totle's Avatar
MFI information wanted
Hi,
I am rebuilding a 1973 911E, and would like to gather information regarding MFI pump.
Would like to know how to calibrate and set up.
Reason for rebuild is basically oil leak, but nice to look over other stuff as well.
I have rebuild several 911 engines, but my first MFI system.
All kind of information and links would be appreciated.
Trond
Trond R.
1979 930: Garret GT35r turbo, EFI, carerra intake, Link EMS, custom GT2 cams, 98mm JE P/C, 964 crank (stroker), custom valves & ported (XtremeCylinderHeads) etc..etc..
1972 914-6 GT replica project
1986 944 Turbo
Old 12-10-2014, 04:36 AM
al lkosmal's Avatar
Ultimate MFI resources thread
MFI Check Measure Adjust - click for high resolution
Trond.........here is a good place to start.
regards,
Al
RGruppe #669
http://www.x-faktory.com/
Old 12-10-2014, 06:57 AM
356RS's Avatar
Like Al suggested; Ultimate-MFI-Resources & MFI Check-Measure-Adjust. Sounds like you want to dig into the MFI pump, so I would suggest getting the DIY step-by-step guide written by Michael J. Burgess. His web site is: WELCOME - The Home of the DIY Step-by-Step Porsche 911 Guide. All the information you need to rebuild your MFI pump.
Mark Jung
Bend, OR
MFI Werks.com
Old 12-10-2014, 12:41 PM
al lkosmal's Avatar
MFI magic
Trond,
Mark Jung...posted above...is the go to guy for MFI knowledge, rebuilds and tuning. When i was rebuilding my 71E, I took my pump apart to learn, refurb, etc............I was amazed by how the pump was actually like another little 6 cylinder engine......incredible design. (check out the pic below) I did my best and then I sent it to Mark to ensure that it was done right. Mark basically took it all apart, replaced all the gaskets, refurbed, dyno tuned etc and sent it back to me as new...............I bolted it in and fired it up.
MFI is a great learning experience, made even better knowing that there are experts to back your play.
RGruppe #669
Old 12-10-2014, 10:20 PM
Sway Bar's Avatar
That's a great picture...just need the Lego style instructions to go with it as I start to experiment with MFI.
Marlon
1973 911 3.0 MFI
Old 12-12-2014, 03:04 PM
totle's Avatar
Al and Mark, thank you for your information.
Amazing how many parts that is inside the pump.
Trond R.
1986 944 Turbo
Old 12-13-2014, 11:49 AM
356RS's Avatar
Great photo of all the parts of a late MFI pump. One part missing. Al knows. Anyone else?
Mark Jung
Bend, OR
MFI Werks.com
Old 12-14-2014, 09:06 AM
part missing...
Uhmmm...a washer? Wait this is too easy
Old 12-14-2014, 11:18 AM
356RS's Avatar
Without this part it will not run!
Mark Jung
Bend, OR
MFI Werks.com
Old 12-14-2014, 11:23 AM
totle's Avatar
Now I'm curious...
Trond R.
1986 944 Turbo
Old 12-14-2014, 02:22 PM
I'll take a wild guess. I don't see anything that looks like a cylinder head with injector line fittings on it.
Old 12-14-2014, 03:19 PM
Max Sluiter
Flieger's Avatar
Belt?
Old 12-14-2014, 03:40 PM
356RS's Avatar
Not the belt or injector lines/injectors. Just look closer at all the parts shown.
Mark Jung
Bend, OR
MFI Werks.com
Old 12-14-2014, 04:19 PM
I have it...
OIL
Ha! and you thought you could trick us
Old 12-14-2014, 06:14 PM
356RS's Avatar
No, not oil.
Mark Jung
Bend, OR
MFI Werks.com
Old 12-14-2014, 06:38 PM
Drive pulley
Tom Butler
1973 RSR Clone
1970 911E - Sold but Never Forgotten
914-6 GT Clone
Old 12-15-2014, 03:32 AM
356RS's Avatar
Drive pulley is in the photo.
Mark Jung
Bend, OR
MFI Werks.com
Old 12-15-2014, 06:39 AM
Sway Bar's Avatar
I think the space cam is there so how about the stylus?
But I also want to say the rear seal, even though the pump would still run, but just messy.
Marlon
1973 911 3.0 MFI
Old 12-15-2014, 09:38 AM
356RS's Avatar
Good eye! I didn't catch the missing seal, but no that's not it. Stylus is there on the lever in the photo.
Mark Jung
Bend, OR
MFI Werks.com
Old 12-15-2014, 10:20 AM
tharbert's Avatar
There should be two banjo fittings, one for oil and one for gas.
72 911T 2.4 MFI
2017 Escape SE 2.0 turbo
2020 Honda Civic Touring Sport 1.6 turbo
10' Madone 5.2/17' Lynskey ProCross
Old 12-15-2014, 11:48 AM
