It seems that what he actually meant to say was that he "invented" the idea of rerouting the high side refrigerant flow path, the front lid condenser first, then to the rear lid condenser and then to the dryer.
His claim was that this technique improved the refrigerant condensing efficiency substantially, well enough to justify the expense. No qualifying of the exact or approximate level of improvement was ever offered, as was the case of an engineering explanation for the gain, insofar as I am aware. My own measurement of CSA airflow for the 2 condensers seems to put the lie to his "invention". Even at idle the rear lid condenser gets a higher level of cooling airflow, and the equation gets worse with rising engine RPM. "Throw" in his "improved" PFC front lip condenser and matters get ever worse, as the new condenser actually BLOCKS(***) forward motion cooling airflow whereas the factory condenser takes advantage of this effect. *** As is the case with ALL aftermarket front lip condensers... PUZZLING, EXTREMELY so. |
Ah, ok, thanks for the summary, thats pretty much what I had gleaned.
Jake Gulick, Black Rock, CT. '73 yellow 911E , & 2003 BMW M3 Cab. Ex: 84 Mazda RX-7 SCCA racer. did ok with it, set some records, won some races, but it wore out, LOL[/B] |
I wish him well, but we may as well wait for Gilles to give us actual data or at least impressions. Good luck, Dave
Dave McKenzie 1984 Carrera 3.2 1984 928S Automatic 2001 996TT |
Mighty Meatlocker Turbo
GO SIT IN THE CORNER, WWEST!!!!!!!!!!
![]() The charlatan modus operandi continues, then - nice! Last edited by Rawknees'Turbo; 05-10-2016 at 11:36 PM.. |
Sadly, he thought again...
72 911T 2.4 MFI 2017 Escape SE 2.0 turbo 2020 Honda Civic Touring Sport 1.6 turbo 10' Madone 5.2/17' Lynskey ProCross |
YES THIS REMOVES MASSIVE HEAT from the front PFC Gills does NOT have this initially BUT IF HE WANTS ICECOLD911 @ 100 F plus ambient he will discover his OEM front blower ain't going to cut it! AND NEEDS SOMETHING LIKE THIS!!!!!!!!! ![]() ![]() ![]()
DaveMcKenz
YOUR THINKING IS WRONG ABOUT ENGINE HEAT AND WHAT IS GOING ON IN MY DESIGN! Last edited by KelogGes; 05-11-2016 at 07:33 AM.. |
Sturmvogel
Thanks, Reid.
Please clarify. My image is that you have a big honking front condenser and fan assembly that dumps a lot of heat, first. Then you have a very efficient rear PF condenser. You use an orifice valve and accumulator too. Besides control and air distribution, what am I missing? Dave
3 restos WIP = psycho
- 1965 911 - 1969 911S - 1980 911SC Targa - 1979 930 |
kenikh GET YOUR CRAP POST OUT OF HERE
OR I will bring back the moderators Last edited by KelogGes; 05-11-2016 at 08:45 AM.. |
maybe its time to do this anyway!!!!!!!!!!!!
Hi Reid,
I did include the reversed gas flow, by saying you send to front condenser first, then rear condenser. That's the only reversal isn't it? Thanks, Dave
There is basically no noticeable engine oil temp increase when the a/c is turned or off
With my design The OEM A/C Design greatly increases oil temp when the a/c is on as ambient temperatures increase Last edited by KelogGes; 05-11-2016 at 09:30 AM.. |
So, when Reid says "your thinking is wrong" he really means "you are 100% correct and understand this perfectly", just as when he says "invented" he means "didn't invent at all". See? He makes perfect sense, once you put his posts through the Spiderman Decoder Ring.
Mike Bradshaw 1980 911SC sunroof coupe, silver/black Putting the sick back into sycophant! |
its unfortunate I have decided to not post the install here, you had your chance
oh well! Last edited by KelogGes; 05-11-2016 at 09:44 AM.. |
