Corsica), 66-912 ( France), 1970 914X (Wisconsin) 76 911S roller..off to Florida/Germany RGruppe #669 http://www.x-faktory.com/ |
That's a great picture...just need the Lego style instructions to go with it as I start to experiment with MFI.
Marlon 1973 911 3.0 MFI |
Al and Mark, thank you for your information.
Amazing how many parts that is inside the pump.
Great photo of all the parts of a late MFI pump. One part missing. Al knows. Anyone else?
part missing...
Without this part it will not run!
Now I'm curious...
I'll take a wild guess. I don't see anything that looks like a cylinder head with injector line fittings on it.
Max Sluiter
Belt?
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
Not the belt or injector lines/injectors. Just look closer at all the parts shown.
I have it...
OIL
Ha! and you thought you could trick us
No, not oil.
Drive pulley
Tom Butler 1973 RSR Clone 1970 911E - Sold but Never Forgotten 914-6 GT Clone |
Drive pulley is in the photo.
I think the space cam is there so how about the stylus?
But I also want to say the rear seal, even though the pump would still run, but just messy.
Good eye! I didn't catch the missing seal, but no that's not it. Stylus is there on the lever in the photo.
There should be two banjo fittings, one for oil and one for gas.
72 911T 2.4 MFI 2017 Escape SE 2.0 turbo 2020 Honda Civic Touring Sport 1.6 turbo 10' Madone 5.2/17' Lynskey ProCross |
