Mighty Meatlocker Turbo
I wonder how we'll all be able to cope - perhaps drugs (more) will be necessary?!?!
you're doing just fine the reversed gas flow "The smaller front PFC IS now doing the Premiere first act stage of highest heat temp condensation, rear second act or stage PFC is just idling along NOW and helping!" If my front PFC were only a little more efficient there would be no need for the rear PFC AT ALL I have an idea i have been sitting on for over for 3 years; prototype for a more state of the art front ONLY CONDENSER early model 911 PF (different) MICRO-CHANNEL; but I am to busy right now to test it LOL These fools making all the BS Noise in here shot themselves in the foot Dave you like technology go read about co2 refrigerants and A/C co2 compressors the auto industry is currently installing in cars Last edited by KelogGes; 05-11-2016 at 06:03 PM.. |
El Duderino
Selling. Not selling.
Going to explain the new idea. Not going to explain the new idea. Rerouting. Reversing. There is more. There is nothing more. There is a customer and he isn't allowed to share anything. This whole thing is an enigma shrouded in mystery. If anyone does page the admins maybe they will delete the nearly 2 dozen pages that don't tell us any more than when this thing started. My synopsis.
There are those who call me... Tim '83 911 SC 3.0 coupe (NA) You can't buy happiness, but you can buy car parts which is kind of the same thing. |
Good luck, Dave
Dave McKenzie 1984 Carrera 3.2 1984 928S Automatic 2001 996TT |
Fleabit peanut monkey
1981 911SC Targa |
Not sure why Mods should be called in? It's an interesting thread, and I've learned a lot about AC so far, and had many chuckles.
Jake Gulick, Black Rock, CT. '73 yellow 911E , & 2003 BMW M3 Cab. Ex: 84 Mazda RX-7 SCCA racer. did ok with it, set some records, won some races, but it wore out, LOL[/B] |
Immature Member
All these AC mods are laughable. 34F vents temps? Whut-evar. My AC goes to 11!
1984 Carrera Coupe = love affair 1997 Eagle Talon Tsi = old girlfriend (RIP) 2014 Chrysler 300 AWD Hemi = family car "Lowering the bar with every post!" |
964-993 AC Condensers OLD OBSOLETE TECHNOLOGY 964-573-011-03 993-573-011-00 993-573-011-01 993-573-011-10 I have designed PFCs for this model also but have not made them yet I want to come out with PFCs for the 930s next I think my rear 930 PFC design will adapt nicely for the 964 & 993 Last edited by KelogGes; 05-12-2016 at 07:39 AM.. |
April Was Hottest Month Ever... Record Smashed AGAIN...
April Was Hottest Month Ever... Record Smashed AGAIN... 'Greater Than 99 Percent Chance' 2016 Will Be Warmest Year In History...
No doubt that high levels of methane produced by reversing the gasses has contributed greatly to global warming. Quote:
I Am SURE YOU LIE!
Jeebus, Rawknees..........
Per WIKI Publishers point to "many longtime Almanac followers claim that our forecasts are 80% to 85% accurate" on their website.[1] Professional meteorologists refute this pointing to historical results of below 50 percent accuracy rate. Get out and drive ten minutes and check vent temps. They will not be 27. Butt-of-course. (RIP to our dear departed friend).
1981 911SC Targa |
It's been a while since everyone has seen this annoying thread. Thought I'd bring it back for Memorial Day to remember those we've lost, and those who were sadly taken from us too early when removed from the forums during the "reverse the flow" war.
I think I might be on to something!
I asked my grandma to test this. ( disinterested third party). I had her take the top off our shop vac and put the hose in the different hole. Now it blows instead of sucks. And according to this found on the Internet .. "Air is a mixture of gases, 78% nitrogen and 21% oxygen with traces of water vapor, carbon dioxide, argon, and various other components. We usually model air as a uniform (no variation or fluctuation) gas with properties that are averaged from all the individual components. Grandma is reversing the gases to blow her driveway! That doesn't suck!
