When you say to plug the connector to the WUR, you’re talking about the valve next to the gauge, right? Is there anything I can do to clean the WUR while it’s out right now? I won’t be back near the car for another day or three. |
I worked on it a few times, minor stuff. Yeah, he was proud if it. The black cherry paint was the giveaway. Haven't seen him in years. Maybe parked due to the current issue.
Some Clarification……..
NO. WUR has a gray electrical plug or connector that supplies power to the WUR when the FP is running. You can pull it out or disconnect it to prevent the WUR heater from heating up when measuring for cold control pressure. For measuring WCP, you need the electrical plug connected to the WUR to heat up the heater. Hope I explain it well for you to understand. No valve involve. Tony |
![]() Quote:
CCP - 70psi
WCP - 75psi (took 2ish minutes to max out here) I dont have a way to add vacuum currently. Will work on that. Going to reread the link above again for trouble shooting to see if I’m missing something… Last edited by ZeroHecksGiven; 05-27-2023 at 08:19 AM.. |
PCA Member since 1988
I don't think you checked the CCP correctly. It should be much lower than 70psi, more like 25-ish psi. You need the CIS gauge and valve setup to check the SP and the CCP and WCP.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! Last edited by PeteKz; 05-27-2023 at 12:48 AM.. |
Here is a picture from when everything was turned off and it was losing pressure over a few minutes…
Looks like the right setup, but you wrote something that got my attention. You said the other end of the gauge setup goes to the line closest to the firewall. That is usually the return to the tank, not the CP line. The correct connection should be the one on top of the WUR closest to the back of the car. That line goes down on top of the WUR, whereas the return line comes off at a right angle from a banjo bolt and points forward towards the firewall. Possible someone confused these in the past ad screwed them in backwards? Even so, I would expect the CCP to be much lower, and the WCP to be in the upper 40's.
What is your WUR part number?
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! Last edited by PeteKz; 05-27-2023 at 11:31 PM.. |
The WUR is a 033 I believe. Attaching some photos now. ![]()
It looks to me like the whole WUR is turned 180 degrees. If so, then the connections are correct, but turned around with the WUR. The brass nipple sticking out one end of the 033 WUR should point to the left where you can see the hose that connects to it. The nipple should not be under the intake runners. I don't think that will make a difference in how it runs, but at least it will be oriented like everyone else's.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
Very cool
Thank you for your time responding Hopefully we’ll stumble upon the missing link here soon.
Have you driven it yet? With the CCP being about the same as the WCP, which is also too high, it probably starts hard and you have to feather the gas to keep it running cold. No? But it may run okay when fully warm. At any rate, driving it will tell you more about what you need to do.
Probably too lean, due to several factors, including too high CCP. However, as a temporary work around, you can try to increase the richness of the CO screw 1/8-1/4 turn and see if that will get it running.
Is the switch in the air metering unit not allowing the fuel pump to run? Just checking.
Here's something else I try when it won't keep running: get an assistant to start the engine, and squirt starting fluid or gasoline into the intake to keep it running. If you can manually feed fuel and keep it running, then we know it's too lean. Then we work on getting correct mixture. Try the suggestion of enriching the CO screw too (clockwise enriches).
Have you set the initial static CO screw adjustment to 1/2 turn CCW from when the injectors start squirting? If so, try 1/4 turn.
https://youtube.com/shorts/7MOv4qPCkTI?feature=share
Welp, that’s progress. Turned the screw 1/2 turn cw and it was popping a little. Went another 1/4 turn and this is what we got. Buttoning things back up a little and will give it another go. We did start it once without priming and it mostly started right up Last edited by ZeroHecksGiven; 06-01-2023 at 09:34 PM.. |
Good to hear it running. Now drive it.
I'm wondering if your CO screw was way off? The basic setup should be 1/2 turn CCW from the point where the injectors start to squirt. If the car does not run at that setting, then something else is off, like the cold and warm control pressures. Get an exhaust gas analyzer or AFR gauge and figure out your CO%. The spec varies over the years, but somewhere in the 2%-3% range should get you in the ballpark.
Thanks Pete!
Not sure how far out it was and not sure if we're in the right spot now or not. Couple things. 1) I did the n00b mistake of overfilling the oil. We were letting it idle (high) for a good minute or two and when we killed it, we could hear the oil basically boiling on the left side heat exchanger. I drained the amount of oil I added and I think it's good now, except that now there is excess oil in that heat exchanger and it's smoking and smelly and kinda scary. 2) It's idling high. We will need to start over with that CO screw and dial that in a little bit (thank you for the tips about the injectors squirting). We had adjusted it in the very first day or two of messing with this thing. So it's likely that was an issue for sure. But it's also idling around 2K. We got it close to timed, but once it would settle in on the mark, the idle would surge a little and I was kinda chasing it around. Got it where I think it should be, but also understand that will need to be looked at again. So right now, feeling on the moon. Obviously, some things to address and dial in here, but it's progress and I'm pretty pumped. |
| Tags |
| 1977 , build thread , convertible , diy |