Bob K. sez yer Grandma's a hottie! And as a bonus, I bet she's way more pleasant to converse with than Reid/Kellogs! |
Basic Refrigeration Cycle: Apply to all A/C & Refrigeration Systems
Very Easy To Understand FOR DIY; detailed system knowledge Last edited by KelogGes; 06-20-2016 at 12:10 PM.. |
Reid Kelly 954-599 5235 ICECOLD911
The Professor: Symptoms of Air in a Refrigeration System | 2015-06-01 | ACHRNEWS
The Professor: Symptoms of Air in a Refrigeration System Air May Cause a Reduction in Condensing Surface Area and High Head Pressures FS-table.jpg June 1, 2015 John Tomczyk KEYWORDS Air in a Refrigeration System / condenser / John Tomczyk / refrigeration / The Professor Reprints No Comments Symptoms of Air in a Refrigeration SystemAir doesn’t belong in a refrigeration system, and if it gets in, it will cause problems. Air can enter a refrigeration system in many ways, including through tube, gasket, or flange leaks; poor charging procedures; poor recovery or recycling procedures; or by forgetting to purge hoses when accessing systems. If air gets into a system, it will collect in the top of the condenser and be trapped. Air is a non-condensable and cannot be condensed like refrigerant vapors. The liquid seal (subcooled liquid) at the bottom of the condenser will prevent air from leaving the condenser. Air will cause a reduction of condensing surface area and cause high condensing (head) pressures. Air can enter the system through a leak in the low side of the refrigeration system. Refrigerant leaks will eventually lead to an undercharged system. Severely undercharged systems will run vacuums in the low side. These vacuums will suck in air from the atmosphere because the system’s low-side pressure is lower than the atmospheric pressure. Know the Symptoms The symptoms of air in a refrigeration system are: • High discharge temperature; • High condensing (head) pressure; • High condenser subcooling; • High condenser split; • High compression ratios; • Normal to slightly higher evaporator (suction) pressures; • Normal superheats; and • High amp (Horse power) draws. Let’s take a closer look at each of these. High Discharge Temperatures — These are caused by high compression ratios. High heats of compression are associated with high compression ratios. High compression ratios are associated with high condensing (head) pressure. The compressor has to compress suction vapors through a greater pressure range; thus, more heat is generated. High Condensing (Head) Pressures — High head or condensing pressures are generated from the air taking up condensing surface volume at the top of the condenser. Because the air stays at the top of the condenser and doesn’t condense, it leaves a smaller condenser to desuperheat, condense, and subcool the refrigerant. High Condenser Subcooling — The elevated condensing temperatures and pressures make the subcooled liquid in the bottom of the condenser hotter. Now there is more of a temperature difference between the subcooled liquid and the ambient to where heat is rejected. This will increase the rate of heat transfer from the subcooled liquid because the temperature difference is the driving potential for the heat transfer to take place. The higher subcooling does not necessarily mean there is more liquid at the condenser’s bottom, it just means there is more cooling of the same amount of liquid to make the temperature difference greater. Remember, condenser subcooling is a temperature difference between the liquid temperature at the condenser outlet and the condensing temperature. High Condenser Splits — Because the air is sitting at the top of the condenser, causing elevated condensing pressures and temperatures, the temperature difference between the surrounding ambient and the condensing temperature will be high. This temperature is defined as the condenser split. High Compression Ratios — The higher condensing (head) pressures will cause the compression ratio to increase, causing low volumetric efficiencies and loss of capacity. Normal to Slightly Higher Evaporator (Suction) Pressures — A system’s thermostatic expansion valve (TXV) will control superheat as long as the pressure ranges of the valve are not exceeded. It takes a very high head pressure to exceed the pressure range of most TXVs. The TXV may overfeed a bit on its opening strokes because of the greater pressure difference across its orifice, giving it a slightly higher capacity. This may give the evaporator a suction pressure that’s a bit higher than normal. If the amount of air in the condenser is extreme, the compression ratio will skyrocket and cause very low volumetric efficiencies. This will cause a low capacity, and the box (your 911 cabin) temperature may rise. This added heat in the box (your 911 cabin) may cause evaporator pressure to increase because of the added heat load. Normal Superheats — As mentioned earlier, the TXV will try to maintain evaporator superheat as long as the valve’s pressure range is not exceeded. The opening strokes of TXV may momentarily overfeed the evaporator, but it will start to gain control shortly afterwards. High Amp (Horse power) Draws — The high compression ratio will cause a greater pressure range for the suction vapors to be compressed. This will require more work from the compressor and increase the amp draw. Publication date: 6/1/2015 Last edited by KelogGes; 06-20-2016 at 12:13 PM.. |
